Old 09-16-2001, 10:20 PM   #181
TC3Racer's Avatar
Send a message via AIM to TC3Racer
the steel dogbones wont help. I have seen steel ones turned into twizlers on the serpent impulse
TC3Racer is offline   Reply With Quote
Old 09-17-2001, 01:18 AM   #182
Corse-R's Avatar
Originally posted by MattW
Can anyone tell me the measured length of TC3 shock shafts??
The shock shaft on TC3 is 0.56". If you run the TC3-R the shock shaft is 0.71".
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 09-17-2001, 07:07 AM   #183
TPhalen's Avatar
R/C Tech Charter Subscriber
RE: Breaking dogbones while using the one-way.
The biggest problem is when either front wheel becomes unloaded, typically while turning. The inside wheel begins to spin at a MUCH higher rpm and when it settles, the shock of it touching the ground tends to snap the CVD. Associated has cured the problem by releasing thicker CVD's. There are quite a few thin ones still in circulation, so, when you buy new ones, just check to make sure you're getting the thicker ones. Also, make sure the little o-ring is also installed in the one-way drive cup.
Hope this helps.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 09-17-2001, 10:26 AM   #184
Send a message via ICQ to MattW
Yeah i wondered what the "actual physical length" was to be honest.
MattW is offline   Reply With Quote
Old 09-17-2001, 01:06 PM   #185
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Are you talking eyelet to eyelet? If that is the case, that number does not sound correct.
wolfeman09 is offline   Reply With Quote
Old 09-17-2001, 01:46 PM   #186
Corse-R's Avatar
Nope... I'm talking about the lenght of the shock shaft (please, take a minute to re-read my posting) the lenght of the shock should vary depending what type of shock cap you're using: Associated plastic, Associated aluminium or the Yokomo shock cap (the one with a small screw on it to adjust the air into the shock).
Cheers,
Corse-R
Old 09-17-2001, 01:48 PM   #187
Corse-R's Avatar
I solved partially this problem using the IRS pins on my CVD's
Cheers,
Corse-R
Old 09-17-2001, 02:52 PM   #188
ovalnator's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to ovalnator
wow....posted my message and 4 more appear RIGHT after it...
don't you people work??? ahhaha, oh, ya, i'm at work too...heh heh
Tony, its not like we have anything better to do!!!! We also want to know all those speed secrets you got!!!!!
ovalnator is offline   Reply With Quote
Old 09-17-2001, 02:59 PM   #189
TPhalen's Avatar
Well, ask away. I will have alot of good info on my site soon. The "Tips From the Pros" section is almost done. I'll let you know when it is....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 09-17-2001, 03:26 PM   #190
JOHNNY RACER's Avatar
Default NOT A SPEED SECRET QUESTION,BUT.......
does anyone know if the speedtech dishes are dyeable?
JOHNNY RACER is offline   Reply With Quote
Old 09-17-2001, 04:55 PM   #191
TC3Racer's Avatar
If they dont have coating on them like the rpm wheels do, then it should be dyable.
Old 09-17-2001, 05:10 PM   #192
you mean like a clearcoat type of coating? they're not as shiny as the ofna dishes.
Old 09-17-2001, 07:28 PM   #193
robk's Avatar
Trader Rating: 22 (100%+)
skar tisu-
Foam Mod-
oil 70 f 50 r
droop 6 f 4 r (i'm sure you could go less, still trying stuff)
spring white or yellow f blue r
swaybar front only
shock mount middle hole (all the way in in the rear for more bite)
camber link up, in all around
caster 4+2
battery split or back, some guys like the 2+4 split
4.5mm ride ht
full time 4wd
toe 1* out f 3+2 r
TRC plaid f purple r
Also, for the one way guys-
On carpet with rubber the diff is usually really good in stock. Not everybody likes it for mod. The center shaft car be helpful when you're not comfortable with the diff oneway, or if the traction isn't good, old carpet whatever.
On foam you can get into trouble with the oneway diff. The amount of front end traction can give you wierd traction rolls, especially at big races. Generally not good. The Center shaft can work well in stock, but few people like it for mod. Foam tires makes the car drive really hard into the corners, and the oneway takes away some of your ability to battle, and makes the car a bit incosistent for mod.
robk is online now   Reply With Quote
Old 09-17-2001, 08:26 PM   #194
RacerTex's Avatar
Default Bearing Maintenance?
Just rebuilding my car after Saturday's racing - full rebuild and I noticed that my rear outer wheel bearings were almost siezed. I could bearly get them to move. One of the rear inner wheel bearings were in sad shape too. I've "touched" a board or two every race day but I'm not a hack (at least I think so) and people have hit me too. I'm an A main qualifier most of the time. Funny thing is that the front bearings are still in great shape.
Question: Is anyone seeing similar issues? Do the rear wheel bearings just take a beating? Any tips or tricks on maintenance. Also, what is the best method for removing bearings from the hub without messing up the bearing races? Finally, what brand bearings are the best (strong and smooth)?
RacerTex is offline   Reply With Quote
Old 09-18-2001, 07:12 AM   #195
TPhalen's Avatar
Is your car a FT, Team, or a Racer kit? If it's a FT (or I think the Team, also), the kit will include 'bearing spacers'. These little gems fit between the bearing IN the hubs. It's possible you've over tightened the wheel nut to clamp down on the bearing. This will definitely overheat the bearing and cause it to seize up. Just one possibility.
Something else to check. If your rear hubs are cracked, this could mis-align the bearings, causing the axle to sit funny in the bearings. I've seen someones car with that, also. That's a little more noticeable, though.
Tony Phalen
RCDriver.com
CompetitionX.com
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
