Like Tree4Likes
Old 03-16-2017, 12:15 PM   #9346
Djchow85's Avatar
Originally Posted by viking44 View Post
Why would you dremel it? You can just uscrew the post when you want to remove the battery. Those posts can be removed or added to tune the flex of the chassis. Dremel it ouy and you won't have that option anymore.
For easy release of battery
I don't use the front posts anyways since running on low bumpy asphalt and most likely won't be running on med/high traction any time soon. Also had this idea since I think the Pro by deafult - the top deck doesn't extend that far?
Lancer Corolla 3 Impreza
Djchow85 is offline   Reply With Quote
Old 04-19-2017, 12:39 AM   #9347
Hi guys,
I have a problem with the gearing on my car. I now run a 32T pinion / 60T spur combo, 48 pitch. The 60 spur I made myself but it doesn't last. I would love to run my 70T Exotec spur, but that would mean I need to run a 36T pinion and the combo won't fit the standard motor mount. I also found some 66T spurs but they hold a lot less balls and would still require a 35T pinion, I doubt that would fit.
Now I am not married to the standard mount, what options do I have? Our track really requires a 1.9 FDR and no-one else runs an F104, the other cars I saw seem to have more room to fit such tall gearing.
Cheers,
Hugo
HugoW is offline   Reply With Quote
Old 04-19-2017, 01:20 AM   #9348
ErikJan's Avatar
Originally Posted by HugoW View Post
Hi guys,
Cheers,
Hugo
Hugo,
You can go to a 64dpi combo. For example a 76T Xray spur and a 40T pinion will do the job.
I had the same issue with the 48dpi, it is very hard to find a small spur where you can use 12 or more balls.
ErikJan is offline   Reply With Quote
Old 04-19-2017, 01:30 AM   #9349
Dank je wel!
Hugo
Old 04-22-2017, 04:40 AM   #9350
Well, the concept was nice...
The ceramic balls I have seem too small and they run on the blue points of the holder, not completely on the wear ring. What is required? Bigger balls, I presume, but I fear they will run inside the wear ring on the blue part as well. Advice it welcome...
Cheers,
Hugo
Old 04-22-2017, 04:57 AM   #9351
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Has anyone made the switch over to 64 pitch instead of 48? Seems like your spur gear is just wrong for the 104 if the diff ball holes dont line up with the diff rings..
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 04-22-2017, 05:23 AM   #9352
dfiantii's Avatar
Finally fixed it
Old 04-22-2017, 06:01 AM   #9353
What parts / sizes are those? (BTW, remove the '?filters' from the link, now it doesn't work.)
Cheers,
Hugo
Old 05-20-2017, 03:03 PM   #9354
Djchow85's Avatar
Anyone have a setup for low traction bumpy asphalt with technicial layout
Running a 104w
Current setup
5.4mm ride all around ~
30k roll damper
Soft pit tyres all around
Diff is 1/4 turn loose from full lock
Kawada 48p spur gear
Steering DR 85%
Brakes 90%
Abs on radio
Throttle 100%
Drag brake 10%
High punch and high brake settings on esc
SP motor with low timing
FDR of 2.25. Lacking punch coming out of corners. Maybe too conservative on the throttle coming out?
Old 05-21-2017, 08:34 AM   #9355
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Running a 104w
Current setup
30k roll damper
Steering DR 85%
Brakes 90%
Abs on radio
Throttle 100%
Drag brake 10%
harder front tires for sure to start
stiff front springs
lighter rear side damper grease
soft rear shock spring, light oil
basically soft rear setup for grip
stiff front set up to kill steering
You get the idea.
These cars just like to do donuts.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 05-21-2017, 09:24 AM   #9356
texastc's Avatar
F N CUDA!!!
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 05-21-2017, 02:08 PM   #9357
Djchow85's Avatar
stiff front springs
You get the idea.
On our track, soft pits worked the best as its coming to winter
Maybe I need to go softer front springs. I think currently have hard fronts
Old 06-05-2017, 08:51 PM   #9358
Cheers,
Hugo
I am using a Kimbrough 104T 64P spur with carbide balls and the Tamiya spur gear spacer 54215
Seatown is offline   Reply With Quote
Old 07-09-2017, 05:19 PM   #9359
Djchow85's Avatar
anyone running on low asphalt, if so, how tight are you setting your diff. I feell like im lacking forward bite in the midfield ... and also when on power at short burts that maybe the car is slipping more than normal. I've got it at 1/4 off full lock
Old 07-09-2017, 05:22 PM   #9360
Djchow85's Avatar
whats the lowest FDR you can get on the f104 with 64p? I've been told that having the extra ball bearings in the spur will have a better diff action?
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
