Like Tree5Likes
Old 02-06-2017, 08:33 PM   #9331
Djchow85's Avatar
but to remove a shorty you'd still need to have one of the posts removed right? I was thinking using thumb screws to make it easier to remove instead of a button head. I prefer not to leave the shorty in when I'm not racing for safety reasons
Lancer Corolla 3 Impreza
Djchow85 is offline   Reply With Quote
Old 02-06-2017, 09:32 PM   #9332
mtveten's Avatar
Trader Rating: 27 (100%+)
Alternatively you could remove the top deck. thumb screw would work fine but its really not any easier than a couple button or cap head screws that use the same size driver you already have out to service the car. I used to use regular buttons on the middle posts, leave out the stiffener forward posts and insert grub screws in the rear pivot to keep the top deck square but not rigid. This way I had maximum flex, could easily remove the top deck and battery while keeping the chassis tweak free. Most of the newer cars use a top plate or shock mount designed to hold the battery down secured with a couple of screws.
mtveten is offline   Reply With Quote
Old 03-13-2017, 06:23 PM   #9333
Djchow85's Avatar
what benefit is there apart from reduced weight of the carbon drive shaft... would it make the rear more twitchy since it puts down the power quicker vs the steel?
Old 03-15-2017, 04:49 AM   #9334
Yes, it will make the rear end more difficult. I heard that and experienced it. I have the carbon axle back in the spares box. I do know people using it, and weighing down the rear pod with wheel balancing lead. Less inertia, better placed weight. I stick to the steel axle for now.
Another question; how do you guys wire your brushless setup so it doesn't hinder pod movement and clears the body? Here's mine:
But I''m not happy with it, yet. I'm also looking at thinner gauge, it's a 21.5T motor, but I'm not sure what the minimum would be. BTW, X1 rear suspension...
Cheers,
Hugo
Hugo
HugoW is offline   Reply With Quote
Old 03-15-2017, 06:21 AM   #9335
the same as you BUT with 16AWG wire.
Gurneyflap is offline   Reply With Quote
Old 03-15-2017, 06:52 AM   #9336
Thanks. I have 14 gauge. What motor do you run? I have the 21.5T Juststock.
Hugo
Old 03-15-2017, 07:01 AM   #9337
21.5 stock
Old 03-15-2017, 08:04 AM   #9338
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
16 gauge wire is more than enough for the 21.5 motor. Just make sure it is loose and not being pushed down when the body is on
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC Xti Altered Ego|Associated B5M|TT02|TA05|TL01RA|TL01|
f1larry is offline   Reply With Quote
Old 03-15-2017, 08:44 AM   #9339
TQ wire 16 gauge wire. It has a higher strand count which makes it more flexible. It's specifically designed for 1/12 stock, so it will work fine in F1.
Hugo, those wires look a little tight.
jiml is offline   Reply With Quote
Old 03-15-2017, 09:45 AM   #9340
I need to move to the US... TQ I cannot seemto find here. Thanks for all the input. I'm also looking at a better quality / more flexible sensor lead...
Cheers,
Hugo
Old 03-15-2017, 11:16 AM   #9341
ErikJan's Avatar
Just stay in the Netherlands: https://hobbyking.com/nl_nl/catalog/...id/6833/?wrh=7
ErikJan is offline   Reply With Quote
Old 03-15-2017, 11:59 AM   #9342
This is 16 gauge, and i've got all three and the sensor wire passing through there. Although I just realized the solder posts on your motor might prevent this routing.
viking44 is offline   Reply With Quote
Old 03-15-2017, 02:10 PM   #9343
Djchow85's Avatar
Is it okay to dremel the top deck back just behind the antennae post for easier removal of the battery? Will it affect handing? This is the 104w
Old 03-15-2017, 03:43 PM   #9344
Why would you dremel it? You can just uscrew the post when you want to remove the battery. Those posts can be removed or added to tune the flex of the chassis. Dremel it ouy and you won't have that option anymore.
Old 03-16-2017, 03:46 AM   #9345
@viking44, thanks, that's an interesting routing. I think I can get away with it with my motor, too.
Cheers,
Hugo
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
IMPORTANT: New Product Arrival Alert! (June 2009) rcmart rcMart.com Mega Online R/C Marketplace 18 06-21-2009 10:11 PM
