Old 06-03-2002, 10:19 AM   #1936
TPhalen's Avatar
R/C Tech Charter Subscriber
I don't know yet. I have to call (today, hopefully) and get the info...
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 06-03-2002, 10:40 AM   #1937
sponger's Avatar
Well I'm sure you'll post it as soon a you can. Thanks for the help
Sponger
sponger is offline   Reply With Quote
Old 06-03-2002, 03:24 PM   #1938
TPhalen's Avatar
May try to help out as best I can, but now I have a problem. Just (possibly) broke my ankle. Stepped in a hole and twist-snap!!!!
Sitting here icing it right now. In an hour or two, if it's still super sore, I'll be heading to the doctors.
Unfortunately, this will hamper my movement around the house...might not be able to get to some things as soon as I'd like...nor, depending, will I be able to make the Nats.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-03-2002, 03:44 PM   #1939
sponger's Avatar
dude, talk about a bummer you must feel like a kulst I'll call Hot rods, maybe Jimmy knows or if any else out there in cyber space knows what tire and instert combo to run at Hot rod hobbies let us know.
Old 06-03-2002, 05:49 PM   #1940
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
Wild cherry...i thought the new arms were front arms?????
TPHalen......tell em' to put an elevator beside the driver stand.......ya' gotta back up the Reedy result.......
Dragon Slayer is offline   Reply With Quote
Old 06-03-2002, 05:50 PM   #1941
Craig's Avatar
Send a message via AIM to Craig
Tony-what driveshaft is the team guys running?
Craig is offline   Reply With Quote
Old 06-03-2002, 08:01 PM   #1942
TigeRyan's Avatar
Send a message via AIM to TigeRyan
Evening all,
Just got a couple of used TC3's and I am having a problem with the one. It seems the rear end of the car is tweaked really bad, I am unscrewed everyone on the car and the chassis is straight, I even bolted everything onto a new chassis and it is still tweaked....
Here is a list of things I have tried so far...
#1. Rebuilt all shocks and checked and matched length of all shocks
#2. Checked lengths on all tie rods
#3. Checked chassis for straightness
#4. removed all 4 braces and re-assembled
I am at a lose at this point...I have had the car out 3 times to the track and it is fast, actually hanging with some of the real fast guys at our track on the straightaways, but the car is rear end loose in the corners and under breaking and I have to bet it is the tweak in the rear-end of the car...
Well, if anyone has any ideas they would be greatly appreciated...
TigeRyan
TigeRyan is offline   Reply With Quote
Old 06-03-2002, 09:48 PM   #1943
rto997's Avatar
Did you check the bearings in each of the hubs, when bearings go bad the tend to make the car feel like it is tweaked.
Do you have the bearing spacers in between the bearings in each hub??? The spacers are needed to keep the bearings parallel to one another, also to keep from binding when tightening the wheels down.
Just a few of the things that I can think of??
rto997 is offline   Reply With Quote
Old 06-04-2002, 01:51 AM   #1944
Corse-R's Avatar
Default Rear end tweaked? (Maybe can be a a-arm mount messed)
Uhm.... for those steps that you did previously, I bet for a 'classic mess' on the TC3, you maind some interesting info if you dive on the past of this forum (concretely was some thread talking of uneven rear toe-in... Arvid, me and others - sorry, that was 8 months ago, I don't remember all the people who noticed this) I tried to find it. Search for 'uneven rear toe-in' and should be a thread between ends of Dec'2001 and mids of Jan'2002.
Sorry for not giving more info, that's all that I remember about.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-04-2002, 08:20 AM   #1945
TPhalen's Avatar
Craig: Most of the drivers are using the standard carbon shaft, but others, like myself, have gone to an aluminum shaft. Good points: shaft won't break. Bad points: something else will, namely the outdrives the shaft slides into. While I haven't broken one yet, this is, as we figured and seen a few people do, the next weak point.
Also, with an aluminum shaft, you might want to be a little more careful if you DO break the output shaft cup. This might let the shaft slide over and short out the battery. Saw it happen once....not a pretty site. Smoke coming out of the car. Pretty cool if it's not YOUR car
TigeRyan: One of the biggest problems with the car being tweaked is simply BUILDING the car correctly.
First off, shock length is important, but preload is not. You might not have the same preload on all four corners. That's ok, as long as it's CLOSE and the car is tweaked correctly.
Second, you might have to replace the front and rear hinge pin mounts. This is a common mistake with TC3 builders. The object is not to MAKE the hinge pins fit, but to make them fit without flexing the plastic that they seat in. The instruction manual doesn't tell you, but you have to slide the hinge pins into the arm mount, slide the arms on the hinge pins, and then, instead of just forcing the final hinge pin mount on, you have to push BOTH arms toward the center of the car, and slide the hinge pin mount on.
Most builders slide on hinge pin in the mount, flex the mount over and insert the second hinge pin. Bad. That flexes the plastic mount and can certainly cause un-equal rear toe or possibly tweak.
Also, as RTO mentioned, it is VERY important to have the 'crush tubes' installed between the bearing on all four corners. If not, you could overtighten the wheel nut, causing one wheel to not spin correctly. This could also cause handling problems.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-04-2002, 08:31 AM   #1946
linger's Avatar
Tony - dood, sorry to hear about that ankle. I have some titanium plates and screws from a previous job to bolt that puppy back together.
I tried the locked front diff for a while, but I couldn't get the car to turn in at all and running slower overall. I was running 2 front kickup and 2 castor - should I try some thing different?
linger is offline   Reply With Quote
Old 06-04-2002, 08:32 AM   #1947
dcracer's Avatar
Tony, which aluminum shaft are you using. How does it compare in weight to the stock shaft.
dcracer
dcracer is offline   Reply With Quote
Old 06-04-2002, 08:37 AM   #1948
Send a message via AIM to Dabeejrc
Default TC3 parts
If you want good CVDs get the MIP Shiny or Aluminum. Also, I think there is a Factory Team TC3 so go for one of those
Dabeejrc is offline   Reply With Quote
Old 06-04-2002, 08:41 AM   #1949
sponger's Avatar
Tony hows the ankle??? are you going to make it to the nats???? I called Hot Rod's they said Sorex 32, 36, 40s with hpi green and blue inserts. Hope to see ya at Rod's
Old 06-04-2002, 12:42 PM   #1950
Send a message via AIM to Matman03
How does the aluminum driveshaft's weight compare to the composite? Has anyone use the titanium driveshaft on the market?
And one last question, does the pivot ball suspension from the NTC-3 bolt on to the TC-3? Thanks
Matman03 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
