Old 08-12-2002, 09:49 PM   #2266
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Originally posted by TC3Nut
Can anyone answer this one problem I'm having? I have installed the rear shock tower in front. The shock's retainer hits the Caster block when I mounted on the outside hole of the new A-arms. Did you put spacers to between the shocks mount to extend out?
I just realized this problem to and its only on the right side of the car. You push the shock back and it bounces forward. The shock it totally hitting the castor block.
I dont think it effected anything, but I really dont know. Anyone else realize this?
wolfeman09 is offline   Reply With Quote
Old 08-12-2002, 09:50 PM   #2267
wolfeman09's Avatar
General question > On big sweeping tracks you want to use more Castor and on smaller tighter tracks you want to use less Castor?
Thanks...
Old 08-12-2002, 10:07 PM   #2268
For my TC3, it is binding aganist the Caster Block on both side. I'm using the 0 degree caster block for now. I waiting for the 4 degree caster block to come in at the local hobby store. Maybe with 4 degree it will solve this problem because it is tilted towards the back.
TC3Nut is offline   Reply With Quote
Old 08-13-2002, 07:05 AM   #2269
Regional Moderator
Send a message via AIM to Mike F
boomer - I haven't tried that set up yet, I will though. My car is pretty hooked now and I don't want to change it until after our big race this weekend.
Mike F is offline   Reply With Quote
Old 08-13-2002, 07:42 AM   #2270
johnbull's Avatar
Craig.
I just read your bit in this thread about how great your car is.
I have also just read your bit in the X Ray thread.
So if your TC3 is so good, which I have no doubt it is, why do you want to buy an X Ray.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 08-13-2002, 10:00 AM   #2271
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Thanks...
Yes, that is theoretically correct no matter what car you’re talking about.
MarkA is offline   Reply With Quote
Old 08-13-2002, 01:13 PM   #2272
Regional Moderator
one question on the locked front diff. Will it work equally as well with a stock motor? I printed out Barry Bakers set up, looks good but I was wondering if in Stock sedan with this set up, mainly the diff locked, if it will work.
Old 08-13-2002, 01:20 PM   #2273
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
I'm running stock on it. I think it works great - really well balanced all the way through the turns.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 08-13-2002, 01:44 PM   #2274
Regional Moderator
cool - thanks boomer. I think I'll make the switch before the race this weekend, see what happens.
Old 08-13-2002, 02:05 PM   #2275
Dingus's Avatar
I think I asked this b4, but what about the center one way with the locked diff?
Any ideas? I won't be able to try it for a few weeks.
Dingus is offline   Reply With Quote
Old 08-13-2002, 02:15 PM   #2276
Boomer's Avatar
Center one-way? on a TC-3?
Old 08-13-2002, 02:25 PM   #2277
Dingus's Avatar
yeah, from GPM
http://www.hobbyetc.com/cgi-bin/item...=984&car_id=27
Old 08-13-2002, 02:45 PM   #2278
shrekair's Avatar
Trader Rating: 9 (91%+)
whe i ran tc3's i use the center one way as a tuning tool. with the center one way i was able to roll better through highspeed corners, w/o the center one way i was able negotiate tighter sections of track due to increase weight transfer when i let off the throttle. and it also made it feel like a little more steering in the middle of the corner.
shrekair is offline   Reply With Quote
Old 08-13-2002, 05:15 PM   #2279
Craig's Avatar
Send a message via AIM to Craig
Johnbull-I have owned almost every car out there thats readily available.I like trying new stuff.It always makes me go make and look at the TC3 differently.The bad part about the Xray is that its almost $600 for the EVO2 and the C-hub conversion.So I think until I win the lottery its out for now.I have decide to get a new FTC3.
Craig is offline   Reply With Quote
Old 08-13-2002, 09:52 PM   #2280
...and if you want to save some cash on TC3 accessories....try here.
I ordered several items, they do the exchange rate perfectly, sent via mail...and only 4 days to arrive. VERY good service!!!!
http://www.cmldistribution.co.uk/fast_tc.htm
acloco is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
