Old 06-04-2002, 08:41 PM   #1951
TPhalen's Avatar
R/C Tech Charter Subscriber
Ok, the ankle is promising. Just got back from ER and the xrays show no breaks. BUT, the doc said it was severly sprained...he was surprised it WASN'T broken. Wow. Anyway, I'm hobbling around on crutches right now. How the heck am I gonna get my RC stuff to my car, or drive a 5-Speed with crutches???? Sucks. Gotta find a way to the Nats...heh heh
dcracer. I'm using the Irrgang shaft. Weight is comparable (I think the carbon one might be a tad lighter).
Matman03: Nope. The NTC3 suspension is completely different. I guess you could adapt it with ALOT of work, but I really don't think it's worth it...
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 06-04-2002, 10:24 PM   #1952
tony do you have any more pics of you electric cars? Possibily your tc3?
Thanks,
Drew
teamAE is offline   Reply With Quote
Old 06-04-2002, 10:57 PM   #1953
One more often overlooked option for universals for the TC3.....is...believe it or not....at Integy. Yep....they ONLY have rears...but they do work front & rear.
Rear......no modification.
Front, slightly remove some of the dogbone opening in the front hubs....and it does NOT weaken the hubs.
These are tried and proven....do not bend, break, etc........just clean and lube them out of the package.....and give them a little lube......about every 30 or so packs.......about 20 for you people running mod motors. I lube ALL of my CVD's with AE Green Slime.......works very well.
acloco is offline   Reply With Quote
Old 06-05-2002, 08:31 AM   #1954
TPhalen's Avatar
Drew: Sorry, don't have any more pix o' my cars. I'm trying to take some more, just too darn lazy!!!!
Any particular questions you might have?
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-05-2002, 08:42 AM   #1955
Ya I just got some arms for the front and the rear and they have two holes in them. Are these the new ones? I got the car in a trade and they came with it. They have a shinny plactic look to them. Are you coming to socal sat?
Thanks, Drew
Old 06-05-2002, 01:08 PM   #1956
TPhalen's Avatar
Hmmm. Didnt' think they were out yet. Interesting.
Make sure the car is 190mm wide. The original 200mm gas/rally arms had two holes in them, and are readily available.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-05-2002, 04:48 PM   #1957
Yes it is 190 I don't know umm.
Old 06-05-2002, 10:21 PM   #1958
TigeRyan's Avatar
Send a message via AIM to TigeRyan
Tony,
Just wanted to send along a big Thank you for the tips on assembling the rear-end of the TC3 with respects to the Arms and pins, I did as you instructed and the car only required on small spacer to be put into the left side shock to remove all tweak!!!
Thank you again can't wait to put the car back on the track with it ready to track properly...
John
TigeRyan is offline   Reply With Quote
Old 06-06-2002, 08:16 AM   #1959
TPhalen's Avatar
Cool. Glad it worked. Good luck.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-06-2002, 09:04 AM   #1960
rayhuang's Avatar
Default ONe-way question!!
I am starting this weekend with two-diffs and will switch to a one-way in practice. What are the shock, camber link, etc changes you need to make immediately when making the switch?? I am running on rubber tires on brushed concrete!!!
Thanks,
Ray
Old 06-06-2002, 09:13 AM   #1961
You should go to the stock setup for a bumpy track in the manual and with a one way I usually go stiffer pring up front.
Old 06-07-2002, 09:10 AM   #1962
SpeedTech's Avatar
Hi Guys,
We got a couple sets of the Titanium racing titanium screw kits for the TC3 in stock right now. These are stronger and lighter than the stock screws
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 06-07-2002, 09:12 AM   #1963
TigeRyan's Avatar
Steve,
Was just trying to access your site and getting 404 errors on most sub-pages...
Old 06-07-2002, 01:37 PM   #1964
SpeedTech's Avatar
TigeRyan,
I just checked through the website and it seems to be okay. If you still have problem, feel free to give me a call at:
909-869-9443
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Old 06-07-2002, 02:55 PM   #1965
TPhalen's Avatar
Where they be, Stevo....didn't see them.
Tony Phalen
RCDriver.com
CompetitionX.com
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
