Old 11-27-2002, 07:33 PM   #3106
Peter Busch's Avatar
R/C Tech Charter Subscriber
yes they did, why do you ask?
Peter Busch is offline   Reply With Quote
Old 11-27-2002, 08:23 PM   #3107
Moderator
Speedo's Avatar
I hadn't heard about them and then I looked at my car and realised I had them.
Now that I've moved to the inside hole on the arm in the rear, it will be interesting to see how it goes.
How do you all set preload? Do you worry about whether the spring is free when the car is off the ground, and set your droop accoringly? By free I mean a little bit of play up and down.
Speedo is offline   Reply With Quote
Old 11-28-2002, 12:50 AM   #3108
Lonestar's Avatar
Speedo,
preload: two things to take into account
1- Tweak
2- ground clearance
Assuming that the drop screws are not useless (ie that they indeed limit the suspension travel) and are already adjusted symmetrically, the way I do is
1- unscrew the shock collars to the max first,
2- put the car on a stand in order to have the suspension fully eytended,
3- screw each shcok collar separately until it touch the spring.
This procedure is applied to compensate for the usual unequal SPRING length (very common on AE springs).
4- take the car off the stand and make sure the chassis doesn't drag on the ground
5- put the car on a tweak (4-scale board)
6- fiddle with the shock collars until the readings are correct
7- then I adjust ride height on each end of the car by modifying the preload symmetrically left and right
A trick to help adjust symmetrically in step 7 is to make one or several marks with a magic marker on the shcok collar, to help you count how many turns you turn each of them. I also recommend counting them loud... believe me, it helps...
Although it is not optimal not to have a symmetrical ride height left and right, it happens on TC3's with tweaked chassis (like mine), I believe it's better to have assymmetrical L/R ride height and a correctly set L/R tweak compensation with preloads and okay droop screws, than a perfectly flat car which will track sideways...
now for the springs "floating" on the shock body, we discussed it below. It is very common especially with stiff springs, but you should not worry about it.
Later
Paul
Lonestar is offline   Reply With Quote
Old 11-28-2002, 05:09 PM   #3109
Moderator
Speedo's Avatar
Thanks man...
BTW, what is that in your avatar?
Old 11-28-2002, 06:03 PM   #3110
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Speedo.....looks like a cow or a steer.....being that hes from Texas there is only two things that come from Texas and well there is one of them in his avatar.............
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-28-2002, 06:04 PM   #3111
Send a message via AIM to Kaliboy
Default Cleveland race!!
anyone know of anything new the Associated drivers are doing this year on the cars, for the cleveland race???
i know about:
shaving the spine, for inner batery placement
using losi steering blocks
using losi rear uprights for less toe -in
rear tower in the front.... curently using stock on indoor carpet.
F -block for the front/ rear mount.
Is the solid axle the way to go still??
if anyone has info please post..
thanks
Kaliboy is offline   Reply With Quote
Old 11-29-2002, 01:41 AM   #3112
NTC3NUT's Avatar
Look for the NTC3 steering rack, modified NTC3 shock towers F&R, and some may have Losi rear shock towers glued/bolted to the outside of the modified NTC3 rear shock tower. I have seen all of these at one point or another, just depends on how they perform in Cleveland during qualifing.
NTC3NUT is offline   Reply With Quote
Old 11-29-2002, 02:14 AM   #3113
Craig's Avatar
Send a message via AIM to Craig
Talking
NTC3NUT- You take any pictures this weekend?
Craig is offline   Reply With Quote
Old 11-29-2002, 02:25 AM   #3114
NTC3NUT's Avatar
I'm not sure yet if I'm going, wife & kids (4) are all sick. If I do I will take a million & post them here first. Keeping my fingers crossed.
Old 11-29-2002, 02:59 AM   #3115
Craig's Avatar
Would be cool to see if you go.Kinda interested in how the AE camp will fair this weekend.
Old 11-29-2002, 06:43 AM   #3116
Lonestar's Avatar
Default indeed
Originally posted by Speedo
Thanks man...
Speedo,
as guessed by Kevin, it's a cow... Having lived in Texas and now living in Switzerland, which both are states with a strong cattle and dairy image, I figured out it was pretty appropriate!
Have a good WE yall
Cleveland: GO A-TEAM !!!
Paul
Old 11-29-2002, 12:01 PM   #3117
PizzaDude's Avatar
Default Josh's TC-3
I hope someone pins his cammera down on Cyruls TC-3.
Man is he driving a Losi TC-3 or something?
Every race more and more non (e)TC-3 parts show up in his ride...
He is in serious doubt it seems LOL.... (Losi vs AE)
On the Team Orion site a few pics are shown.
But I'ld really like some good close-ups!!!
PizzaDude is offline   Reply With Quote
Old 11-29-2002, 05:54 PM   #3118
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Pizza Dude, who made the Samurai? Was it Mauri? I cant remember.
Jack Smash is offline   Reply With Quote
Old 11-29-2002, 10:00 PM   #3119
Craig's Avatar
I wonder what AE thinks of there paid driver using Losi parts? Maybe they are RD new ideas for updates.
Old 11-29-2002, 11:29 PM   #3120
PizzaDude's Avatar
I thought Josh wash a Trinity man, and not a AE.
I mean for the sponsored part...
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
