Old 08-21-2002, 08:14 AM   #2326
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Tony,
as always thanks for the great information....what am I looking for specifically on the new arms, as I have gotten bitten a couple of times at my LHS buying parts that were not the latest revision...
Thanks,
John
PS. with the info provided here I have improved to making A-Main's this outdoor season, which is a considerable improvements from my B-Main speed bumb appearances, or the C-Main win....Thanks!!!
TigeRyan is offline   Reply With Quote
Old 08-21-2002, 09:49 AM   #2327
Default locked diffs
need help in locking my steel diffs...............how and where to drill........any other options? is this good for stock racing?
max428 is offline   Reply With Quote
Old 08-21-2002, 11:46 AM   #2328
Corse-R's Avatar
Originally posted by TigeRyan
Just blew out my old Airtronics servo this weekend in my TC3 and since I need to replace it I want to get a servo that will serve me well and was wondering what some of you run, I prefer Futaba (never blown one out, knock on wood!) but would listen to other suggestions...
Without any doubt about them. Futaba 9450's are one of the best servos you can bolt to your mean machine. KO Fet servos are quite good, but stay away from those nasty PS7xx series servos, get a PS2xxx series servo and can be almost indestructible too.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-21-2002, 11:55 AM   #2329
big al's Avatar
Hey tigeryan-- I've been using my trusty airtronics 258 for about 2 years now and it still rocks!! Which ever serco you buy, make sure it has metal gears(durability) ang dual ball bearings. Generally a tourquey servo will have good centering characteristics, which if you've ever noticed on heap servos you have to counter steer to get the car to track straight when leaving a turn.
Whan I installed the rear tower up front, I just took off about 3mm of plastic off of the lower ball cup (about 3 threads exposed on the shaft). I can now easily get 3mm ride height if I wanted. It's the cheapest and most practical way to get the job done! Hope this helps--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 08-21-2002, 02:20 PM   #2330
Regional Moderator
Send a message via AIM to Mike F
Default Spur Gears
I'm hearing different things about what spur gears to use, in any kit not just a TC3.
From what I heard on another thread, 64 pitch spur gears are the way to go to be more competitive. 88 for stock racing and 100 for mod. I know that you can achieve the same thing with 48 pitch, in regards to final gear ratio or close to it but I want to know what you guys think and what are you running in your TC3, 88 or 100 Stock or MOD
Mike F is offline   Reply With Quote
Old 08-21-2002, 02:55 PM   #2331
BBSpence's Avatar
Trader Rating: 37 (100%+)
I always try to use the biggest spur that will allow the gearing I need. Usually 96t for stock and 100t for mod in my TC3. I really don't think 88 is necessary, I've run as high as 96/42 and that was on a very large outdoor track that was setup more for the gas cars. When you change pinions with 64p, the change in ratio isn't as much compared to 48p. It's like going up or down a 1/2 tooth with 48p.
BBSpence is offline   Reply With Quote
Old 08-21-2002, 03:48 PM   #2332
Regional Moderator
I heard the samething about going up or down. Wow, 5.74 FGR you must have been flying.
So what's your recommendation, go with a 96?
Old 08-21-2002, 03:59 PM   #2333
Peter Busch's Avatar
What does putting the rear tower on the front do and what is the part number for the newer arms?
Peter Busch is offline   Reply With Quote
Old 08-21-2002, 06:29 PM   #2334
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
Spongebob....go back a couple pages..there are several pages on the subject.
Dragon Slayer is offline   Reply With Quote
Old 08-21-2002, 07:08 PM   #2335
Coxy's Avatar
This setup with a locked front diff is fine. But has anyone tryed a one way in the rear aswell. If you do would you have to change the direction of the bearings in the one way, other wise it would become a 2WD car. Is that correct ??????.
I still can't get over how good the locked front diff is, in therory it should not work and should understeer, but it does work.
Coxy.
Coxy is offline   Reply With Quote
Old 08-21-2002, 07:39 PM   #2336
Ok, I'll go back, I was just being lazy.
One more thing, where can I pick up those white delrin machined spur gears? The Kimbro's are never round.
Old 08-21-2002, 07:40 PM   #2337
BBSpence's Avatar
Mike F....for stock, I'd definately go with a 96t
Old 08-22-2002, 06:58 AM   #2338
Regional Moderator
BBspence - cool, thanks
Old 08-22-2002, 08:24 AM   #2339
tfrahm's Avatar
Send a message via AIM to tfrahm
Spongebob -- not to "argue", but in 13 years of racing R/C, the Kimbrough gears are the best I've ever found... What sort of problems are you having? I've used them in 12th scale and 10th scale pan cars (64 pitch), and 48 pitch for Legends, pan cars, and of course, my TC3's. I've never had a gear that wasn't "round".
Like I said, not trying to argue, just curious as to what sort of problems you have had....
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 08-22-2002, 10:23 AM   #2340
The kimbro's all seem to have a high spot on them so one side of the mesh is pretty tight and the other side is a little loose.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
