Old 07-15-2002, 01:53 PM   #2131
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
I'll start a new topic...
I've got a fairly good setup on my TC3 for bumpy track conditions, but what can I do for more on-power steering or better yet, Turn-in steering...
I have thought about a couple of things:
#1. More toe-in
#2. Softer Front springs
#3. Lighter weight front oil (already at 30 weight)
Thanks for any suggestions all....
TigeRyan is offline   Reply With Quote
Old 07-15-2002, 01:55 PM   #2132
Sigearhead's Avatar
Trader Rating: 68 (100%+)
what castor blocks are you running?
Sigearhead is offline   Reply With Quote
Old 07-15-2002, 01:56 PM   #2133
Sigearhead's Avatar
btw, if you wanted more turn-in steering you don't want more toe-in you would actually want toe-out.
Old 07-15-2002, 01:58 PM   #2134
Send a message via AIM to ZER01
Originally posted by acloco
By using the rear shock tower on the front....and SPACING it up...you RAISE THE DAMN INNER CAMBER LINK LOCATION!!!!!
Looks like someone figured out a way to add more adjustments to the TC3's roll centers. Good thinking and you are RIGHT. Same here, but I modified my NTC3's front shock tower so that I can run lower caster than the stock options.
ZER01 is offline   Reply With Quote
Old 07-15-2002, 02:01 PM   #2135
More on-power steering, try less droop in the front or more droop in the rear but it might push on exit.
Old 07-15-2002, 02:02 PM   #2136
TigeRyan's Avatar
I am running 0 degree caster blocks...
And currently 2 degree toe-in...
Old 07-15-2002, 02:04 PM   #2137
2 degree toe-in on the front? Are you using any anti-squat?
Old 07-15-2002, 02:05 PM   #2138
Trips's Avatar
Trader Rating: 16 (100%+)
ARGH! Crap...come on guys.
By using the rear shock tower on the front....and SPACING it up...you RAISE THE DAMN INNER CAMBER LINK LOCATION!!!!! The same amount that you raised the rear shock tower when moving it to the front.
Again.....draw it out on graph paper.
Take 10 minutes and draw it out......move the inner camber link location UP ....because you spaced the shock tower UP.
I'm not disagreeing that you'll move the inner camber link up, I'm just stating that moving the inner camber link up will LOWER the roll center.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 07-15-2002, 02:09 PM   #2139
The higher the inner pivot point of the camber link will decrease the roll of the chassis.
Old 07-15-2002, 02:11 PM   #2140
TigeRyan's Avatar
I will have to look for the Anti-squat when I have my setup sheet in front of me...
Is 2 degrees too much??
Old 07-15-2002, 02:19 PM   #2141
2 degrees toe-in for the front is too much in the wrong direction. Run 0-1 toe-out on the front is good. Anti-squat directs weight more upfront on and off-power. How much kickup are you running?
Old 07-15-2002, 02:46 PM   #2142
TigeRyan's Avatar
Wow, never run toe-out before on a TC...
Ok, well, will take those suggestions to the track with me Saturday, big charity race locally (South Jersey) so I want to try and put my best race out there...
Old 07-15-2002, 03:59 PM   #2143
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Set it up at zero toe first.
Usually, we set it up with about 1/2 degrees toe-in (that's half). Toe-in on an electric sedan makes it more stable - if it's toed out, you're gonna be twitchy.
Strangely enough, it's opposite with my nitro sedan - toe-in is twitchy as a druggy without a fix! Toe out seems to pull the car straight. . .wierd.
If you're used to 2 deg in - I would go to about 0 and see how that works. It will prolly be too twitchy for you and you will run in a half degree.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-16-2002, 08:38 PM   #2144
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
TTT
Dragon Slayer is offline   Reply With Quote
Old 07-16-2002, 11:02 PM   #2145
Default toe
As with real cars, 4wd works better with a slight amount of toe out .5 too 2.0 degrees. I believe it is because, under power the front wheel pull forward slightly. so if your at zero, when your under power your actually at negative toe position.
food for thought
Lap Ya Later
racer S
RACRS is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
