Old 09-30-2009, 02:57 AM   #1051
Oortael's Avatar
I'm wondering what the people have expected when they bought their F104.
It's wheelbase is grater, has smaller tread and narrower tires in the rear.
Based on these conditions:
1. If you run the car out of the box, it will be slow in corners and fast on straight lines.
2. Acceleration must be charched well.
These Advanteges/Disadvanteges are charactaristics of the design of the car, which depends on the look of the latest F1 cars.
So I guess that a F104s can beat F103s on a high speed track with lots of staight lines and will loose most of the races on a track with lots of corners.
My conclusion is to go with that or change to a TRF416 or something.
But I definitely won't spend 500 bucks for a rc car.
Oortael is offline   Reply With Quote
Old 09-30-2009, 03:46 AM   #1052
heretic's Avatar
Originally Posted by mugler View Post
Holy moly, Kyosho had it goin on back in the day! they really need to jump into F1 again, if they do it will really jolt the F1 scene.
For the electric version go to minute 1:27:
http://www.youtube.com/watch?v=Utjh4r7WYXE
Nice video and music...
Kyosho also had a 1/10th pan car f1 , named "impress". Don't know if it made it to the market though... I saw it in a kyosho catalog ten years ago at least (it had yellow and black panasonics in it !)
It had an ugly plastic front upper plate but if I remember well it had a fully adjustable front end la trinity sv10 or speedmerchant rev5
heretic is offline   Reply With Quote
Old 09-30-2009, 04:18 AM   #1053
heretic's Avatar
double post
Old 09-30-2009, 09:00 AM   #1054
robk's Avatar
Trader Rating: 22 (100%+)
Old 09-30-2009, 10:28 AM   #1055
JayL's Avatar
I highly doubt the F104 was designed with lipo in mind, especially since they don't run it in Japan.
JayL is offline   Reply With Quote
Old 09-30-2009, 10:44 AM   #1056
rtypec's Avatar
Lipo friendly upper deck is in the works
*edit* or maybe not
rtypec is offline   Reply With Quote
Old 09-30-2009, 01:55 PM   #1057
gsxr0311's Avatar
Trader Rating: 18 (100%+)
well i thought just like everybody else that if tamiya released a new f1 car it would be better than the old one. is that not the point of releasing something new ? pretty much everything in todays society that is new was made with the intent of it being better that the previous one unless otherwise stated. some how i thought the new longer narrower car would be better than the old. i guess i assumed tamiya did their homework and made a better out of the box car than the 15th anv f103. they even called it the pro version. so does that mean the next version will be slower because its not the pro.
i am excited to get my paws on the f60 because of the scale looks but i dont expect it to be any better.
gsxr0311 is offline   Reply With Quote
Old 09-30-2009, 02:05 PM   #1058
linger's Avatar
*edit* or maybe not
from Tamiya Japan, Tamiya USA or Other.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 09-30-2009, 03:19 PM   #1059
Trader Rating: 26 (100%+)
Fat500 - thanks for the set up tips, I will try them.
I am still trying to understand the different adjustments and what the effects are. So if someone has the time, please define these adjustments and effects.
I am new to pan cars and having a problem finding tuning tips on the F104. I raced this weekend and I was totally lost on what adjustments to use to correct the problems I was having, Example - end of straight into sweeper I experienced a serious push among other things. I was hoping someone could give me the basics regarding the effect on some of the adjustments available.
1) Shock adjustment - tighter vs looser
2) Damper - tighter vs looser
3) Front Springs - Silver vs Gold vs Black
4) Rear Ride Height - Lower vs Higher
5) Camber - 1 towards rear vs 2 towards rear
6) T Bar - Stock vs Soft Option
7) T bar - Pivot joint loose vs tight
8) Shock Oil - heavier vs lighter weight
svines1972 is offline   Reply With Quote
Old 09-30-2009, 06:45 PM   #1060
MaxSp97's Avatar
This from Team X-Ray link:
http://www.teamxray.com/teamxray/pro...ame=XRAY%20XII
Read the Setup Book.
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 09-30-2009, 07:15 PM   #1061
rtypec's Avatar
Originally Posted by linger View Post
I am one slo mo fo
Pictures of an upper deck
Old 09-30-2009, 07:36 PM   #1062
veecee's Avatar
Trader Rating: 34 (100%+)
I'll try and explain based on what I have learnt over the past few months...
Spring preload for rear. This will alter how the rear end compresses under acceleration and over bumps. So the looser it is, the easier it is to compress although the spring rate itself is not affected. So looser will give more rear traction and therefore less steering.
Control how quickly the rear pivots from side to side - ie response under roll (and under certain bumps). Looser will therefore give more rear traction but will also be slower when changing direction quickly.
Silver is soft (more steering), Gold is med and Black is stiff (less steering).
Higher will transfer more weight to the front and generally give more steering.
Affects tyre wear and steering response. 1 towards rear is 0 deg and 2 is -1 deg (as per manual). -1 deg should give make tyre wear more even and give a touch more steering most of the time.
Stock is stiffer tan Soft. So stiff will make the rear end stiffer in roll, under acceleration and over bumps which reduces rear traction.
Initial response of the rear end. Looser will make the rear end stick better.
Control how quickly the rear compresses fore and aft - ie response under acceleration and bump. So heavier will generally give less initial traction.
The biggest thing to remember is that anything to do with the T-bar will affect both cornering and acceleration. Whereas anything on the shock will not really affect cornering (apart from acceleration out of corner). This is why not running a shock spring seems to work well.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 09-30-2009, 09:56 PM   #1063
SRBMOJO's Avatar
Trader Rating: 67 (100%+)
I want one, is this something you made, or is a Tamiya part?
Steve
ALL TAMIYA 4 WHEEL DRIVE ALL THE TIME
TRF-416X, SP CIRTIX, LRP X-12 17.5, FUTABA 9550
SRBMOJO is offline   Reply With Quote
Old 09-30-2009, 10:02 PM   #1064
Originally Posted by cyclone x View Post
anything i should know about this car that breaks or anything
spur gears, I have gone through 3 already, maybe due to all my crashing but it annoys me incredibly.
I also lost this: TAMIYA 4035046 F104 FRICTION DAMPER POST ADJUSTER NUT
I've seen others lose theirs on the track as well, I caked mine with anti-wear grease this time, hopefully that will keep it on.
torg is offline   Reply With Quote
Old 09-30-2009, 10:06 PM   #1065
Originally Posted by Ekim81 View Post
Qestion to those running LiPo stick packs in thier F104s; Did you have to mode the chassis or the battery mounts at all to get it to fit? I tried fitting a hard case LiPo stick pack and I could not seem to get it to slide all the way in with the factory battery mount. Am I just dumb or do I need to change something to get this to fit?
I use this battery and had to use my pliers a little on the battery plate (the one with the two snap pins). Nothing major.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
