Old 07-30-2002, 07:04 AM   #2191
Cracker78's Avatar
Send a message via AIM to Cracker78
Hey everyone, my local track layout changed from a track with many large radius turns to one with many hairpin turns. Now I had read somewhere in this thread that one-ways (which i am currently running) are slow in hairpins and that running a normal diff up front instead would be more appropriate for the situation. My question is - Is this true and why? In my mental picture of how things work, outside of better braking, I can't envision how a ball diff would be better in a tight turn. Anyone have any theories or ideas or even a link to info that explains this to my poor little brain
Cracker78 is offline   Reply With Quote
Old 07-30-2002, 09:11 AM   #2192
RAP66's Avatar
Default one-way & front sway bar
Is that an okay combo..... or will the front sway bar take away the effects of the one-way?
Rich Pedro
rap66@rcracing.com
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 07-30-2002, 10:32 AM   #2193
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
cracker - oneways work best on sweeping turns where you can keep on some power (not saying sweepers. . .just turns with some sweep) so that the front literally pulls the car through.
They don't work as well on tight tracks where you have to slow down a lot - you end up having to swing wide initially (which opens you up for T-bones by people with brakes!) and since you can't brake, you have to kinda glide your speed down (or find some other way to shed speed)
It can still be faster, but, as in a conversation with TPhalen this weekend, it is very hard to be as consistent on a tight track with a oneway as it is with a diff.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-30-2002, 05:37 PM   #2194
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Like Boomer said. THe one ways like a more open type track with a flowing layout. I normally run diffs in all my cars because my track is tight with many hairpins. If I was on the track by myself I could run fast with a one way but with others out and having to change my lines the diff setup was faster as I could point and shoot to the corners. I works very well with diffs on the track.
Me personally just don't care for one ways too much but on certain tracks they can be faster but then again you also need to know who you run against to see if you would truely benefit having a one way in.
Old 07-31-2002, 06:33 PM   #2195
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
If i am elected President.....I will outlaw one-ways....Diffs for everyone.....HIP HIP HOORAY....HIP HIP HOORAY......
Dragon Slayer is offline   Reply With Quote
Old 07-31-2002, 06:37 PM   #2196
onaMISSION's Avatar
I can run a one way just as clean as running a diff. I just turn my brake down alot around 50 percent. I do like use diffs feels like the car is more planted.:d
onaMISSION is offline   Reply With Quote
Old 07-31-2002, 07:56 PM   #2197
big al's Avatar
It's all about the good 'ol ball diff!!
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 08-01-2002, 04:27 PM   #2198
Default Caster
Help needed
To get more mid and exit corner steering do I need to increase or decrease the caster.
Thanks for myour help with the above
FTD RACING is offline   Reply With Quote
Old 08-01-2002, 04:35 PM   #2199
Send a message via AIM to ZER01
FTD racing, decrease the caster.
ZER01 is offline   Reply With Quote
Old 08-01-2002, 06:05 PM   #2200
big al's Avatar
Use the rear shock tower up front!!
Old 08-01-2002, 09:53 PM   #2201
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
What exactly does bump steer do? anyone care to enlighten? does it add to initial steering/turn-in? thanks in advance!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 08-02-2002, 02:40 AM   #2202
Default IRS Diff
I recently replaced the front diff to IRS Aluminum outdrives diff. Now the gear mesh don't seem to mesh. I could feel that there is more fraction between the big diff gear and the little drive gear. I placed a shim as per manual on the long side of the outdrive and try placing one the other side. Problem still exist. Next, I placed 2 shims on the long side thus forcing the diff gear to move to the left. This increased the pressure on the diff bearing. Then I proceeded to removed the shims in the drive gear so it will be positioned farther back. No luck!!!
I switched to the aluminum because the plastic outdrives kept breaking with the slightest hits. I have tried the the steel outdrives and it works fine, but I'm trying to maxmium weight reduction specially with rotating mass.
I currently running the new tires from Medial Pro 25 shore and it is the best tires I have use on non spray/prep parking lot surface. Definitly well worth the $13/pr.
TC3Nut is offline   Reply With Quote
Old 08-04-2002, 10:56 AM   #2203
TTT
Old 08-04-2002, 01:26 PM   #2204
Corse-R's Avatar
Default Re: IRS Diff
Uhm....
After more than 320 packs over my actual TC3 I'didn't had the need of changing the plastic outdrives for breakage of one outdrive (touch wood...) another address to your 'problem' should be changing the steel input shafts to the aluminium ones made by IRS and sticking with steel outdrives, the weight saving isn't the same, but you shave precious grams on rotating parts of your car.
I have the aluminium ones and the plastic oudrives and none problems after 320 packs.
Stick with the plastic ones and don't slam the walls, your outdrives appreciate a lot...
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-05-2002, 12:23 AM   #2205
spawn's Avatar
Guys my setup is really out but the car runs well on prepared track. I still find my shocks a bit soft as the front end of the body scrapes the ground whenever I hard brake on the straights.
Front:
ellegi 26mm foam shore 42
shock piston #2
Integy damper oil #140
AE Gold springs
upper center hole for shock
camber link outer lower hole
camber 2degrees
toe out .5degrees
F2+2
Std C hub carrier
Rear:
ellegi 26mm Foam shore 30
Shock piston #2
Eagle super hard springs
Inside hole for shock
camber link inside lower
camber link inside lower on hub carrier
camber 1.5degrees
R2+2
Ratio:
9.8
weights near motor to compensate the heavy 3000 batt.
Very controllable except that my car does not have the droop adjustment, does this help? is there another cheaper way to overcome this?. I burned about 2mm of the back tire with 2 batt. packs on the last outing. Really fun coz it sticks to the ground.
spawn is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
