Old 07-13-2002, 12:27 PM   #2116
....and we are ALL Americans.
....this coming from a transplanted MONTANAN....out here in Northern CA......
.....take me home...to the place...where I was born....START YOUR ENGINES.......
....well....sorry.....NO major races held in Montana....just the occasional 1/4 mile of fun on some frontage road somewhere in Big Sky Country!
acloco is offline   Reply With Quote
Old 07-14-2002, 02:29 AM   #2117
Sigearhead's Avatar
Trader Rating: 68 (100%+)
you're missing the point, everyone that lives in the States is an American and even though everyone who lives in Scandinavia is "Noridic", Norweigians are not Swedish and Swedish are not Finnish, they don't even speak the same languages. I have to say it is an insult to generalize in this way. It's like saying all people who speak spanish are Mexican. my 2 cents.
Sigearhead is offline   Reply With Quote
Old 07-14-2002, 04:37 AM   #2118
um....whatever...back to the topic at hand.
The roll center is changed when using the R shock tower in the front. Why? The pickup points for the camber rods are raised......so...the front roll center is raised.
Old 07-14-2002, 05:28 AM   #2119
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
I think you are wrong. the camber link positions are exactly the same on the front and rear shoch tower. If you shim the tower, then the pick up points are raised, but that actually lowers the roll center.
Airwide is offline   Reply With Quote
Old 07-14-2002, 11:09 AM   #2120
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
I would like to take this opportunity to appologize to all those of the Nodic region, that may have been offended by my generalization of your region........
Dragon Slayer is offline   Reply With Quote
Old 07-14-2002, 11:28 AM   #2121
Airwide's Avatar
No probs dragon slayer, and I wasn't offended. I just wanted to clarify that Solberg is from Norway.
Old 07-14-2002, 11:36 AM   #2122
Airwide...after i posted the original comment on Solberg...i went to the WRC site to see if it said anything about his R/C involvement.....didnt see anything...didnt figure i would....yes, he is form Norway.
So, i guess we can move on now....lolol
Old 07-14-2002, 03:30 PM   #2123
Well....no....the roll center is raised.
Does everybody know what the term "roll center" actually means? Kind of neat, actually. Draw a line from your right inner camber link location to the left lower inner hinge pin....repeat the same for the left inner camber link location to the right lower inner hinge pin......the center of the X is the "roll center. Now...put the Rear shock tower on the front....raise the shock tower as described previously.......now.....draw the new lines to find the roll center. The crossing point of the X is now HIGHER.....so....the roll center is now higher.
...looks something like this.... x vs X
Old 07-14-2002, 03:41 PM   #2124
Trips's Avatar
Trader Rating: 16 (100%+)
acloco,
Sorry to disagree, but I don't think you've got the mechanics of roll center correct. Here's a link to a decent explanation:
http://home.tiscali.be/heremanss/c2/index.htm
(scroll down to section 2.3)
Raising the inner hingpin locations raises the roll center, raising the inner camber link positions lowers the roll center, all else being unchanged.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 07-14-2002, 09:20 PM   #2125
I do not have a scanner, otherwise I would draw it out on graph paper.
Use the picture that is in 2.3 of the link......raise the upper camber link position by 1 or 2 mm.....redraw the lines....and see for yourself.
If you raise the inner camber link position, the blue & red lines passing through the outer & inner camber link positions intersect higher in the center and further out on the intersection point....hence...a higher roll center.
Old 07-14-2002, 09:48 PM   #2126
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Tony P,
wanted to give a little race report....I put your Bumpy TC3 setup on my car and went out to a new track...while it was a light turnout due to some light showers, I still won the A-Main, which is a huge improvement on the car from barely squeeking into the A to winning an A-Main...
Thanks much....car still needs a bit more on-power steering, but for now I am happy were I am at...
Later!
TigeRyan
TigeRyan is offline   Reply With Quote
Old 07-15-2002, 07:40 AM   #2127
acloco,
Take another at the roll center diagram, Trips speaks the truth.
racerdave is offline   Reply With Quote
Old 07-15-2002, 01:19 PM   #2128
Trips's Avatar
The intersection of the blue and red lines isn't the roll center. If you raise the inner camber link, you'll move the intersection of the blue and red lines further outboard, thus when you look at the GREEN lines from the centers of the contact patches to the intersections of the blue and red lines, the intersection of the green lines gets LOWER as the intersections of the blue and red lines moves outboard, thus LOWERING the roll center.
Here's a link to an interactive roll center calculator:
http://www.bennett-racing.com/modem/...ollcenter.html
Plug in your numbers, and get a roll center height, then make no other change but to lower the height of the inner camber link and you'll see the roll center move up.
Trips
MARSHAL!!
Old 07-15-2002, 01:46 PM   #2129
ARGH! Crap...come on guys.
By using the rear shock tower on the front....and SPACING it up...you RAISE THE DAMN INNER CAMBER LINK LOCATION!!!!! The same amount that you raised the rear shock tower when moving it to the front.
Again.....draw it out on graph paper.
Take 10 minutes and draw it out......move the inner camber link location UP ....because you spaced the shock tower UP.
Old 07-15-2002, 01:51 PM   #2130
Sigearhead's Avatar
just agree to disagree and let's move on
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
