Old 09-01-2002, 06:44 PM   #2401
Peter Busch's Avatar
R/C Tech Charter Subscriber
How do you get the bearings out without ruining them?
Peter Busch is offline   Reply With Quote
Old 09-01-2002, 08:14 PM   #2402
Default Med grip asphault set up
I am building a ft tc3 this coming week and I need a good starting setup for stock with a one way or locked diff, rubber tire, med grip smooth asphault. Any help would be most appreciated. Art
Art Jensen is offline   Reply With Quote
Old 09-01-2002, 08:19 PM   #2403
Default Freeing up tc3
Also, what is everyone doing to free up the drivetrain besides the usual grease removal from the bearings and massaging the tranny cases. I want to hit the ground running this weekend. Thanks again, Art
Old 09-01-2002, 08:38 PM   #2404
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
johnbull: i used the protoform stratus 2.0 last saturday at our weekly club race. i liked it a lot! it has just a tad less rear traction due to probably (im just guessing here coz i aint no aeordynamics expert) the narrower rear wing. also the rear fender is cut slightly lower than the original stratus thus may be a cause for a bit more rear lift. to be honest i was expecting the body to have a much looser rear end but to my surprise when i put it on, the car felt perfect. Maybe this is a good complement to the locked diff set-up. lemme know what you think of it when you try it out. overall its still a stable/fairly neutral body shell that we've become used to as with the original stratus.
ps. i was using the original stratus prior to last saturday's race so thats the basis of my comparison.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 09-01-2002, 08:39 PM   #2405
Fred Hubbard's Avatar
Art: For a good one-way setup start with the Worlds setup, which is the one listed in the instruction manual. For a good locked-diff setup start with Barry Baker's Reedy Race/ROAR On-Road Nationals setup. You will need to download the latter from AE's website. You'll need either Adobe Acrobat installed or some other type of app that can read PDF's.
Fred Hubbard
Fred Hubbard is offline   Reply With Quote
Old 09-01-2002, 08:47 PM   #2406
ROBORAT's Avatar
MUFFIN: the Reedy Race set-up of barry baker should be a good starting point. with regards to freeing up the drivetrain, i picked this up from josh cyrul at trinity tech talk --- try playing around with the shimming of the the diffs and input shafts. find the most free moving mesh by shimming the diff gears left to right and the input shafts front to back. i still use the same number of shims in the gear boxes but my input shaft in front is moved slightly back (just enuff that it dosent jam the input drive into the shaft). also, be sure you dont over tighten the bearing holder located near the spur gear. hope that helps.
Old 09-01-2002, 10:02 PM   #2407
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Muffin,
TonyP has good setups for all variations on CompetitionX. Any more, it's the first place I go for setups. I have found that they are more current than AE's site.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 09-01-2002, 11:55 PM   #2408
Spongebob,
The one-way unit is hollow throughout and all of the bearings are pressed into it on the ends. I took a flat-headed piece of metal that was slightly smaller than the inner diameter of the one-way, but would press evenly on the outside portion of the bearings, and put the one-way on top of a vice and slowly tapped them out. To put the bearings back in, I simply used the vice to press them into place as you only put the two in each end, snug together. I'm actually going to visit one of the industrial bearing vendors in my area, like Precision Industries or Motion Industries, to see if they sell a similar sized one-way bearing but for heavier applications. Then I could feel more confident in the bearings holding the power of the lower wind modifieds since the bearings will no longer be doubled up in the same direction in the one-way.
Greg
Greg Anderson is offline   Reply With Quote
Old 09-02-2002, 05:37 AM   #2409
johnbull's Avatar
Hi guys. Greetings from Malta.
Firstly thank you all for your help.
One question that has not been answered is this.
Would it be too risky to use the plastic diffs with a locked up front unit. There is going to be a hell of a load on them.
When I tried a locked plastic diff on the rear it didn't do half a dozen laps before breaking. I would imagine the front is going to have even more load.
I hope to try the locked diff arrangement this evening. Will let you know the outcome.
regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 09-02-2002, 07:56 AM   #2410
Default tips
Thanks alot guys. That helps alot. I will let you know how it turns out after this weekend. Art
Old 09-02-2002, 09:07 AM   #2411
Default rotating mass
looking for ideas on lowering the rotating weight in my tc3
for quiker throtle response
redneck is offline   Reply With Quote
Old 09-02-2002, 09:38 AM   #2412
Dingus's Avatar
Isn't the TC3 already one of the quickest out of the gate!?!
I guess you could get the composite CVD's and lightened outdrives if you don't already have them.
Maybe an aluminum shaft? I would think most of the rotating mass is in the wheels/tires/inserts.
Maybe an aluminum spur carrier thingy?
I ran the locked diff this weekend for the first time on asphault. Awesome out of the corners.
I ran it with the center one way (forgot to bring the diff) and it ran awesome. I think the locked diff helps with acceleration. Coule easily shoot past the Missions and Losi's in the corners!
I ran the Juho guys Euro Champ setup for med grip bumpy asphault. Found at http://home.swipnet.se/airwide/ Awesome! I was a little concerned with the odd droop settings, but it worked.
Dingus is offline   Reply With Quote
Old 09-02-2002, 12:41 PM   #2413
Send a message via AIM to UrbanCowboy Send a message via Yahoo to UrbanCowboy
Default Low Turn Motors
I was looking to get an 8 turn motor to use when messing around. However, I am concerned about overheating the motors and/or EVX. I live in CO and would generally be running in 80-90 degree weather. Should I be concerned? What options do I have to help keep it cool? Maybe I shouldn't go as low as 8 turns? Comments are appreciated
UrbanCowboy is offline   Reply With Quote
Old 09-02-2002, 12:44 PM   #2414
you can you the heat sink to keep the heat down and a heat sink on your speedo. If your speedo can handle it go for it
teamAE is offline   Reply With Quote
Old 09-02-2002, 05:51 PM   #2415
robk's Avatar
Trader Rating: 22 (100%+)
John bull-
From what i heard Hara was using TC3 plastic diff parts in his HPI prototype at the Reedy USA. He was also supposed to be blowing out diffs with regularity. Maybe Tony Phalen can comment on this.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
