Old 10-04-2009, 05:08 PM   #1111
barts71m's Avatar
Trader Rating: 34 (100%+)
Well after the weekend am now a proud owner of a F104pro....bout to take her for a spin hopefully the weather holds up.
barts71m is offline   Reply With Quote
Old 10-04-2009, 06:10 PM   #1112
geeunit1014's Avatar
Originally Posted by akura2 View Post
Thanks for the info... the battery I'm using doesn't have the little "dip" in the front.... Notching the chassis was the only was I could go with mine....
BTW... I drove my car at Bending Corners Raceway yesterday (outdoor asphalt medium to high grip) for the first time and my car didn't have any of the "problems" people have been complaining about.... my car is silver can, with the smaller stock spur gear.... I drove it with the rear spring removed with the stock t-bar...
The car was straight as an arrow on the back straight... and the only thing I noticed was that it had some high speed understeer (not necessarily on power, just higher speed). low speed oversteer... but after a lap or two, it was really easy to get used to and compensate for... rear end was planted
Sight toe-in, stock tires, rear spring removed, stock t-bar, Team Orion 3400, Spektrum 3500, Novak XRS, negative camber setting, no tire additive....
if anyone has any ideas about the over/under steering issue, I'm all ears.. but other than that... the 104 is a keeper....
The battery im using is the IP5000, its taller than the orion packs(or just about any other pack). You may want to see if it will work for you.
Originally Posted by fat500 View Post
I am in need of a second f104 . If you have one pm me . Thanks, fat
mint cond and paypal please or new
How much are you looking to spend? Mine has been raced twice.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-04-2009, 09:00 PM   #1113
TFR
TFR's Avatar
Can't wait...
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 10-04-2009, 09:01 PM   #1114
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Originally Posted by veecee View Post
Good to hear you have the F104 working well. When are you getting the understeer and oversteer - turn in, mid corner or exit? I would try tightening the friction damper a little (or maybe a slightly thicker grease) and maybe even a softer front spring (silver).
I get the under/over during mid corner.... I'll try fiddling with the friction damper (only a little as my car is 80% there and I don't want to mess anything up)...
I was thinking about getting the Option B tires since it has been mentioned that on asphalt they give more grip... so maybe I'll get a little more control
thoughts?
akura2 is offline   Reply With Quote
Old 10-04-2009, 10:04 PM   #1115
RonF's Avatar
Originally Posted by TFR View Post
Can't wait...
That pic is awesome! Where did u get the info? didnt see it on Tamiya site. I may have to save up for this (f104 sport) when it comes out....
RonF is offline   Reply With Quote
Old 10-04-2009, 10:23 PM   #1116
veecee's Avatar
thoughts?
I think the optional tyres would be worth trying. I'll definitely be getting some once the wheels are available again from rcmodel. I'm getting a bit of mid corner understeer in longer medium speed corners too. But that's running soft T-bar and soft front springs (silver).
I am not seeing much benefit in running the soft T-bar when I'm not using a shock spring. So I will probably go back to the std T-bar but keep the soft front spring.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 10-04-2009, 10:39 PM   #1117
akura2's Avatar
About halfway down
http://sudacolumn.cocolog-nifty.com/
http://www.mia-f1.com/
there are even 2009-style Mini-z F1s.... this is a good year
Old 10-04-2009, 11:02 PM   #1118
gsxr0311's Avatar
Trader Rating: 18 (100%+)
man that thing looks good. guess i gotta have 2 f104s. one for bashing and one to race.
gsxr0311 is offline   Reply With Quote
Old 10-05-2009, 12:27 AM   #1119
barts71m's Avatar
Gave my car a bash today on a dirty race track and apart from losing control and ending up in a massive puddle had a blast with it. The Tamiya 12t brushless might be a little much for it though. Cant wait to try it on a grippy surface.
Old 10-05-2009, 12:31 AM   #1120
akura2's Avatar
It looks GREAT... I wish Tamiya would have included the "bar code" decals though...
they should have since it doesn't actually say "Marlboro"
Old 10-05-2009, 12:43 AM   #1121
Oortael's Avatar
Get a pack of 53539 - 0.5, 1, 2 and 3mm spacers.
But they have an inner diameter of 3mm. For the steering knuckels I need some with an inner diameter of 5mm.
Oortael is offline   Reply With Quote
Old 10-05-2009, 02:37 AM   #1122
veecee's Avatar
Oops, read it wrong. You want the axles spacers for the wheels... I thought you wanted the spacers for the steering knuckle.
Old 10-05-2009, 03:26 AM   #1123
ali_g's Avatar
Can't wait...
any idea on the official release date?
ali_g is offline   Reply With Quote
Old 10-05-2009, 03:39 AM   #1124
veecee's Avatar
December according to Tamiya website.
Old 10-05-2009, 05:13 AM   #1125
Oortael's Avatar
Well, my technical english is not so good. But thanks for your suggestions.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
