Old 11-07-2002, 06:26 PM   #2866
madweazl's Avatar
So were they 21mm or 26mm and what size were the wheels
madweazl is offline   Reply With Quote
Old 11-07-2002, 06:28 PM   #2867
[QUOTE]Originally posted by madweazl
[B]So were they 21mm or 26mm and what size were the wheels
26mm HPIs ....unsure on the wheel size.
Greg
GKHTC3 is offline   Reply With Quote
Old 11-07-2002, 06:35 PM   #2868
dcracer's Avatar
The wheels that come with the racer and team version of the TC3 are 26mm.
dcracer is offline   Reply With Quote
Old 11-07-2002, 06:36 PM   #2869
Well; there you go then..........
Greg
Old 11-07-2002, 06:37 PM   #2870
dcracer's Avatar
I just checked out the Tower website and they had the HPI X pattern radials in 21mm and 26mm. Is this the diameter for the wheel (which I thought was 24 and 26mm) or some other measurement? Which one do I use?
That measurement refers to the width of the wheel. I would use the 26mm for your application.
Old 11-07-2002, 06:40 PM   #2871
Yep! And, that's a really nice tire, in my opinion. I'm getting really good wear with mine. Like I said before, I'm using these X patterns in the parking lot for our lunch time racing. I'm sure I will go with slicks when the racing season resumes in the spring. And, still use the X patterns for parking lot / street racing.
Greg
Old 11-07-2002, 06:41 PM   #2872
madweazl's Avatar
Thank you, I'll add them to my next order and try them out. I need to find aluminum caps for the shocks with the bleed wholes in them too. Wish Associated shocks were easier to build correctly. A pain filling up the cap and then screwing it down as fast as you can, I'm use to the Losi shocks. Nice and easy to get right the first try
Old 11-07-2002, 06:47 PM   #2873
I know!! I just rebuilt my TC3 threaded shocks. What a pain! But, since I have had my TC3 now for about 2 months, and I just recently added the blue aluminum shock caps, I figured I would go ahead and do a rebuild. I used 40wt. oil, and yes it was time consuming, for sure. I have an OFNA stand with that nifty shock holder, and that came in very handy. I think I got them all about equal. But just like anything else....next time should be easier.
By the way.... How often do most of you rebuild your shocks?
Greg
Old 11-07-2002, 06:50 PM   #2874
madweazl's Avatar
With my other cars I did it every other race. Probably wont do these quite as often since its not offroad. Probably every 3rd race now. I like smoothe consistent shocks
Old 11-07-2002, 07:34 PM   #2875
lem2's Avatar
Default shock cap
where can i get a blue aluminum shock cap??
who makes them??
thanks
lem
lem2 is offline   Reply With Quote
Old 11-07-2002, 07:36 PM   #2876
Default Re: shock cap
I ordered my blue aluminum shock caps from Tower www.towerhobbies.com - about $10 for the set of 4. Team Associated makes them.
Greg
Old 11-07-2002, 10:39 PM   #2877
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
lem2: last i looked pitshop had the AE alum shock caps.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 11-08-2002, 12:21 PM   #2878
Default Barry Baker's Spur Gear, as seen in RC Car Action...
I noticed Barry Baker's TC3 race setup in the November issue. What kind of Spur Gear is he using?
Greg
Old 11-08-2002, 01:18 PM   #2879
rc-zombies's Avatar
Default Re: Re: shock cap
Greg
I have a set and they leak... stay with the original or yokomo shock caps.
lem2: my parents are going there in Jan.'03. do you want mine?
pm me on you address.
Old 11-08-2002, 01:28 PM   #2880
rc-zombies's Avatar
Dusting off my TC3 and doing major upgrade..has been sitting on the shelf for over a year now...
Don't know if this was discussed yet...anyone running the XXX-s rear hub carriers on their TC3's? I just changed mine..fits perfectly...camber angle about the same. Anyone done this mod and how does it handle?
Also what is the advantage of running the rear shock towers in front along with the new 2 hole arms? I know it places the shocks more upright... what are the advantage and disadvantage of doing this mod..?
Here's what I've done to my car so far:
http://groups.msn.com/RCZOMBIES/tc3.msnw
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
