Old 06-11-2002, 12:28 PM   #1981
Default TC3 Rear Shock tower
I have tried the rear tower on the front.
One thing that I did that helped with the shock clearence, was to cut the ball cup on the shock end so that the bottom of the spring holder would rest on the ball end. If you want more clearence, try cutting the threads on the end of the shock shaft itself. Don't be greedy and take to much though. You only need to lose a couple.
I have even moved my body posts up to the shock tower for less flex.
I definitly want to see ASC new front arms though.
Sounds like they have a good idea.
Tracy
doorman is offline   Reply With Quote
Old 06-11-2002, 09:18 PM   #1982
Thanks........
...and yes.....roll center is moved u just a touch.....but not necessarily a bad thing though!!???!!??!!??
acloco is offline   Reply With Quote
Old 06-11-2002, 09:26 PM   #1983
SpeedTech's Avatar
Hi Guys,
We still have a couple more sets of the Titanium screw kits for the TC3 in stock. This is a complete screw kit for the entire car.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 06-13-2002, 04:34 AM   #1984
RC Nitro's Avatar
TPhalen: Thanks for posting the tip on assembling the rear arms. I built my kit this weekend and followed your instructions. Otherwise I propably would have tweeked the chassis. Going to run indoor TC class on the banked oval tonight.
RC Nitro is offline   Reply With Quote
Old 06-13-2002, 05:40 AM   #1985
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
Originally posted by TPhalen
Hey Airwide...long time no talk. I see you are the MAN over at the Orion Micro game....
Yeah it's been a while. I haven't been racing much the last months, since touring car racing on asphalt isn't popular in sweden. It's a pity, because it's so much more fun on asphalt than on carpet. But I guess it's because our tracks are quite large and more suited for nitro racing. My home track is 330 m long so it's not very fun to practise either.
btw, well done at the reedy race.
Airwide is offline   Reply With Quote
Old 06-13-2002, 07:31 AM   #1986
TPhalen's Avatar
R/C Tech Charter Subscriber
Originally posted by Airwide
...btw, well done at the reedy race.
Thanks.... Fun race.
RC Nitro: Cool. Glad I could help out...
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 06-14-2002, 08:36 AM   #1987
Regional Moderator
Send a message via AIM to Mike F
Default 2nd ANNUAL BEAT THE HEAT SUMMER BASH
We'll be holding our 2nd Annual race on the 18th of August. for more information and updates check out the MSRA thread on this site.
Race held outdoors on Asphalt, OK traction, little bumpy in certain areas. VHT will be laid down.
Mike F is offline   Reply With Quote
Old 06-14-2002, 04:21 PM   #1988
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
When using the rear tower on the front..someone said if you raise the tower you also raise roll center....i almost always use the upper link hole in the tower...so, if you raised the tower enough, couldnt you just use the lower link hole, and have the exact roll center as before......?
When are those new arms coming out??????
MikeF....were gonna try to get some East Texas peeps at your race....I couldnt make it last year.....gonna try this year.
Dragon Slayer is offline   Reply With Quote
Old 06-15-2002, 02:31 AM   #1989
V12
V12's Avatar
when building the transmission the manual recommands using diff lube on the gears. isnīt there a better lube for this job especially regarding low friction for stock racing? maybe teflon lube or any oil?
V12 is offline   Reply With Quote
Old 06-15-2002, 10:41 AM   #1990
yodace's Avatar
How should a person clean their bearings?
yodace is offline   Reply With Quote
Old 06-15-2002, 10:42 AM   #1991
yodace's Avatar
Opps how often should I be cleaning my bearings>
Old 06-15-2002, 01:44 PM   #1992
Super Moderator
Grizzbob's Avatar
V12, yes, there are better lubes for the gears(& using diff lube is far too messy for that). Try going to some local bicycle shops to find something called White Lightning, it's a lube that goes on wet, but it dries leaving a coating of teflon behind, works very well & doesn't make a mess(I have a different one that goes on the same principle, works great & because I get it at work it's free, ). Yodace, when you should clean your bearings will vary by what surfaces & conditions you drive in, but you should check them after every run. If some look like there's some built-up dirt, then spray them out & re-oil them.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-16-2002, 03:53 PM   #1993
TTT......how did everyones racing go this weekend..I didnt get to go
Old 06-16-2002, 05:48 PM   #1994
Super Moderator
Grizzbob's Avatar
Neither did I, I've been a bit short on cash since I had to buy some new tires for my full scale car, so the best I've been able to do has been running one car every other week(& I filed Chap. 13 almost 2 years ago & threw out all credit cards, so I'm stuck with cash only).....
Bob Seay
Go Pokes!!!
Old 06-17-2002, 04:21 AM   #1995
RC Nitro's Avatar
I did better than I expected. Ran TC on carpet oval this weekend. First time on carpet. Wow do you get traction!
Just h ave to get use to that. Broke the rear arm in pratice Now if I could just keep it off the wall........
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
