Old 07-26-2002, 06:14 PM   #2176
big al's Avatar
So do I have to use the new arms? I'm considering using the rear arms as a template for the front arms. ( I think someone mentioned this in an earlier post????) Or , do I just use the holes on the original arms? So many questions about holes!! Thanks--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 07-27-2002, 07:44 AM   #2177
Send a message via AIM to t.i.r-sid
i have driled holes on the front and rear wishbones 2mm outside the original ones i tried this at club meeting on wednesday and tq by 10 sec without the out holes the rear shock tower cant be used as the ride hieght cannot be brought down unless shorten shocks are used. i havnt yet tried the shock tower but im tring it this wednesday. gotta try these things else ull never find out if it will work
t.i.r-sid is offline   Reply With Quote
Old 07-27-2002, 09:59 AM   #2178
Tech Legend
Wild Cherry's Avatar
t.i.r. .....
The new hole on the back arm is inside on the arm compared to original hole....
On the ft arms, its outside the original hole ....
Wild Cherry is offline   Reply With Quote
Old 07-28-2002, 02:15 PM   #2179
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
I just ordered a new FT TC3 and will be picking it up this Thursday. I was looking for a good starting point for stock racing with foams on asphalt. It is a indoor track with good traction plus we can use traction compound so getting grip is normally not a problem. I never had a TC3 before but had various other ones. I have had a Yoke MR4TC, HPI Pro 2, Axis 1 and 2, FSR Bullet, and the Tamiya EVO2 plus more. Finally decided to run the TC3 as all the others were really pretty good for me. Just decided that the TC3 is very easy for me to get parts for.
I was thinking like 60wt front with copper springs #2 piston and for the rear like 50wt with red springs and #2 piston with all other settings in the stock position. Would this be a decent starting spot? Also what 64 pitch spur do most use for stock with the TC3? I will be running a P2K2 and I a normal roll out for our track in stock is around 27.50mm to 28.50mm with 60mm Jaco purple foams front and rear.
Most cars I have run I ran 60 to 70 wt oil but as I have been looking at alot of other TC3 setups it seems most run heavier springs in the front and about one softer weight in the rear and about 10 wt softer oil in the rear. Does this car car have alot of natural steering or lack of. From my impression and the track I race at that when I went to stiffer springs on any end of the car it produced more overall traction. If I wanted more steering I went up to one stiffer spring.
Brian
Old 07-28-2002, 04:17 PM   #2180
yodace's Avatar
R/C Tech Charter Subscriber
I just got a HUDY setup station. I was wondering when you set the droop, should I leave the shocks on or off.
yodace is offline   Reply With Quote
Old 07-28-2002, 08:10 PM   #2181
big al's Avatar
YODACE--
Old 07-28-2002, 08:23 PM   #2182
big al's Avatar
Sorry!! YODACE--When you set droop the shocks can be left on or off. It's really a matter preference. You have to make sure that the shock lenght is longer than the droop setting or the droop screws will not "work". The shock has to be able to drop lower than the droop setting for the adjustment to be utilized correctly!
I finally got to test out the rear shock tower up front. I had to use the stock arms, but all I can say is WOW!! Major exit speed!! A mod well worth the money and effort. I highly recommend it!
Old 07-28-2002, 11:05 PM   #2183
yodace's Avatar
Confused,
when somebody says add more droop do they mean go down or up on the scale? Like for example I have my droop set on 4 and I whated to had more droop I should go to like to right.
Old 07-28-2002, 11:06 PM   #2184
yodace's Avatar
Confused, Sorry for the double post.
when somebody says add more droop do they mean go down or up on the scale? Like for example I have my droop set on 4 and I whated to had more droop. I should go to like to down to three right.
Old 07-28-2002, 11:25 PM   #2185
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Correct....at least that is what I understood he meant by adding more droop.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 07-29-2002, 09:51 AM   #2186
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
More droop is 3mm to 4mm less droop is 4mm to 3mm so when someone adds droop the number gets bigger.
RKeasler is offline   Reply With Quote
Old 07-29-2002, 10:17 AM   #2187
stefan's Avatar
Send a message via AIM to stefan
Default Sorry Rod,
but yu got it the wrong way.
When you add droop, the number on the gauge gets smaller (arm closer to the table).
For example: You got 5 mm droop, that means you arms are 5mm above your chassis level when the shocks are off and the car is supported (droop blocks)
Now, you want your arms go 2 mm further down (more droop) they will be only 3mm above your chassis level..
Hard to explain, but that's how it works.
Aren't you running XXX-S by the way?
stefan is offline   Reply With Quote
Old 07-29-2002, 04:06 PM   #2188
yodace's Avatar
I have both XXXS and a TC3.
Old 07-29-2002, 05:37 PM   #2189
RKeasler's Avatar
Stefan thanks for the clarification I will have to revisit the idea later. I got another TC3 2 or 3 months ago
Old 07-29-2002, 07:12 PM   #2190
Buster in the XRAY thread explained Droop in great detail...take a look.
V-Dezign 4.0
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
