Old 10-01-2002, 05:22 PM   #2581
psycho's Avatar
I'm sure this has been answered a million times already, but I don't feel like searching through thousands of previous posts...
What is the largest 64 pitch spurgear that will fit the TC3 without having to chop up the chassis or poking through the bottom?
psycho is offline   Reply With Quote
Old 10-01-2002, 08:55 PM   #2582
Smile
I would depend on the class that you run. Stock 96 mod 104
rangulo is offline   Reply With Quote
Old 10-01-2002, 08:59 PM   #2583
Smile
Foam tire set ups....
Where on the internet do people post setups for foam tires other than associateds web site. I really would like to use other resources.
Old 10-01-2002, 11:22 PM   #2584
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Rang - www.competitionx.com has a lot of good setups, including foam carpet. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 10-01-2002, 11:58 PM   #2585
johnbull's Avatar
Psycho.
I run a 90 to 94 on my son's TC3 for modified.
Those sort of sizes allow for quite a variation of pinions.
Regards,
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 10-02-2002, 07:44 AM   #2586
redsand's Avatar
Send a message via Yahoo to redsand
Why would anyone run a 64 instead of the stock 48 ?
redsand is offline   Reply With Quote
Old 10-02-2002, 07:58 AM   #2587
64 pitch would allow for smaller increment changes in the final drive. In 48 pitch pinion changes can be very large. 7 7.2 7.5 are 48 pitch changes where you would be able to go in between these with 64. Smaller teeth equals smaller more precise gearing. 64 pitch is not good for newbies, you can strip the gears more easily.
Old 10-02-2002, 08:52 AM   #2588
Personally, I run 32 pitch on my TC3...
Modena AL is offline   Reply With Quote
Old 10-02-2002, 10:08 AM   #2589
psycho's Avatar
Thanks guys. I was mainly interested in what the largest size that will physically fit into the chassis so I'm not guessing. I am running mod. I run on prepared asphalt and carpet, so I'm not worried about stripping gears out. I was looking for the fine gear ratio increment change that rangulo is talking about. 32 pitch? Man! I thought the car was noisy with 48 pitch!
Old 10-02-2002, 10:34 AM   #2590
Modena your car must sound like a vaccum cleaner. VOOOOOOOOOOOOOMMMMMMMM.... LOL
Old 10-02-2002, 06:55 PM   #2591
Super Moderator
Grizzbob's Avatar
Psycho, I am certain that a 104 tooth spur will fit(I use them on my mod class TC3), it looks to me like a 108 MIGHT fit(but I haven't tried it yet, so I'm not sure), but I'm sure it would slightly limit how big a pinion you could run with it.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 10-02-2002, 11:36 PM   #2592
TPhalen's Avatar
Wow. Been awhile since I've been on here!!!!!
I've also run a 104 on my car. 108 might prove interested in cornering....just run the car a little low and it'll turn ON the 108 spur sticking out the bottom!!!!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 10-02-2002, 11:51 PM   #2593
redsand's Avatar
With a metal spur also ?
Old 10-03-2002, 07:14 AM   #2594
TPhalen's Avatar
Metal AND 32p. Whew. And I though Tamiya's were loud....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 10-03-2002, 09:22 AM   #2595
psycho's Avatar
Thanks again, guys. I'll head to my lhs and pick up a 104T. It will be nice to have a few more gearing choices.
Another question... I bought a rear shock tower for the front, but I find that it doesn't fit the shocks very well. If I change the position on the shock tower, it adds compression on the springs. I'm running Mugen threaded body shocks, but I measured them when I built them and made sure they were the same length as the Associated shocks. Any good fix for this? I was thinking about making the ball connector thingies (the part that screws onto the shock shaft) shorter, but I suspect it will be a pita to get them all the same length. What are you guys doing? I assume you are running the rear shock tower up front, since the car handles much better that way. (imo)
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
