Old 10-08-2009, 04:53 PM   #1231
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
I say "YUK" to the friction shock.. but everything else looks pretty good under the hood
and the bodywork and wingset is beautiful!
akura2 is offline   Reply With Quote
Old 10-08-2009, 07:03 PM   #1232
Wow I caught a shot in one of the pictures of the steering wheel and they even have all the pushputton switches on it.
The company I work for in Carpentersville llinois supplies those switches on the real F1 car. There are seven on each side AND the switches for the paddle shifter as well. They are off the production line that I am the Engineer for. We also supply the steering wheel switches for the new Audi R10 as well as several kill switches for NASCAR.
Bob Oaks
bob o is offline   Reply With Quote
Old 10-08-2009, 07:12 PM   #1233
zpmhinojosa's Avatar
Send a message via AIM to zpmhinojosa
zpmhinojosa is offline   Reply With Quote
Old 10-08-2009, 07:21 PM   #1234
Default The Gehrage
Old 10-09-2009, 12:06 AM   #1235
gsxr0311's Avatar
Trader Rating: 18 (100%+)
im a hamilton fan but dam that ferrari looks good. i do love ferrari but not the two current drivers. well i guess masa is ok. i will definitely get the f60.
i finaly got my low friction suspension ball set, man the suspension is way smoother. my original sus stuck and made noise. hopefuly ill get some better handling.
gsxr0311 is offline   Reply With Quote
Old 10-09-2009, 02:35 AM   #1236
ali_g's Avatar
Originally Posted by Smokem Racing View Post
Hi everyone. We understand some people have been having problems getting their F104's to stay with the F103's on the track. We believe this is largely due to the narrower rear tires which is 10mm narrower. We have found that running the wider F103 rear tires makes quite a difference. But it makes the rear end much wider than the front.
So we have developed a set of option front axles for the F104 (and F103). This will allow you to widen the front end on the F104. So you will have the same width front and rear if you choose to run F103 rear tires. They will be machined from titanium for super light weight and strength. We estimate the price to be approximately $15 a pair and should be ready in the next few weeks.
Happy racing!
Hi
To run the f103 rears u are using the 104 rims?? and wat is the effect of running wider rear tyres?
ali_g is offline   Reply With Quote
Old 10-09-2009, 04:25 AM   #1237
cheROK1212's Avatar
Bob Oaks
Windsor and Andersons' premise for starting USF1
...hold my 'stones.
cheROK1212 is offline   Reply With Quote
Old 10-09-2009, 05:23 AM   #1238
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by ali_g View Post
Hi
You the run F103 rear rims and tyres. They are 10mm wider than the F104 rears. Wider rears give more traction and make the car less twitchy.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 10-09-2009, 08:09 AM   #1239
fat500's Avatar
Trader Rating: 27 (100%+)
I wonder if the airfoil ft lower suspension arms will add downforce to the front of the car or is it designed to direct the air under the chassis making the rear diffuser work better? Hmmmm from the pics they look as if they would almost lift the ft end any clarification? ideas?
fat500 is offline   Reply With Quote
Old 10-09-2009, 08:16 AM   #1240
Love that F60! But, I am a McLaren and Red Bull fan so I hope Tamiya comes out with those bodies by spring. Probably will depend on licencing rights though.
Team Lotus is offline   Reply With Quote
Old 10-09-2009, 09:36 AM   #1241
akura2's Avatar
It's already in the Japanese Magazines!!...
Old 10-09-2009, 12:39 PM   #1242
Arthur Burns's Avatar
Great - that is the ONE hop-up I didn't order! Just noticed that the stock ones are plain old nylon.
X-Ray T2 '06 - Novak GTX/Spektrum 3100
Tamiya F103 RM - Novak XBR/Spektrum 300 (currently with Protoform Mulsanne body)
Tamiya F103R - Tekin FX Pro/Spektrum 3000
Tamiya F104 Pro - Tekin Fx/Spektrum 3500
Axial SCX10 - HPI Bronco Body - Tekin FX-R/Tekin 45T / Ubiquitous Slash - Stock
Arthur Burns is offline   Reply With Quote
Old 10-09-2009, 12:48 PM   #1243
I'm a huge Ferrari fan, and have to say that is SWEET, but it sure does look like a "one crash" nose on that F-60 body... Adds to the realism I guess!
Old 10-09-2009, 07:20 PM   #1244
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
So I spent the afternoon shaking the 104 down on the carpet at MSI Raceway here in Detroit. Through trying different combos, I was able to find almost a full second from the first pack to the last. Tried a lot of different things and then combined changes to get a car that would rotate nicely in the corners, while at the same time was not on the ragged edge. I have not run on the carpet since the Trackside TCS race back in March,and I only raced once this summer, so I was shaking out the cobwebs. First impressions were pretty in line with the other posts on here. I started pretty much stock , and the car had a ton of grip, too much really, it was actually bogging in the corners and losing a lot of momentum. I changed over to the B compound foams and while it still had a lot of grip, it had enough slide that it wasnt losing as much speed. I had my 103 with me to do some back to back stuff, but I didnt realize that I had put a broken motor i the car, so that didnt last long. I ran a 55-56mm rollout as DJ suggested and it seemed to be pretty good, I wasnt runing my best motor, but the car still felt pretty quick.
Im not going to give up all the stuff that I tried, but suffice to say that minor adjustments can pay major dividends with this chassis.
I tried three different springs starting with the kit red, going up to a blue, and then settling on a yellow. Silver springs up front and a little stagger in ride height. I want to continue to try some different stuff to settle the tail down a bit. I haven't checked tire wear yet, but at first glance it doesnt look to be bad. Will report out when I get a chance to take a measurement.
But for a first run, with very little tuning, I was very happy, and I think shes got an easy half a second in her with little to no effort.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 10-09-2009, 10:38 PM   #1245
BP SHADOW's Avatar
So I checked the tire wear, the stock foam is down about 1mm from where I started, and the B compound is down less than 1/2 a mm. Not bad for a day of running
I think I ran 3 packs today
I was pulling the car off after a few laps to make changes, so im not sure i ever did a full 5 minute run
http://f1rclab.com
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
