Old 10-14-2002, 12:17 AM   #2671
johnbull's Avatar
Hi Guys. Greetings from Malta.
We started our Nats yesterday, with TC3s well and truely showing the way.
In mod my son Josh took the win, with another two TC3s in second and third.
In stock I got beat into 2nd place by a TC3.
Tony. In terms of touring cars I really don't think Associated need do much more than just keep improving the TC3. It's so good . It's winning everywhere, and people are now starting to copy it.
Perhaps triangulating the top suspension arms front and rear, like the IC cars would be a good idea to keep things from flexing so much, and stronger rear hubs, which are the car's weak point.
I have put some alloy rear hubs on my son's car, just to be safe. I have also triangulated the top front arms. Yet despite these mods the car still needed quite a bit of ballast to bring it up to the regulation weight limit.
We race again this coming Sunday.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 10-14-2002, 09:12 PM   #2672
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Hi Everyone, just wanted to let you know that we have received our order of Titanium Screw Kits and Ball studs for the TC3.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-16-2002, 07:35 PM   #2673
theisgroup's Avatar
Default rear shock tower in front.
We finally got the updated front a-arms. And I am trying to setup my tc3 with the rear towers in front and the new arms. i have not been able to set the ride height below about 6mm. What could I be doing wrong?
thanks for the help
theisgroup is offline   Reply With Quote
Old 10-16-2002, 07:47 PM   #2674
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Did you shim the rear shock tower when putting it up front???
That could be it...
TigeRyan is offline   Reply With Quote
Old 10-16-2002, 07:51 PM   #2675
theisgroup's Avatar
Default rear shock tower up front
no, did not shim. thought if I used the new arms woudl not have to change the roll center.
Old 10-16-2002, 07:53 PM   #2676
Peter Busch's Avatar
Is there any advantage to running the Losi rear hubs?
Peter Busch is offline   Reply With Quote
Old 10-16-2002, 08:11 PM   #2677
metro it gives you more camber adj!
onroad dude is offline   Reply With Quote
Old 10-16-2002, 10:19 PM   #2678
TPhalen's Avatar
theisgroup: Mount the shocks in the outer hole on the arm. This should allow you to lower the car.
Shimming the shock tower would work, but you are correct. You will raise the roll center.
spongebob: Running the Losi rear hubs also allows you to make minor toe-in adjustments. I think, if I'm not mistaken, you can make 1/2 degree increments.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 10-17-2002, 04:06 AM   #2679
Ok thanks
Old 10-17-2002, 06:58 AM   #2680
JLMG1971's Avatar
Default Overweighted TC3 Racer
Hi
My racer kit is always overweighted, the lowest I could get it to is 1550gr. I have Ti turnbuckles, Ti Hingepins, light front and rear diff outdrives, I use a Cyclone TC and a XXL rceiver, and a Hitec 605, and as batts 2400s and 3000s. I know that the 2400s are a little heavier than the 3000s but still the car is heavy. I took of the heat sink clip and the RPM bumper. I was wondering about buying a whole graphite kit to install in my racer, does anyone know how much weight would I be able to save with the AE graphite kit?
Jorge
JLMG1971 is offline   Reply With Quote
Old 10-17-2002, 06:59 AM   #2681
TPhalen's Avatar
The TC3, out of the box, should be underweight. Not sure why yours isn't. What wheels, tires and inserts are you using??? That sometimes makes a BIG difference...
Tony Phalen
RCDriver.com
CompetitionX.com
Old 10-17-2002, 07:28 AM   #2682
JLMG1971's Avatar
I am using Take-off Cs-22 which come with inserts and speedmind wheels, btw the body is a stratus protoform and I try to go really skim with the paint
Old 10-17-2002, 07:40 AM   #2683
theisgroup's Avatar
Default ride height.
Hey Tony,
Congrate on the new job.
I have the shock mounted on the outer hole of the tower and the outer hole of the arm. Am still at about 6 mm. I have also noticed that when I have the shock on the outer hole of the new arm, the spring seems to rest on the C-hubs.
Old 10-17-2002, 08:33 AM   #2684
johnbull's Avatar
Hi guys. Greetings from Malta.
TONY. Jorge's TC3 is th Racer kit. It is usually above the 1500 gram weight limit.
You are right about the graphite ones, the Team and FT. They are usually way under.
So Yes Jorge, go for the graphite kit, then you'll be under too.
The Take Off moulded inserts are fairly heavy, but they do work well.
Regards
Old 10-17-2002, 07:39 PM   #2685
Send a message via ICQ to RCDan-O Send a message via AIM to RCDan-O
Im looking for information. I know associated sells two kinds or more of TC3's. There is a TC3 plain and a TC3 version with all the Hop-ups from the factory. What is the name of that version if I wanted to buy it? Is it the team car?
Dan
RCDan-O is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
