Old 10-28-2002, 05:56 PM   #2746
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
It's also 25 bucks plus shipping! Ouch!
As we said a few pages back (yeah, I know, a LOT of pages in this thread) just pull the diff balls, space the "nut" side a bit (to keep the little white t-nut thing from breaking) and then tighten it down all the way. costs nothing, if you put the balls back in, you are back to a normal diff. . .use a little locktite on the nut if you want to keep it permanently locked (I have one dedicated that way).
Personally, I think that's better than spending extra dinero on one.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 10-28-2002, 06:23 PM   #2747
TRL
Default Losi rear hubs
Hi guys a few questions about the losi hubs when running them on at tc3!
1.Are they a direct fit or do you have to make a new hole for the tie rod?
2.I was reading that cyrul runs them but has them on backwards,any idea why?
3.Basically running them to get 1 degree or 1/2 degree toe-in depending which hubs you have on..any other advantages?
thnks
TRL is offline   Reply With Quote
Old 10-28-2002, 06:35 PM   #2748
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Im looking for mores teerin into the corner with the mod foam car. I will try the solid front axle this weekend. I will let u know how it works out.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 10-28-2002, 08:05 PM   #2749
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Trl,
1. Yes they are a direct fit.
2. He runs them so he can run less toe-out in the rear. I am sure there is another reason but that is the main one. I am not sure what the difference in roll center adjustment is though if any.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-28-2002, 08:05 PM   #2750
TRL: If you follow Cyril's set ups for his TC3. You need to see what all josh does to his car and why.
1) He replaces the "R Block" with a "F block" in the rear.
Plus he adds the R+2-0 block.
Basically it takes all the toe angle out of the arms.
2) Then josh uses the losi hubs to put what ever degree of toe he wants back in.
On carpet w/ foams, you only need about 1 to 2 degrees for stock class.
One other thing I noticed about his set ups.
Josh removes about .030 off the top of the hub carriers.
It clears the wheels and keeps the camber link level.
That's all I can add for now.
I know there are other forums in which you can get some good info for TC3's and anyone racing the Cleveland Indoor Champs.
Hope this helps.
Tracy
doorman is offline   Reply With Quote
Old 10-28-2002, 08:10 PM   #2751
Super Moderator
Kraig's Avatar
Trl,
Old 10-29-2002, 08:29 AM   #2752
TRL
Thanks for the help guys!!
doorman are you sure its the 2+0 block and not the 3+0 block..thought i read 3+0???
The only thing i'am still confused on is why backwards sometimes does running 1 degree hubs on backwards give you something other then 1 degree toe?
thks again
Old 10-29-2002, 09:15 AM   #2753
TRL, What I did was to take the "F- block" and match it with what ever rear block that lined up both sets of holes so they were parallel. (sp-?) I know Josh is always trying different stuff with his car. Josh did mention that he used a R+3-0 block.
Try it and see how it lines up.
As for the Losi hubs, if you install it the way they suggest, you will get the added toe in. If you mount them backwards, they take out that amount. The holes are drilled at an angle.
Hope this helps.
Tracy
Old 10-30-2002, 12:34 PM   #2754
gator's Avatar
Default rear diff ????
ok. i am needing a rear diff, and i am woundering . if i should just get the light weight diff kit , or solid rear axle, or what should i do ? i run cvd's aluminum.. thanks for the help. and info...
gator is offline   Reply With Quote
Old 10-30-2002, 12:40 PM   #2755
Corse-R's Avatar
Default Re: rear diff ????
The solid axle of the NTC3 cannot fit on the TC3 (a simple matter of width of the outdrives). In this case, the answer is straight, get a lightweight (plastic diff), no matter you run (stock or mod) the plastic outdrives withstand anything you bolt on your TC3 (well... for sure cannot whitstand a 14 cell 6 turn mod, FYI ).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 10-30-2002, 12:58 PM   #2756
solid diffs
I was wondering if anyone can tell if a solid diff is good for foam tires on carpet.
al jones is offline   Reply With Quote
Old 10-30-2002, 04:30 PM   #2757
gator's Avatar
Default Re: Re: rear diff ????
thanks , i appreciate the help. i am going to get the light diff kit then...
Old 10-31-2002, 04:36 AM   #2758
hey guys went to drop in one of my extra diffs and the bearings would not sit down in the seats in the chassis. the bearings are spaced outward to far. i measured my extradiff that i was putting in and it was about .020" longer, so theres the reason but im not sure why its longer. also on this diff the ring gear can spin when both out drives are held. i have no clue whats wrong with this diff. i was up late trying new balls, rings, outdrives and have no clue about either of these 2 problems. any help world be appreciated.thanks
Jarrod Langlois is offline   Reply With Quote
Old 10-31-2002, 05:11 AM   #2759
redsand's Avatar
Send a message via Yahoo to redsand
doesn't a solid axle only work best with foam tires ?
redsand is offline   Reply With Quote
Old 10-31-2002, 06:08 AM   #2760
theisgroup's Avatar
Default spaz456
check the bearings inside the diff. there are 2 different bearing sets. The ones for the steel diff are a little wider. that will keep the diff from being put together right.
theisgroup is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
