Old 05-20-2002, 11:57 AM   #1876
Dingus's Avatar
Go to Tony Phalens site and try the Kinetix setup. I personally saw him run with a 10 turn and he was super fast!
www.competitionx.com
Dingus is offline   Reply With Quote
Old 05-20-2002, 02:48 PM   #1877
thanks for the link but I need other setups and for
rubber tires
Super38 is offline   Reply With Quote
Old 05-20-2002, 07:13 PM   #1878
shrekair's Avatar
Trader Rating: 9 (91%+)
when we ran mod rubber it was something like this
front
either 50 or 60wt #2 piston
red spring
2 deg kick up 2 deg castor blocks
shocks in inside hole on shock tower
no bump steer
camber - 1.5
rear
either 40 of 50 wt #1 piston
blue spring
2 deg kickup 3 deg toe in.
inside hole on tower
camber 1.5
hope that helps
shrekair is offline   Reply With Quote
Old 05-21-2002, 06:29 AM   #1879
TPhalen's Avatar
R/C Tech Charter Subscriber
51: I'll be running Open Mod. I think there will be some international guys there, but probably not as many as normal. Everyone is really beat from the double worlds.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 05-22-2002, 05:39 PM   #1880
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
evening.....ttt
Dragon Slayer is offline   Reply With Quote
Old 05-22-2002, 06:14 PM   #1881
I am just getting my ft tc3 and woundering if the irs chassie is any good for aspult, high traction at socal
teamAE is offline   Reply With Quote
Old 05-22-2002, 06:21 PM   #1882
Dingus's Avatar
I have never used one.
Some people really like them, but from what i have heard they rarely make it into the A-main at big events.
PM me if you want to know where the best price is...
Old 05-22-2002, 09:36 PM   #1883
rcruv's Avatar
Anybody seen this or knows if somebody's selling it.
Looks very similar to IRS chassis.
rcruv is offline   Reply With Quote
Old 05-23-2002, 02:51 AM   #1884
blueboy's Avatar
hmm the chassis is nice, but i dont like the pink anodizing, or the lack of battery strap. The transponder mount looks very similar to the IRS one, but the IRS kit has a batery strap not tape.
blueboy is offline   Reply With Quote
Old 05-23-2002, 03:46 AM   #1885
Corse-R's Avatar
Uhm.... maybe can be the KAI's chassis for the TC3, maybe some of Japan can put some light on us about this chassis.
Looks good, I'm so tired of too much blue (sheeeeesh!) maybe some green can be ok.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-23-2002, 09:26 PM   #1886
rcruv's Avatar
They really love pink, don't they?
I heard that the chassis is from hotbodies but nobody knows if it's being sold or not.
Old 05-24-2002, 01:48 AM   #1887
blueboy's Avatar
Just looking at teh electronics on that chassis and it seems that there are two huge capacitors on the speedo, but also a small one on the receiver - what does a cap do for the receiver?
Old 05-24-2002, 08:04 AM   #1888
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Normally, I agree with you on that, but in the case of the TC3, the battery side of the car is heavier than the motor side, so less weight by the elimination of battery strap and posts would be a good thing. Anyone who has ever set their TC3 up on a digital scale setup board knows this to be true. If you look at many of the pro level racers, they like to put weight in the little slot beside the motor, or they somehow lose weight on the battery side of the car to balance it out.
BigDogRacing is offline   Reply With Quote
Old 05-24-2002, 08:43 AM   #1889
blueboy's Avatar
I agree with you about the weight issue BigDog, but I was merely giving a personal opinion; I would much rather have the battery strap and pins than have to tape the cells in, and use new tape every time. Its a laziness thing...
Old 05-26-2002, 12:54 PM   #1890
Regional Moderator
Send a message via AIM to Mike F
I have a question for anyone to answer.
My front MIP CVD's are binding. I pulled them out. completly tore them down and noticed that the coupling that fits inside the axles, even when I re-greased it, seem to bind, bad. Any suggestions on fixing this? Should I put the coupling to a dremel and smooth it out? Has anyone experience this?
Mike F is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
