Old 08-14-2002, 04:33 AM   #2281
Hi there interesting topics, but one question wouldnt locking the front diff make it push like a pig, i tried something similar with a TB-01 getting ready for TCS and it was aweful.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-14-2002, 07:00 AM   #2282
Regional Moderator
Send a message via AIM to Mike F
Hey Besercoe - On the TB01 I used the gear diff in the front and the ball in the rear and it seem to work really well. You have ball diff up front and in the rear? Go with the gear diff in the front.
Mike F is offline   Reply With Quote
Old 08-14-2002, 09:17 AM   #2283
D_Ames's Avatar
Send a message via AIM to D_Ames
Locking the front diff only works on the TC3 with this years Reedy race setup from Barry Baker. His setup gives the car an extreme amount of turn in steering, but it makes the car alot more agressive (in my opinion). The locked diff takes away some of that turn in steering and makes the car more drivable. It also lets the front end pull out of a corner like a one way does, but you still have brakes.
So... yes, in any other car it would push like a pig!!!
It works very well for some people.
D_Ames is offline   Reply With Quote
Old 08-14-2002, 03:10 PM   #2284
TPhalen's Avatar
R/C Tech Charter Subscriber
The locked front diff does make the car push a little going in, but with some other tweaks you can get the car to turn in pretty good. Coming out is where the locked diff works best.
This way just make the car MUCH more predictable and stable. Not as twitchy and the one way and, IMO, you can drive ALOT more aggressively.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 08-14-2002, 03:30 PM   #2285
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Yes, locking the front diff takes away steering, so you have to compensate by softening the rest of the front end - that's why we put the rear shock tower in the front (different geometries) and soften the springs a lot.
Once you get the front to steer again (and you can) you get a very stable car.
Me like it!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 08-14-2002, 06:42 PM   #2286
Thanks guys, i also hace a tc3 so i might give it a go,
Where can i find these types of setups? and also what type of tracks have you tried this setup on?
I race weekly on a tight indoor track where i have needed the one way previously, or is it suited to long sweeping type tracks?
Old 08-14-2002, 11:32 PM   #2287
Boomer's Avatar
A good base setup is Barry Baker's setup from the Reedy Race - it can be found on www.competitionx.com
Old 08-16-2002, 04:59 AM   #2288
Rowdy's Avatar
Has anyone ever experienced the front shock tower being a different height from one side of the car to the other? Their is 2.5-3mm difference from left to right (left is higher) on my TC3. Any help would be very much appreciated, it is causing major tweak issues.
Rowdy is offline   Reply With Quote
Old 08-16-2002, 06:29 AM   #2289
tfrahm's Avatar
Send a message via AIM to tfrahm
Rowdy -- I've never seen what you describe, but I have seen something that might cause it to LOOK like that... I've seen guys pull the front gearbox to make a repair, and than install it in a hurry -- it is easy to get the "legs" one side of the gearbox caught on the bumper and/or the rear hinge pin bracket, and one side will be up in the air about 2-3 mm...
Of course, if that's not your problem, then I don't know what to tell you -- both of my TC3's are very "square" and "flat"...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 08-16-2002, 07:43 AM   #2290
TPhalen's Avatar
Rowdy: How old is your car? Some of the VERY FIRST production kits did have a problem with one side of the tower being slightly higher than the other. This has since been fixed.
You might also check the top gearbox half where it connects to the lower half. Sometimes, when installing it back on the car, it gets hooked on the sway bar screw washer. This will upset the squareness of the tower.
BTW: Thanks Boomer for all the plugs!!!
Tony Phalen
RCDriver.com
CompetitionX.com
Old 08-16-2002, 10:59 AM   #2291
Boomer's Avatar
Rowdy - I had the same problem and it was solved, actually, by Tony. . .
You probably (likely) have two of the little legs not setting inside the holes in the bumper so they're being propped up about 1/8". . .just like tfrahm said.
Check it and you will probably see a little "dimple" where the legs are sitting on the bumper.
Old 08-16-2002, 01:38 PM   #2292
VONEREFLEXR's Avatar
anyone know if there are any aluminum diff cases for the TC3 available.
VONEREFLEXR is offline   Reply With Quote
Old 08-16-2002, 03:21 PM   #2293
TPhalen's Avatar
Don't think so....but why would you want them?
Tony Phalen
RCDriver.com
CompetitionX.com
Old 08-16-2002, 05:06 PM   #2294
Boomer's Avatar
You know what might be cool - alum threads (or inserts) for the diff cases - I have a bad tendency to strip those ones. . .
But alum cases? nah, no real need.
Old 08-16-2002, 05:33 PM   #2295
rcruv's Avatar
Most of my aluminum screws on diff cases are stripped.
But I kinna like it that way. Screws being there alone hold the diff case tight enough (I can't raise the case even slightly without taking most of the screws out) and no chance of over tightening the cases.
I always check the screws if any of them are slightly out before each race.
Does this make any sense?
rcruv is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
