Old 11-20-2002, 12:36 AM   #3016
Lonestar's Avatar
Default By the way...
... the pictured car won the last round of the regional Swiss championship. Granted, not the worlds, but not your average club race either. All these mods (tweak rods, motor fan) do work, believe me!
Later yall
Pauk
Lonestar is offline   Reply With Quote
Old 11-20-2002, 01:23 AM   #3017
Hi Guys,
I received my TC3 FT and bought as well the rear shock tower to put it in front,
the problem is when I use the upper second hole of the shock tower with the new external hole of the arm, on the right side I can't put my shock. On the left side no problem.
As the hub carrier is assymetrical, do I have to trim the right hub carrier ?
thank you for your help
Ralf is offline   Reply With Quote
Old 11-20-2002, 01:48 PM   #3018
robk's Avatar
Trader Rating: 22 (100%+)
Spongebob: try between 1-2 mm of uptravel. you don't need much if you track is especially high bite.
Old 11-20-2002, 02:02 PM   #3019
ralf if your talking about the shock collar hitting the c-hub then you have to dremel the hub just a little at a time and recheck. i had the same problem on both sides when i fitted the rear shock tower up front with the new arms.
those threaded rods look like they might be a nice feature to have but are they really very effective in adjusting tweak?
Jarrod Langlois is offline   Reply With Quote
Old 11-20-2002, 04:49 PM   #3020
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
I just scanned the last couple pages of this thread.....
I though only the Losi car has fundamental flaws from the factory?
lol
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 11-20-2002, 05:19 PM   #3021
Craig's Avatar
Send a message via AIM to Craig
Man-you guys take the smallest problems and b**ch about then night and day.Turn off the computer and go race.I have had my TC3 from the beginning and yes it had uneven toe in the beginning.Then after dealing with it for a while I found a fix.No big deal.Its not the end of the world.Look at the Losi car,you cant have good brakes without the belt slipping-sounds like premature wear to me? And yes I had one-fine car.The purpose for these boards are for racers to get together and figured their cars-so we can go faster then the competition,not complain about it.The TC3 is the best car out in my opinion.
And I have a NTC3 and it has the stock gas tank and runs fine.Send me a plane ticket and I will bring it and show you.
Now go out and race please...
Craig is offline   Reply With Quote
Old 11-20-2002, 06:02 PM   #3022
Kenneth Tan's Avatar
Default Binding
I have an FTTC3. I have just finished building the front and rear gearboxes with the new aluminium shaft. The rest of the parts are not fitted yet. I am very sure that I shimmed the transmission as what the instruction manual stated - yet the transmission is binding. Do I place the shims in a different position as stated in the mauual? What else can I do? Thanks a lot.
Nevermind.... found it in one of the pages earlier.
Kenneth Tan is offline   Reply With Quote
Old 11-20-2002, 06:33 PM   #3023
Craig's Avatar
Associated has said that there were bad hub carriers.But the last ones I have bought were fine.
Old 11-20-2002, 07:50 PM   #3024
JLMG1971's Avatar
Default Re: Binding
I have been running a TC3 for a year, I have had two kits so far, and in both of them I shimmed the tranny with only two, or one shim, the manual says three which I believe it stresses the bevel gears.... I might be wrong but it works for me
JLMG1971 is offline   Reply With Quote
Old 11-20-2002, 08:09 PM   #3025
TPhalen's Avatar
R/C Tech Charter Subscriber
<<Edit>>
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 11-20-2002, 09:37 PM   #3026
Default Mystracing
Dude it seems your on a rampage. What do you feel like your accomplishing while sitting behind your pc talking trash to a very nice person like Tony Phalen.
rangulo is offline   Reply With Quote
Old 11-20-2002, 09:45 PM   #3027
Default Mystyracing
Looks like you need more help than this web site can give. I regularly change out plastic parts because they wear out!!!! When I told you about having problems with the Hudy set up a while back, I was talking about a problem I had when I was driving a different car. I was not using that piece of equipment on my tc3.
Old 11-20-2002, 09:55 PM   #3028
Moderator
Speedo's Avatar
TPhalen, just out of curiosity, and I'm not sure if you can tell me this, but on average, how many of a car do you sell? Like the TC3 for example, you say the mold has put out millions of parts, I'm not sure if you are exagerating here, but I'm going to say you aren't, how many of those go into kits and how many are packaged individually? I'm just interested is all.
My TC3 should be here tomorrow, I'm looking forward to it.
Speedo is offline   Reply With Quote
Old 11-20-2002, 11:34 PM   #3029
Craig's Avatar
I was curious about that too,how many TC3 have been made?
Old 11-21-2002, 12:22 AM   #3030
johnbull's Avatar
Hi guys. Greetings from Malta.
SPEEDO. So that's what you're replacing the Yoke with. Good choice. I still run my Yoke and love it, but son Josh won't change his TC3 for anything. And who can blame him with 4 wins in 4 rounds of the Nats so far.
TONY. One of your arguments really hit me. It happens to me all the time. Just because I import certain items people think that the manufacturer gives me better ones than I supply to everybody else. Not so much with car kits but with motors and cells in particular, and i've even had accusations that Novak give us special speedos. I wish!
Actually I do have a slight advantage having a shop, and that's where cells are concerned. If I get asked to assemble a couple of packs for a customer and happen to come across a pack with really blinding figures, then i put that pack away for our own use. But the difference between the best and the worst of any company's top cells is so minimal that it doesn't really make so much difference. Certainly I'm not a good enough driver to notice it.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
