Old 10-31-2002, 05:15 PM   #2776
Skip109's Avatar
The diffs work fine if you dont let them slip(no slip no heat no heat no melt)
I have run them with 8turns.
Skip109 is offline   Reply With Quote
Old 10-31-2002, 05:22 PM   #2777
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
I tend to go with steel, period. They weigh a bit more, but I'm still right near the minimum anyway. I prefer a reliable car that I can drive fast over a plastic car that may melt in the middle of a race.
BTW, my diffs don't slip. Not in my TC3, not ever. But I'm still not going to go to plastic. Alum, maybe, but not plastic.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 10-31-2002, 05:38 PM   #2778
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Trinityracingnut......If you melted your diff's maybe your car was diffing in the corners and thats why you melted them. If your car is not setup exactly in mod foam first thing you will notice is how bad and how fast your diffs get crappy. So I would look into that setup of yours and see whats really going on. I would almost bet to say that the car was on 3 wheels in some corners.....this was the first time you ran mod foam right?
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-31-2002, 06:19 PM   #2779
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
you should try the irs outdrives thay are awsome but you will also need to use irs pin cushions thay sell the dog bones with them are you can buy just the pin cushion if you buy just the pin cushions use a slotcar pinion puller to push out the old pin you will also need ass part #6575 to replace the old diff nut also try sanding your diffrings with some 600 grit sandpapper befor you build it
RCAmerica, X-Ray, Hudy, Ko Propo, Protoform, PRS, Jaco, JConcepts, SXT, RC3 Grafix, Kool-Aid, P-Nut, NEXT, www.SuperiorHobbies.com
We're going to skate to one song and one song only!
Dave Bowser is offline   Reply With Quote
Old 10-31-2002, 07:06 PM   #2780
TPhalen's Avatar
Hey everyone. Been awhile since I've been on here. AE keeping me busy!!!! Just wondering what's going on???
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 10-31-2002, 07:18 PM   #2781
shrekair's Avatar
Trader Rating: 9 (91%+)
where can i find an editable TC3 setup sheet? one that you can record right on the sheet w/o having to print and re-scan it?
shrekair is offline   Reply With Quote
Old 10-31-2002, 07:22 PM   #2782
robk's Avatar
Trader Rating: 22 (100%+)
Trinityracenut: I would second Kevin K's advice. Where is your car set for droop now? You need VERY little if the track has any traction.
Old 10-31-2002, 07:25 PM   #2783
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
U guys running the new blue IRS outdrives, with the IRS black plastic schumacher blade type protectors on the cvd?
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 10-31-2002, 08:05 PM   #2784
D_Ames's Avatar
Send a message via AIM to D_Ames
Tony,
How's the new job?? Do you still have the same e-mail address?
Going to So Cal Saturday if your interested.
D_Ames is offline   Reply With Quote
Old 10-31-2002, 09:09 PM   #2785
TPhalen's Avatar
shrekair: My site has blank and other pro setups. Give it a look.
'Sup Dave???? No, different e-mail. I'll PM it to ya.... New job rules....we'll have to get together and talk!!!!
And, already have plans for saturday. Sorry.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 10-31-2002, 09:11 PM   #2786
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
LOCKED DIFF
I'm new to TC3 but it already gave me the 1st place to B-Main & am so proud even as a stock TC3.
Now i wonder, how the locked diff worked...i mean how to do it, as Barry front setup did? Is it just fully locked(turned) diff, meaning both tires going same way when turned? help me.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 10-31-2002, 10:02 PM   #2787
shrekair's Avatar
tony - i'm looking for the editable one though. u can actually type right on it and click the boxes
Old 10-31-2002, 10:46 PM   #2788
TPhalen's Avatar
Ah. Might be hard pressed to find one. Most of them out there are all gonna be .pdf files.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 10-31-2002, 11:48 PM   #2789
johnbull's Avatar
Try going on the cmldistribution site for a blank set up sheet you can print out.
I'm afraid i don't know their exact web address but if you go on links in www.brca.org you should find them.
Good luck.
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 11-01-2002, 04:43 AM   #2790
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Thanx guys i will look into the droop thing but i have always run droop. it helps the car load in the corners and make it easier to drive but with foam i dont think i need it lol. So if im at 5.5 and 4.5 do i go higher on the numbers? thanx kevin
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
