Like Tree5Likes
Old 03-10-2015, 12:02 PM   #9301
Originally Posted by Markus View Post
Thanks NutDriver. I just placed the same order from Banzai yesterday. Hope I get it in 4 days too!
Mine was canceled today, out of stock.
Gurneyflap is offline   Reply With Quote
Old 03-10-2015, 01:38 PM   #9302
j.d.roost's Avatar
Trader Rating: 28 (100%+)
BTW JD. Thanks for letting me pass to claim 3rd.... actually almost got 2nd on the last lap.
The video is on Horshmam's thread and when you let me pass you yelled "Go ahead Mark!" it looked like you unleashed a crazed race horse. lol.
Lol..no problem. I was playing it safe at that point for obvious reasons... Made the race more interesting for sure. I think steel rain has another vid.posted on youtube. Search tcs horsham.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-13-2015, 12:49 AM   #9303
Trader Rating: 23 (100%+)
Hi all, just wondering whats the best front wing to run for maximum downforce? thanks
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 03-13-2015, 07:48 AM   #9304
cruise's Avatar
Originally Posted by Blueman Austria View Post
Hy There!
Dose anyone know if the 42286 TRF 101 conversion also fit the F104?
I think it should because the lower Suspension is the same... at least on the normal TRF 101.
Dont know about the holes from the servomount.
Here is the link from the conversion.
http://www.stellamodels.com.hk/42286...on-p-8861.html
Greetings Rainer
You will need the F103/RM01 King Pin # 19804420/54355, the F104 Uprights should compatible....
Hope can help
Tamiya - TA05MS, TRF416, TB-EVO5MS, TRF417X, TRF417V5, TRF418, TRF419
Serpent - VETEQ, 950R, 960, 966
AE - RC500 2wd/4wd
KO - EX1 Mars, EX1 UR, EX10 Helios, Ex1 KIY
cruise is offline   Reply With Quote
Old 04-26-2015, 03:04 AM   #9305
Hi all.
I finally have a tamiya f104 pro.
I'd like to buy the item 54331.
Will it be enough to transform it into an x1?
Then, using that upgrade, will i be able to use hard case lipos and shorty lipos?
At the moment with standard f104 pro i have some trouble fitting batteries...
Thanks to all
coderzone77 is offline   Reply With Quote
Old 07-28-2015, 05:59 PM   #9306
guinnes.s's Avatar
What rubber tyres are good for tarmac?
guinnes.s is offline   Reply With Quote
Old 08-12-2015, 01:03 PM   #9307
jacobrwills's Avatar
Where can I get a stock spur gear for the regular f104? I stripped the one I got
jacobrwills is offline   Reply With Quote
Old 08-12-2015, 01:09 PM   #9308
scirocco14's Avatar
Ebay is one place.
http://www.ebay.com/itm/Tamiya-Ameri...item463882cca8
You can switch over to 64P spur gears, but you'll need a spur gear spacer, a 64P pinion, and 1/8" diff balls. The stock Tamiya diff balls are 3mm, and slightly different.
http://www.tqrcracing.com/shop/produ...w.asp?p_id=881
Mark
Mark C. USVTA #115 TC4 & Xray T4 '13, USGT #115 Xray T4 '13
USVTA-F1 #115 F103/4 & F1R3 & WTF1 FC-16. Tamiya M05 M06
Bush River RC, The RUG at King, Ho B Max Raceway, Easley RC
scirocco14 is offline   Reply With Quote
Old 01-13-2016, 02:54 PM   #9309
Hello everyone, I'm new here, and just wanted to ask a few questions about a new body I've bought.
I originally bought a Tamiya McLaren MP4/5B set, with an F104W chassis. Recently, I bought a current era F1 body, designed for the F104 chassis. Will I be able to fit the new body to the F104W, or do I need to convert the chassis to a standard F104?
Chris
Chris_McLarenF1 is offline   Reply With Quote
Old 01-13-2016, 03:32 PM   #9310
Vyger's Avatar
Hey Chris, the body should fit. The main difference between the W and regular 104 is the front A-arms...they widen out the car at the front. But the chassis is basically the same as a standard 104.
Tamiya Road Wizard, F101s, F102s, F103s, F103RSs, F103LM, F103RXs, F103RMs, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 01-13-2016, 03:40 PM   #9311
Pro10noob's Avatar
Fits as both are the same chassis.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-14-2016, 03:46 AM   #9312
do you test TRG ??
quimico is offline   Reply With Quote
Old 02-09-2016, 05:29 AM   #9313
Hi,
I have a question about the front suspension wishbones. I wasted 3 on a racing weekend, all on the right hand side, smashing against the boarding. So I wasted three whole sets of F- (how appropriate) parts. I managed to survive the finals with a braced suspension, don't laugh:
Now, basically, I need to learn how to drive. I managed to hit the same point in the boarding constantly, smashing the right front wheel on it. But anyhow; is this part of the suspension a known weak point, is it worth searching for a 19004373 set (carbon reinforced), or was this just a freak accident due to my stupidity combined with this difficult and narrow track?
Cheers,
Hugo
HugoW is offline   Reply With Quote
Old 02-09-2016, 06:07 AM   #9314
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
I have done the smae thing on the left side. I have s couple of right side arms I'll trade you for your extra left side arms.😀
Originally Posted by HugoW View Post
Hi,
Cheers,
Hugo
f1larry is offline   Reply With Quote
Old 02-09-2016, 06:49 AM   #9315
Ph3nyx's Avatar
it's the weak point of the F104. You can use the TRF102 renforced part or event better, the exotek adjustable front arm set (#1205) http://www.exotekracing.com/f104-adj...front-arm-set/
Worth every single penny
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
IMPORTANT: New Product Arrival Alert! (June 2009) rcmart rcMart.com Mega Online R/C Marketplace 18 06-21-2009 10:11 PM
