Old 05-12-2002, 10:03 PM   #1846
littledog's Avatar
R/C Tech Charter Subscriber
The hudy set up board will work with any 10 th scale.I own a hudy set up and it works great for me.
littledog is offline   Reply With Quote
Old 05-13-2002, 02:59 AM   #1847
Trader Rating: 62 (100%+)
thanks for the replies
marvi is offline   Reply With Quote
Old 05-13-2002, 10:28 AM   #1848
Impreza's Avatar
Send a message via ICQ to Impreza
Thanks littledog!!!
Impreza is offline   Reply With Quote
Old 05-14-2002, 03:59 PM   #1849
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
Anybody get to race this weekend?????I didnt ...how did ya'll do???
Dragon Slayer is offline   Reply With Quote
Old 05-14-2002, 04:05 PM   #1850
littledog's Avatar
Yea!I went tp the quarter mile track and did a 14.80 in a stock saturn sl2 with a 25 shot.Not bad for 4 bangger.BTW You know memphis's track sucks.There are too many whoopty dooes past the 60 foot mark.
Old 05-14-2002, 04:12 PM   #1851
littledog's Avatar
Adding the 75 shot to it as i type and heading out to the track to see if I can get an even 14.I just can't seem to blow this thing up.I'll get too tonite though,I hope.
Old 05-14-2002, 04:16 PM   #1852
Dingus's Avatar
Hey Dragon,
Did you ever get your hands on the one way?
I finally ran mine. To be honest, I really didn't notice much difference with the center one way. Maybe too much on power time on the carpet? Ill have to try again in a couple of weeks, goin truck racin this Friday in Killeen. Is there a T3 thread somewhere?
Dingus is offline   Reply With Quote
Old 05-14-2002, 05:10 PM   #1853
Bullseye's Avatar
Send a message via AIM to Bullseye
Originally posted by Dingus
Hey Dragon,
You really didn't notice that much of a difference when you changed to a one way in your TC3? Wow, I noticed a big difference. Especially when I tried using the brakes..
I really like the one way.. Makes the car pull real nice out of the corners..
Bullseye is offline   Reply With Quote
Old 05-14-2002, 05:45 PM   #1854
Dingus's Avatar
Well, I would expect a bigger impact with a front one way diff, but I have the center one way from GPM. I ran on a fairly tight ozite track in stock so not really much need for the brakes. Even then, there is enough traction to get brakes anyway. Might try the front one way diff, but I'm afraid of parts breaking too often for my modest budget.
Old 05-15-2002, 01:33 AM   #1855
over gear's Avatar
Trader Rating: 15 (100%+)
What's the diameter of the TC3 hinge pins? i'm looking for a drill bit of the same size... the suspension is binding a bit....
over gear is offline   Reply With Quote
Old 05-15-2002, 05:52 AM   #1856
Dingus's Avatar
I had the same problem, but solved it by sanding/filing the sides of the arms, not the insides.
Old 05-15-2002, 07:50 AM   #1857
shrekair's Avatar
Trader Rating: 9 (91%+)
can people post some current setups for the car? foam and rubber
shrekair is offline   Reply With Quote
Old 05-15-2002, 09:23 AM   #1858
over gear's Avatar
the hinge pins just don't line up perfectly. i a little drilling will make everything perfect...
Old 05-15-2002, 09:27 AM   #1859
Dingus's Avatar
what do you mean by line up? In the front or back?
Old 05-15-2002, 09:44 AM   #1860
Dingus's Avatar
Don't drill yet!!! If its in the back, they don't seem to line up because that is how the rear toe-in is set. You gotta pull those bad boys apart a little to get 3 degrees. Seems unnatural at first, but that's how it works. Drilling new holes in the rear hinge carrier will cause HUGE handling problems.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
