Old 08-22-2002, 10:35 AM   #2341
TPhalen's Avatar
R/C Tech Charter Subscriber
One-Way in the rear. Tried it. Pushes going in and spins coming out. Don't waste your time....
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 08-22-2002, 11:16 AM   #2342
RAP66's Avatar
It's possible that you m,ay have the screws too tight, causing the spur to distort, try loosening the screws a bit and see what that does.
Rich
Originally posted by spongebob
The kimbro's all seem to have a high spot on them so one side of the mesh is pretty tight and the other side is a little loose.
Rich Pedro
rap66@rcracing.com
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 08-22-2002, 07:12 PM   #2343
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
I've found the same thing - Kimbroughs (which are molded) seem to mesh differently on different sides of the gear.
I'm using Robinson machines delrin gears.
Robinson Racing has some and there is someone else, I will look on Saturday. I can't remember the brand off-hand.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 08-22-2002, 09:36 PM   #2344
I agree kimbrough are too soft for my liking, i like ither the robinson machined delrin range or there is a UK based company called RW Racing who make extremely nice pinion and spurs
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-23-2002, 06:48 AM   #2345
TigeRyan's Avatar
Send a message via AIM to TigeRyan
Good Morning Everyone...
Tried to locked diff upfront, but without the rear shock tower up front....all I have to say is PUSH PUSH PUSH, and a little more PUSH...
I am going to put the front shock tower up front, the question I have is what camber link position, shock tower position, and what tow-in and camber should I be running with this, also any spring and shock oil suggestions would be appreciated...
The car was faster on the straight then anyone I was running with, but I couldn't turn the darn thing without slowing to a crawl, which lost me any advantage I had gained...
I am running Sunday at a parking lot track, fairly bumpy...if that will make any major differences...
FYI: I am running Tony's Bumpy Setup right now...
Thanks!
John
TigeRyan is offline   Reply With Quote
Old 08-23-2002, 08:08 AM   #2346
TPhalen's Avatar
FYI: Just putting the rear tower on the front and throwing in a diff WILL NOT make your car have great steering and consistency. You will most likely need to do some major setup changes to get it to work. But when you do, the car will have changed so dramatically that you will think it's a totally new car.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 08-23-2002, 08:17 AM   #2347
TigeRyan's Avatar
Tony,
I had figured on making major changes, so yesterday I had a demonstration at a block party so I decided to try it and see where I was at as a starting point...thus finding out that I had major push...so now I start the process of finding more turn-in...I don't mind working for my setup, took me almost 6 months to get my pro3 right, but now it is real nice...The TC3 has just been a bit more stubborn....
I have a second TC3 that will probably be run this weekend, but I would like to further make changes to the car I tried yesterday and continue improving it.
I realize there is no "Wonder Change" to make a car fast...
Old 08-23-2002, 11:33 AM   #2348
has anyone tried the locked diff with the rear tower on carpet with foams yet? i am interested in this cuz our indoor season will be starting in a few months time and was wondering if anyone has tried it yet. thanks.
rybeyak is offline   Reply With Quote
Old 08-23-2002, 11:58 AM   #2349
Boomer's Avatar
Originally posted by TigeRyan
Tony,
There isn't a "wonder change" but there is a good setup that works quite well for a starting point. . . On Tony's site there is Barry's Reedy Race setup which used a locked front diff. I started there and made small progressive changes and it works great. Makes a great starting point.
Old 08-24-2002, 03:23 AM   #2350
V12
V12's Avatar
What are the changes from Barry's Reedy Race setup?
V12 is offline   Reply With Quote
Old 08-24-2002, 09:47 AM   #2351
lem2's Avatar
Default Help!!
Hello People!!!!
My name is Lem from Manila, Philippines!!!
I recently Purchased a Factory Team TC3.
Hope you guys will not be pissed with my "ignoramous" and numerous questions as I hone my skills on this Car!
So--any building tips??
Thanks!
lem2 is offline   Reply With Quote
Old 08-24-2002, 09:59 AM   #2352
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
Welcome to the board Lem2......Take your time when building......Follow the instructions...read this thread everyday...go race...have fun.
Dragon Slayer is offline   Reply With Quote
Old 08-24-2002, 03:38 PM   #2353
Super Moderator
Grizzbob's Avatar
Yup, there are no stupid questions, just stupid people(mostly stupid people giving bad answers)....and for tips I'd just follow the direction faithfully, Associated really did their homework on it, & it shows. Just take your time to get everything right, & enjoy the build....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 08-25-2002, 08:09 AM   #2354
I have the said setup and I can say from all the setup I have tried for the tc3 this is the best for carpet!!!
you can drive so aggresively and still be on rails!
dont know yet about outdoor.
Im now modifying a solid diff from nttc3 to fit the fttc3
so no more diff rings and diff balls to lock and snap!
Super38 is offline   Reply With Quote
Old 08-25-2002, 01:27 PM   #2355
Boomer's Avatar
I took an old diff and removed the balls and spaced out the "nut" side a bit and just tightened it down. didn't damage anything and I have a locked diff that I can put some balls back in and make it normal again.
We ran my TC3 last night with dual one-ways in it. Just a bit more aggressive than with the single one-way. It worked very very well.
It's not as tolerant as the solid front, so if I run it I'm going to use the locked front. but if Anton is going to run it, he'll run the dually.
I am going to try, just for kicks, the middle one-way and locked front diff. . .just to see what happens.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
