TC3 Forum
#1786
TPHalen......okie dokie......
Dingus.....we have some peeps running mod foam, and if i get a second car, will do so myself.
#1788
We have a pretty good 19t class now. Lot of guys are getting bored with stock due to the high traction easy to drive thing. Might just try it myself soon. Looks like fun!!
#1789
TP - Thanks for helping me with diff adjustment.
Wow, my car now turns automaticaly through the corners.
I've now had it with composite bones. I'm going for MIP shiny bones.
It doesn't matter if I try not to hit anything if somebody just keeps hitting my car out of nowhere and breaks dogbones.
I wonder what will break with steel bones. A arms? Carriers?
Nontherless, racing is FUN !!!
Happy racing guys.
Happy racing guys.
#1790
Super Moderator
Actually, with steel CVD's, I'd say the next weakest link would be the main driveshaft. I've had friends who tried shiny CVD's with a front one-way & they ended up breaking main driveshafts. Personally, I can put up with changing CVD's, & the cost of the composite ones are much easier to deal with. And if I can't afford to do that, then I'll just use the shaft one-way, & use a regular diff up front.....
#1791
Would Ti drive shaft cure that problem?
Then what do you think is the next victim?
#1792
Chassis braces
Has anyone tried TC3 without the chassis stiffening braces? I assume that this modification would let the chassis flex a little bit more. I`m starting outdoors season and I think that flex is sometimes good for tarmac. If someone has tried this, please tell me your experiences.
#1793
I broke a Front plastic outdrive saturday. I didn't even hit anything?
In body have any thoughts about way it broke? Please let me know.
#1794
Were you running stock or modified. It's possible it was stressed from a previous hit.
#1796
Just built the car.
Somebody at the track told me that I front diff to tight and thats why it broke the front diff outdrive?
#1797
I was running stock?
#1798
If you over tightened the diff it is possible to stress the plastic to point of breaking, and power being applied to it would be enough to finish breaking the outdrive.
#1799
Any suggests on how to solve the problem ?
#1800
I just basicly follow the instuctions for building and tightening the diff. Once the diff is in the car, I hold the front wheels and try turning the spur gear, and adjust it so that it does not slip. Then do the same for the back.
