Old 11-12-2002, 10:06 AM   #2911
Guys,
What are the refs for Losi front hub carriers and front knuckles ?
Ralf is offline   Reply With Quote
Old 11-12-2002, 11:04 AM   #2912
Skip109's Avatar
Is it just me or does TPhalen's msg board have way to many popup windows to use?
Skip109 is offline   Reply With Quote
Old 11-12-2002, 04:14 PM   #2913
hey guys i was installing the new front arms on my tc3 today and when i went to set the droop on the car i had the droop screws all the way backed out and noticed the arms would not sit down on the chassis. after examining it i noticed the c-hubs where sitting against the molding of the outer lower shock mounting hole. i think im going to dremel this off but when im using that hole the screw may still be in the way, not sure though but ill find out. has anyone else noticed this? any comments? thanks guys.
Jarrod Langlois is offline   Reply With Quote
Old 11-12-2002, 04:38 PM   #2914
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
i had the same problem with mine you could do it with a dremel or a x-acto knife but when you do it try not to cut to much off so you dont weaken the caster block
RCAmerica, X-Ray, Hudy, Ko Propo, Protoform, PRS, Jaco, JConcepts, SXT, RC3 Grafix, Kool-Aid, P-Nut, NEXT, www.SuperiorHobbies.com
We're going to skate to one song and one song only!
Dave Bowser is offline   Reply With Quote
Old 11-12-2002, 04:56 PM   #2915
Send a message via ICQ to ecenshu
I'm not sure if this would help anyone here but Team Orion has a decent chassis setup guide that I found quite technical.
The URL is http://www.team-orion.ch/faq/car-handling.asp
It's a reprint of another guide I found but it's layout looks much better =)
ecenshu is offline   Reply With Quote
Old 11-12-2002, 05:02 PM   #2916
phatskeemz, i dremeled off the molding for the lower shock mount screw. now i can get the arms down to about the 3 1/2 range on the droop gauge. now i noticed when i tryed to install the shock into the outer hole on bottom the collar hit the c-hub. any suggestions on what i should do now? thanks
Old 11-12-2002, 05:04 PM   #2917
I have a Team TC3(Not factory team) and was wondering what parts I needed to add to get droop adjustments? Do I need new chassis and arms? and how do I tell if the parts I'm getting is the Factory team one, not the team or racer versions? Cheers!
Old 11-12-2002, 05:19 PM   #2918
spaz 465 im not sure we are on the same page look at my post agen and that should fix the problem
Old 11-12-2002, 05:43 PM   #2919
ok, first i dremeled of the molding aroung the lower shock mount on the arm, but now i think will trim a little of the c-hub too. i see what you mean now. thanks.
esenchu- the kit should say on the box. the team is a little more expensive then the racer version, and the factory team is a little more expensive then the team kit. for the droop adjustments it depends on how old your kit is. the droop adjustments were added in later on. maybe a year or so after the tc3 was released, dont quote me on that.
if you dont have the droop adjustments you may need the newer chassis and new arms with the droop screws. i think thats it.
Old 11-12-2002, 05:48 PM   #2920
All you need to add droop screws to your TC3 is to purchase the arms with droop screws installed, the original chassis did not have the little ears for the droop screws, although associated designed their location so that they can still be used on the original chassis (they touch just on the edge of the chassis) this is how i have mine, and they work fine.
So two pairs of arms should cost you very little and you will have an uptodate car.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 11-12-2002, 06:28 PM   #2921
i am not familiar with the older chassis so its sounds as though you are in luck and do not have to buy a whole new chassis then.
Old 11-12-2002, 06:34 PM   #2922
dcracer's Avatar
The old chassis will work just fine with droop screws.
dcracer is offline   Reply With Quote
Old 11-12-2002, 07:13 PM   #2923
Thanks for the prompt responses!
Do the droop screw holes exist in the graphite arms and/or the plastic arms?
and how do I tell if they are droop adjustable? Do they have different part no's?
Old 11-12-2002, 07:45 PM   #2924
dcracer's Avatar
Both types of arms have the droop screw holes. Unfortunately the part numbers for both the old and new arms are the same. If you look towards the inner hinge pin mount on the arms you should see a round hole where the set screw goes.
Old 11-12-2002, 07:48 PM   #2925
dcracer's Avatar
One other thing to remember, once you start using the droop screws, you don't need to use limiters inside the shocks any more.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
