Old 06-25-2002, 08:56 AM   #2026
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
I hear ya...I am a techno-geek too, love those gadgets...
Hey, quick question for you on the TC3, I got the car handling better, but it is still ass-end loose...I run on a parking lot track that is fairly bumpy, I am running red springs all around with 60 weight oil...
I am pretty much running the car stock per kit build...I've seen the bumpy setup you suggest on your site, gonna try it, but anything else I can try???
Thanks!
TigeRyan is offline   Reply With Quote
Old 06-25-2002, 11:31 AM   #2027
mystererc's Avatar
TigeRyan, that seems a little stiff for a bumpy track. We run on concrete with seams and I am running 40wt with reds in front and 40wt with silvers in the back. I am actually considering running 35wt or 30wt oil.
E
mystererc is offline   Reply With Quote
Old 06-25-2002, 01:01 PM   #2028
yodace's Avatar
TPhalen were could i find the bumpy setup on your website, which area.
yodace is offline   Reply With Quote
Old 06-25-2002, 01:31 PM   #2029
Mr. MR4's Avatar
Hi Tigeryan,
for bumpy surfaces try 4 degree caster blocks in front, 30wt oil and green springs all around.
For more rear end grip try the R + 2 + 2.
Hope this helps
Mr. MR4 is offline   Reply With Quote
Old 06-25-2002, 01:41 PM   #2030
TPhalen's Avatar
TigerRyan. As mystererc stated, that seems a little stiff for a bumpy track. A bit softer oil and/or spring should do the trick.
yodace. Go to the home page. Up near the top is the quickclik nav bar. Click on the Pro Setups and that will take you right to the opening area of the setups.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 06-25-2002, 09:25 PM   #2031
rcruv's Avatar
TP - Do you have a setup for Hitec challenge in Poway, CA or similar one that I could use?
Thank you in advance.
rcruv is offline   Reply With Quote
Old 06-26-2002, 08:41 AM   #2032
TPhalen's Avatar
I basically ran a SoCal setup with a different shock locations. I think something like the Reedy Race setup would probably work pretty good. Might need to change the shock locations, though. Down one in the back.
Try that.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-26-2002, 09:38 AM   #2033
Why is it that when I run stock class, my car gets REALLY unstable or spins out when I let off on the throttle, but when I run mod, the problem disappears?
Does it have something to do with the fact that the stock motor seems to slow a LOT quicker (almost brake-like) than a mod?
Any suggestions on how I can solve this problem? Btw, I'm running a one-way.
G-spec is offline   Reply With Quote
Old 06-26-2002, 10:12 AM   #2034
linger's Avatar
Yeah, that's expected. Stock motors have a lot of built in braking and you can help the car by giving it a rolling throttle. You can do this by advancing your throttle trim or using the "idle up" feature on your radio. I prefer the idle up since your endpoints remain the same.
linger is offline   Reply With Quote
Old 06-26-2002, 11:13 AM   #2035
TPhalen's Avatar
Good call Ling....
BTW, where ya racing this weekend???? I heard something about a race at Lowes....
Interested?
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-26-2002, 01:37 PM   #2036
rcruv's Avatar
TP - Thank you for your advice on track setting.
Old 06-26-2002, 01:45 PM   #2037
yodace's Avatar
do M8's have a "idle up" feature or something like it>
Old 06-26-2002, 01:50 PM   #2038
TigeRyan's Avatar
when you say Idle Up is that the same as putting creep into the car so that when you release the throttle it continues to roll or do you mean something else???
Old 06-26-2002, 02:01 PM   #2039
Trips's Avatar
Trader Rating: 16 (100%+)
YEs, I believe Airtronics calls it "start position" (or "S-POS"). It'll be a switch on the transmitter that sets the throttle trim to a preset higher point. Some nitro guys use it to help get the engines started easier. For stock electrics, just set it so when you hit the switch, the car just creeps forward.
T
MARSHAL!!
Trips is offline   Reply With Quote
Old 06-26-2002, 04:14 PM   #2040
So are most of you guys running stock class using the "idle up" feature when racing? Or do you guys just never have the trigger below halfway point during your run when letting off?
I know sometimes when I let off, I let it off all the way to the triggers neutral position during hard turns. (This is when I feel the instability in the car.)
I hope you guys understand what I'm trying to say.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
