Like Tree4Likes
Old 10-08-2002, 01:18 PM   #2626
big al's Avatar
hey Trinityracinnut--Shoot me that setup or post here. Thanks in advance--Al [email protected]
So are you guys saying that now we should use losi knuckles as well as the rear tower up front?? We're gonna have frankenstein cars pretty soon.
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 10-08-2002, 05:31 PM   #2627
psycho's Avatar
TPhalen
Hmmm... ok, thanks. I have a XXX-S, so it will be easy for me to test this out. Thanks for the explaination.
psycho is offline   Reply With Quote
Old 10-08-2002, 07:56 PM   #2628
hobbipro's Avatar
Trader Rating: 21 (100%+)
Another great thing to use with the XXX-S knuckles, is the use of Exponential on a computer radio, you can use end point adjustment to set your maximum throw on the TC3 ( till the steering rack just barely hits left/right) then use negative Expo say -20%- 50% to de-tune the amount of steering throw during the initial turning of the steering wheel. That way if you do need maximum throw its there to use, just means you have to turn the steering wheel more........it actually wont limit the servo's throw, just the amount it travels versus wheel movement.
hobbipro is offline   Reply With Quote
Old 10-08-2002, 08:21 PM   #2629
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
I have to use a certain amount of neg-exp because when I do well I start to shake. . .it's actually quite comical. If I'm in the lead, about the only things that aren't shaking are my head and my left hand. . .
I'm not so bad now, and, for some reason, I don't shake at all when I'm driving Nitro - must be the fumes!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 10-08-2002, 08:38 PM   #2630
gator's Avatar
Default re:
why doesn't associated put pivot ball on the elect. tc3 or do they already have the option to do so ?
gator is offline   Reply With Quote
Old 10-08-2002, 10:31 PM   #2631
Craig's Avatar
Send a message via AIM to Craig
There is no need for pivot balls on a electric tc.
Craig is offline   Reply With Quote
Old 10-09-2002, 05:37 AM   #2632
Default tc3tuning guide
can somebody say where i can download the tuning guid or if some body can sent it to me .mij email is [email protected]
asenna is offline   Reply With Quote
Old 10-09-2002, 06:56 AM   #2633
redsand's Avatar
Send a message via Yahoo to redsand
I'd rather tune the chassis and let the radio settings 100% linear.
I would use the radio to tune the car as a last minute resort, though.
redsand is offline   Reply With Quote
Old 10-09-2002, 08:06 AM   #2634
Jack Smash's Avatar
Trader Rating: 29 (100%+)
gator: its proably the same reason that X-ray now offers a conversion to get rid of the pivot ball.
Jack Smash is offline   Reply With Quote
Old 10-09-2002, 12:04 PM   #2635
Aluma's Avatar
hi guys, i just got a tc3.... have any of you tried the rally conversion on it? is it worth the price? Can it be used as an "offroad" 4wd buggy? Can it handle the big jumps?
Aluma is offline   Reply With Quote
Old 10-09-2002, 01:21 PM   #2636
Angry factory team bearings
Hello everybody I am new to the forum I race over in england
and have only one complaint about the car the factory team bearings are rubbish they have only lasted me 6 months even though I only race indoors they became gritty and one even slit down the middle and b4 u ask I am not a wall banger.
Has anybody else had this problem ????...
does anybody else race in england if so where so we can compare setups
ASSOCIATED is offline   Reply With Quote
Old 10-09-2002, 01:38 PM   #2637
Regional Moderator
Send a message via AIM to Mike F
Which bearings are you refering too? I have the FTTC3 and the only problem I had with the bearings was self induced. I took the seals off the front/rear hub carriers, not a good move. I replaced them with the rubber sealed bearings and haven't had any trouble with them. I do clean them out every other race just to make sure they still flow freely. I also took the seals off the diff bearings and they are still working great for me.
Mike F is offline   Reply With Quote
Old 10-09-2002, 01:56 PM   #2638
Boomer's Avatar
Me as well - I ran, for a time, with no seals and had to do a LOT of maintenance constantly.
I got a new set of the stock AE bearings and have just cleaned them every week (just sprayed and a drop of lube) - the wheel bearings, not the diff ones - and they've been really good. I haven't done much at all to the diff bearings - just cleaned them any time I have reworked the diff (not often. . .) and they've been great.
Are you running outdoors in any kind of dusty environment? If you are, then you will have to do more maintenance. 6 months does not sound like an unreasonable amount of time. I usually replace mine about twice a year. . .They are moving parts and will wear out and do require maintenance. . .
Old 10-10-2002, 04:30 PM   #2639
After working on my new FT TC3, I have noticed that there is quite a bit of binding between the diff gear and gear that connects the long shaft. Can spare some knowlledge on how to get bind free gears.
I have also noticed that the swaybars pop out of the mounts quite easily. The screws seem quite small to hold it in and there is quite a bit of play aswell. Any help with this would also be greatly appreciated.
Thanks.
rcpilot is offline   Reply With Quote
Old 10-10-2002, 05:59 PM   #2640
Trader Rating: 67 (100%+)
a small washer prevents the swaybar from slipping out of the allen screw head. you may have to grind one side a bit to clear the side of the gearbox cover.
marvi is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
