Like Tree4Likes
Old 05-15-2002, 03:32 PM   #1861
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
Shrekair................Go to the Associated site or to TPHalens site...they have lotsa of setups there.
Dingus......havent picked up the center 1 way yet...still workin' with the front 1 way.
Dragon Slayer is offline   Reply With Quote
Old 05-16-2002, 07:46 AM   #1862
shrekair's Avatar
Trader Rating: 9 (91%+)
yeah they have setups but i wanna know what everyday racers have change on those setups of if they have found something different.
shrekair is offline   Reply With Quote
Old 05-16-2002, 08:02 AM   #1863
Dingus's Avatar
Go to Tony Phalens site for great setups.
If there is any tinkering, it is usually to adjust to individual driving style. Only you can do that. Just make one change at a time and see what you like.
I run his setup on carpet. I only changed the front tires to plaid and added a rear swaybar. I am not skilled enough to handle as much steering as T.
Dingus is offline   Reply With Quote
Old 05-17-2002, 04:14 PM   #1864
TTT
Old 05-18-2002, 07:39 PM   #1865
rcruv's Avatar
Congratulations Barry Baker, Billy Easton and other Associated drivers!
It was awsome.
rcruv is offline   Reply With Quote
Old 05-18-2002, 08:19 PM   #1866
Peter Busch's Avatar
R/C Tech Charter Subscriber
How close does your rear shock springs come to the cvd? I'm building another TC3 and I dont remember this on my old one.
Peter Busch is offline   Reply With Quote
Old 05-18-2002, 08:34 PM   #1867
dcracer's Avatar
I use composite CVD's and the springs almost touch the CVD's. The do not touch through out the entire range of motion however.
dcracer is offline   Reply With Quote
Old 05-18-2002, 09:02 PM   #1868
Trader Rating: 67 (100%+)
i also have composite cvd's that are very close to the rear springs. i just add a couple of washers on the screw that holds the lower ball end for more clearance. or put the rear hub spacers in the rear position (short wheelbase position) but this may slightly affect handling if youre using the standard or long wheelbase setup.
marvi is offline   Reply With Quote
Old 05-19-2002, 07:59 AM   #1869
I ended up using a small spacer to move the shock out a little. I never remembered doing this on my old one though.
Old 05-19-2002, 04:22 PM   #1870
shrekair's Avatar
i never had that problem either, what gives? did they mold slightly different arms?
Old 05-19-2002, 05:45 PM   #1871
dcracer's Avatar
I think it is a question of very close tolerances rather than an actual problem. The springs on my FT come ever so close to the cvd's without actually touching.
Old 05-19-2002, 05:53 PM   #1872
I guess I never noticed it untill now.
Old 05-20-2002, 06:11 AM   #1873
maybe the newer cvd's are thicker. i think both the aluminum and composite cvds were slightly increased in diameter to resist breaking
Old 05-20-2002, 07:54 AM   #1874
51
51's Avatar
Tony: Hey what class are you running at the Reedy Race? Any new info about the race that I should know? Do you know if all the international guys will be there?
51 is offline   Reply With Quote
Old 05-20-2002, 11:52 AM   #1875
Default setups
attn modified drivers:
been trying modified lately and want to try other setups
setups will be for carpet ozite 10x2 motor rubber tires
around 50ft-75ft straights.
any suggestions
thanks for the replies
Super38 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
