Like Tree4Likes
Old 09-18-2001, 09:00 PM   #196
STLNLST's Avatar
Trader Rating: 21 (100%+)
RacerTex- I replaced all of my wheel bearings recently. I had the same problem. I don't know what caused it but after replacing them it hasn't happend again.
Tony- Good luck in Vegas. I can't go but some of my fellow racer's from Speedworld will be there.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 09-18-2001, 09:27 PM   #197
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
ROBK.....you said something about"the center shaft will work well in stock" is there a center shaft one way and if so, who makes it???thanks......I'm a better "diff"driver than one-way.Is the center a good compromise between the two???if there is a center 1-way????
Dragon Slayer is offline   Reply With Quote
Old 09-19-2001, 07:15 AM   #198
TPhalen's Avatar
R/C Tech Charter Subscriber
A couple companies make the center drive one-way. I think one of them might be GPM. My experiences with it were that it gave a hint of the one-way diff. It wasn't as aggressive, and it certainly didn't add the steering that the diff gives. IMO, it did actually smooth the car out a bit. Personally, though, I like alot of steering, and this just didn't give me enough.
We did try it with both the diff and the shaft, but we didn't feel that much of a difference. But that's just me. It might work differently for others.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 09-19-2001, 08:33 AM   #199
JOHNNY RACER's Avatar
Default hey tony....
i just received some wheels and tires from speedtech. i got the 138g and 139g2 combos. there seems to be an excessive amount of air gap between the tires and the inserts. have you noticed the same with yok tires and inserts you have gotten b4? assuming you have had them b4. will this hinder performance? i've only had hpi tires w/ yok inserts and didn't notice much of a gap w/ those.
JOHNNY RACER is offline   Reply With Quote
Old 09-19-2001, 08:59 AM   #200
TPhalen's Avatar
Supposedly, in Japan, that is the hot ticket. When I ran the G's they did have a noticeable air gap. I felt like this provided a little more forward traction (sort of like the wrinkle-wall effect in drag racing). Only problem I felt was making sure you had the same amount of gap in ALL the tires...i.e., too much air gap in the left rear than the right might give more traction on the left side, causing handling problems.
If you get a chance, try the Sorex tires. They don't have any gap and last ALOT longer.... Sort of sux to say AFTER you bought the G's....heh heh, sorry!
Tony Phalen
RCDriver.com
CompetitionX.com
Old 09-19-2001, 09:06 AM   #201
yeah, the wrinkle wall is the first plus i thought about, but then at the same time the wrinkle walls are only good for straight-line traction. guess i'll assemble them all first and check the gaps b4 gluing them. i remember you mentioning the sorex tires. i think someone else said that the traction performance falls off far b4 the tire wears out though. dunno. speedtech didn't have a sorex combo and i'm on a pretty tight budget right now. i plan to try them next set. what ones are equiv. to the 138 and which the 139? should i still use yok inserts?
thanks.
Old 09-19-2001, 12:07 PM   #202
TPhalen's Avatar
The 36R's are the Sorex tires you want.
As for the air gap, there is one thing you can do the take away a little of the gap. Getcher hands on some relatively thin width strapping tape. On the wheel, wrap the tape around a couple times and test fit the tire and insert. You can cut down on the size of the gap. Just remember how much you wrapped so you can do this evenly to all 4 wheels.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 09-19-2001, 02:31 PM   #203
linger's Avatar
Tphalen - what insert are you using with your 36-R's?
I'm currently using a set with HPi blues and there is a definite air gap. However, they still seem to hook up great with nearly 50+ runs on them in Mod. Should I fill the air gap with strapping tape the next time I glue up a set?
linger is offline   Reply With Quote
Old 09-19-2001, 02:53 PM   #204
TPhalen's Avatar
You can try it!!! The tire is less likely to squirm going in and coming out of the corners....
We usually run HPI Green inserts or Pit Shimitzu inserts. Pits seem to work a little better, but harder to getcher hands on...
Tony Phalen
RCDriver.com
CompetitionX.com
Old 09-19-2001, 09:26 PM   #205
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
people are also using the Yok Med and Firm inserts with the Yok tires.
Regarding the air gap, wouldnt this be eliminated if you put a hole in the rim? I alway drill 2 holes in my rim before i put the tire on. There is an article on the proline website.
This bvirus really sucks!!!! No internet at work and my computer is hosed
wolfeman09 is offline   Reply With Quote
Old 09-19-2001, 10:16 PM   #206
TPhalen's Avatar
There are 2 reasons for the air gap....one is air in the tire and the other is the insert being a little too small for the tire. The air-in-the-tire gap can be eliminated by the drilling of holes in the wheel, as Matt has said. The small-insert gap is best filled by lining the wheel with tape.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 09-20-2001, 07:34 AM   #207
should i line the wheel with tape untill there is no gap? even if it takes stretching the insert to match the tire and eliminate the gap? or should i just leave it alone?
Old 09-20-2001, 09:09 AM   #208
TPhalen's Avatar
You could put tape between the insert and the tire, but you might take away some of the traction. The best place is taping up the wheel and stretching the tire and insert over it....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 09-20-2001, 09:18 AM   #209
so i should tape the wheel until the gap is completely gone?
Old 09-20-2001, 12:10 PM   #210
TPhalen's Avatar
Yes. It shouldn't require more than 2 or 3 turns around...
Tony Phalen
RCDriver.com
CompetitionX.com
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
