Old 09-03-2002, 08:20 PM   #2431
Fred Hubbard's Avatar
Hey Chad,
How's it going buddy? How's the weather in CO.
Fred Hubbard
Fred Hubbard is offline   Reply With Quote
Old 09-03-2002, 11:28 PM   #2432
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
V12 - you DON'T need the new arms. You can use the regular arms. I am doing so and have been running the Locked Front setup for a while now.
rcpainter - interesting idea. I just didn't put the balls in and it locked fine. . .did you find that you needed the eraser? Mine is totally locked without them.
fred - actually, we are trying to INCREASE friction, not decrease it. If we decreased friction, it would allow the ring gear to slip which would defeat the purpose - methinks you got switched up!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 09-03-2002, 11:51 PM   #2433
Boomer, acutally, this is something that was told to me from a PRO driver. Unless you want to run your ride hide above 5mm, it is best to invest in the new arms.
Fred Hubbard
Old 09-04-2002, 12:04 AM   #2434
If you space the rear shock mount up by 2mm, you can achieve a ride height down to 4.3mm.
Have been running two TC3's for 3 weeks now setup like this.
acloco is offline   Reply With Quote
Old 09-04-2002, 01:07 AM   #2435
johnbull's Avatar
Hi guys. Greetings from Malta.
The TC3, now in it's 3rd year, still almost exactly as it started off, and copied by many, still seems to be the car to have.
In the last 6 weeks almost every race of any importance, anywhere in the world, has been won by a TC3.
The latest in the series of wins occurred at Snetterton in England last Sunday.
In the penultimate round of the British championship TC3s scored wins in both stock and modified, and with still one round to go have clinched both championships, despite stiff opposition from almost every other manufacturer.
Cliff Lett deserves a doctorate.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 09-04-2002, 07:44 AM   #2436
TPhalen's Avatar
Hahahha...here we go again.
Do realize that you DON'T need the new front arms....if you choose NOT to use them, you CANNOT get the ride below 5mm....
unless....
....you shim up the shock tower. While this is an easy fix, it also changes the camber link location on the tower. You will lose the lower tower location (as shimming the tower UP will, in essence, move the camber link up also). You also make the tower a little more vulnerable in a crash. The screws need to be longer and since they aren't really attaching the tower to the bulkhead, you MIGHT encounter problems.
It's a better choice to just buy the arms. They are cheap and they are a running change so ALL the arms from now on will be with the new holes (for either tower).
I have a buddy making a spool for me (should be done soon) and I can't wait to try it. Not sure if a locked diff or the spool will be better....
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 09-04-2002, 08:13 AM   #2437
TP: I'm glad someone else finds this funny as well. Isn't life grand?!? It's always interesting to see all the different answers to a question. I love this game...
Fred Hubbard
Old 09-04-2002, 09:07 AM   #2438
johnbull's Avatar
Someone is clearly doing something wrong.
I built son's TC3 up with the rear tower up front.
I didn't space it.
I use standard TC3 shocks without any rebound washers.
On full compression the car bottoms before the shocks do.
And I still have the old type, single hole arms, since the new ones haven't arrived yet.
So what am I doing wrong, to still have all the travel I want!
I have the front ride height set at about 5mm.
Interesting.
Regards
Old 09-04-2002, 09:41 AM   #2439
Just trim the shock eyelet down a few millimeters. The spring retension cup will now be able to slide farther down eyelet and you can get 3mm ride height if desired.
Many of us have been running the rear tower up front on carpet w/ foams for about 9 months now. Nobody has had a problem since trimming down the neck of the eyelet. The setup works very well.
bshields is offline   Reply With Quote
Old 09-04-2002, 09:50 AM   #2440
Boomer's Avatar
Yep, more or less!
I didn't want to shim the tower - I was afraid of weakening things. . .
But I'm running 4.5mm RH at the front and I am using the old arms. I could go lower, far lower. Anything's possible!
Old 09-04-2002, 10:47 AM   #2441
TPhalen's Avatar
Fred.....ahhahaha you enjoy this too???? Good to know, though, that there are MANY different thoughts about things....
johnbull: question. Can you LOWER the ride height below 5mm???? I'm pretty sure you can't. And that's the problem. On really high-bite tracks (like our SoCal Raceway...or even carpet), anything ABOVE 4 - 4.5 is too high. And you can't lower the front ride height below 5mm.
I heard of guys cutting the eyelets....I don't like doing anything that jeopardizes the durability of the car....especially the front of it!!!!! Sometimes I like to crash....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 09-04-2002, 02:41 PM   #2442
robk's Avatar
Trader Rating: 22 (100%+)
I put header paper in the diff and ran it. Everything was fne during the run, and it did get off the corner nice.
I also tried cutting down rulon pegs from the Traxxas slipper. It's easy to do as far as making them fit the hole, but they were too long. This made the diff halves not true to each other. When i comprssed the diff (tightened) it, the pegs got kinda squashed and deformed. Probably if you cut them to a shorter length before hand, everything would work out.
...And i also ran with a locked diff using all the stock components on carpet with foams. The car was just super well behaved and even drove right thru corner dots like a MUVVV! I hate corner dots so this is good. It just needed steering, and I suspected it would need to have the front end softened. Just wanted to test w/ a regular, known setup so I'd have a baseline. I'm not sure how much extra rip off the corner it got, since it was foam stock, but when I tried the car out side on rubber it was readily apparent.
to the foam guys w/ the spool: lemme know if you come up with something you like. I'm going to try equal oil, pistons, and Purple and red springs.
Old 09-04-2002, 03:37 PM   #2443
Boomer i tried it with the diff-balls but couldn't get it locked, the eraser works just fine it is and will stay locked
rcpainter is offline   Reply With Quote
Old 09-04-2002, 04:54 PM   #2444
Boomer's Avatar
yeah, I tried with them too, and it was fairly cool, but not locked.
I just took them out and tightened it down. that worked well for me, but then I'm obviously fairly wierd!
Old 09-04-2002, 05:00 PM   #2445
TRL
Hi guys
what does everyone mean buy a spool?
TRL is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
