Old 06-21-2002, 07:18 AM   #2011
TPhalen's Avatar
R/C Tech Charter Subscriber
Slim or shim???? Guess it's the same thing....
Running the bubble in the middle of the tweak station DOES NOT necessarily mean your car is tweaked correctly. This just means the car is (weight-wise) is flat. We've found that using the tweak station is a good start, but we NEVER rely on it. Put the car on the track and chances are it's not going to drive with a correct tweak. That is the first step, though. Set the ride height as described by big al. You can then set it on the tweak station and set it, or do the Track Tweak method. Track Tweak is basically setting it on the track and do some hard left and hard right turns. If it's equal, then your chassis and setup is good. If it doesn't, most likely the chassis is twisted. If it hooks harder to one side, you need to adjust the OPPOSITE side to fix the tweak. It takes a little getting used to but it's very effective.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 06-21-2002, 09:45 AM   #2012
Tech Legend
Wild Cherry's Avatar
ooops , thats what happens when you post at midnight ......
SHIMS........
Wild Cherry is offline   Reply With Quote
Old 06-21-2002, 01:06 PM   #2013
TPhalen's Avatar
heh heh, that's ok...you could of messed on a different word....that's an innocent one!!!!!!
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-21-2002, 02:37 PM   #2014
Tech Legend
Thats why they call me Shim Shady.....
Old 06-21-2002, 10:33 PM   #2015
shrekair's Avatar
Trader Rating: 9 (91%+)
teflon or brass knuckles there shim?
shrekair is offline   Reply With Quote
Old 06-22-2002, 03:29 AM   #2016
over gear's Avatar
Trader Rating: 15 (100%+)
Tony Phalen: Can you share the track tweak method? let's say my tc3 pushes turning left, how should i adjust the right suspensions? lower or raise both right front and right rear ride height?
my car looks good on the tweak station, but it never have even steering....
over gear is offline   Reply With Quote
Old 06-22-2002, 11:07 AM   #2017
shrekair's Avatar
inc. RR ride height
Old 06-24-2002, 09:33 AM   #2018
If you never have even steering you will have to adjust your radio. I set mine at 120% dual rate then set the steering epa to 100 then go up or down from there, then when it looks like they are the same(do a circle, make it even both ways) you can turn the dual rate up or down depending home much sterring you want.
teamAE is offline   Reply With Quote
Old 06-24-2002, 10:26 AM   #2019
TPhalen's Avatar
shrekair is right. increase Right Rear.
teamAE has another solution, although your not really fixing the problem, just patching it. Ideally, you want to set up the car so your EPA's are not all jacked.... I have to say that this solution has worked for me in a pinch (at race time).
over gear: Ya, that's the problem with the tweak station. The bubble might be dead-nuts in the center, but your car will still act tweaked. That's when track-tweak comes in. Make sure you set it DURING practice. At race time you may not be allowed the time to play and adjust.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-24-2002, 10:41 AM   #2020
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Tony, in this case wouldn't it be better to set up the car with scales instead of the tweak station? Would a car you call track tweak free read ok on the scales? Just wondering if you looked into that at all. Thanks.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-24-2002, 03:59 PM   #2021
Send a message via AIM to Type S
i had a horrible day at the track on sunday.
I broke in the first qualifer
qualified 2nd after the 2nd qualifier
broke in the 3rd qualifier
and got ran into the wall in the main and broke again
damn , my luck stinks.
Tony:
will the trinity front bumper for the NTC3 fit on the electric TC3
Type S is offline   Reply With Quote
Old 06-24-2002, 04:40 PM   #2022
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
Evening all....may finally get to race this weekend......been almost 2 months since i've raced........AAAARGH
Dragon Slayer is offline   Reply With Quote
Old 06-25-2002, 07:18 AM   #2023
TPhalen's Avatar
Kraig: Ya, that would probably work well. Only problem is that you need to buy FOUR scales. Well, I guess you could do it with two. I found some small scales but at $35 a piece, track tweaking didn't seem all that hard....
Might look into it again.....
Type S: Not a direct fit. I guess you could try to modify it but it might take some time.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-25-2002, 07:24 AM   #2024
TigeRyan's Avatar
Send a message via AIM to TigeRyan
Tony,
Had read somewhere that a guy used the Walmart food scales that dieters use...they have enough measurement to work for R/C and are relatively in-expensize ($14.95 each)
What the guy have done was to remove the curved basket and put on a piece of flat plastic for the tray to sit the cars on...just something I had read...
John
TigeRyan is offline   Reply With Quote
Old 06-25-2002, 07:52 AM   #2025
TPhalen's Avatar
Ya. But if you know me, you know you have to have something better than the analog scales. I need digital, man!!!!
Tony Phalen
RCDriver.com
CompetitionX.com
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
