Like Tree4Likes
Old 07-15-2014, 08:09 PM   #9271
Photocycler's Avatar
Trader Rating: 34 (100%+)
Is there a thread for the F104V.2? I just bought one and looking for setup tips.
Also, with the wheels that come with it—can I run any rubber tire?
Photocycler is offline   Reply With Quote
Old 07-15-2014, 08:10 PM   #9272
Also, with the wheels that come with itócan I run any rubber tire?
Old 07-19-2014, 10:55 AM   #9273
roger999's Avatar
Guys, just wondering what upgrade would be better for my f104 pro... Exotek f1r2 or just upgrade to full f104 ver 2?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 07-19-2014, 11:17 AM   #9274
Pro10noob's Avatar
In my opinion??
If the rules let you, go Exotek.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 07-29-2014, 01:47 PM   #9275
chef88's Avatar
Trader Rating: 48 (100%+)
Guys
Have a F104 for sale.
With a bunch of goodies
Great for someone ready to get into an F1
Tamiya F104X1
X -Ray X1.TRF 101
Rebel 12, T4 2017.
Maryland Funster/ Beneteau 373.
180 Raceway/ Johns Mobile Raceway.
chef88 is offline   Reply With Quote
Old 10-23-2014, 02:08 PM   #9276
monkeyracing's Avatar
Thought I'd bring this thread back from the dead.
I'm putting together an F104/F104 Pro and have questions. First, how do you fit the steering ballstuds on the back side of the servo saver and actually have it clear the servo body. I'm using a Kimbrough, but had the same results with a Tamiya, where the ballstuds contact the body of the servo, even without cups on them.
How close is .4 mod to actual 64p? I think I have a stock spur gear on the car and it makes a bit too much noise when used with a 64p pinion. Would swapping to 48p be a better idea?
Anyone ever shortened the top plate, as seen in the X1, on a regular F104? I know it will increase mechanical grip. Any downsides?
More questions later!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-23-2014, 02:08 PM   #9277
Stab it and steer.
Old 10-23-2014, 02:16 PM   #9278
JayL's Avatar
I did it like the F104v.2 manual: front of saver
but then I swapped all my F1's to laydown shorty servo and xray saver
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 10-23-2014, 03:26 PM   #9279
Switching to 48DP will only make the noise worse, the finer the pitch the less the noise.
Thaan is offline   Reply With Quote
Old 10-23-2014, 03:50 PM   #9280
Figured out how to do it using stuff I've got. This is a nice modification.
This isn't always true. I swapped to 48 from 64 in my TC and it's not appreciably louder. I'm just looking at it from the perspective of being stronger, easier to mesh and actually compatible.
The opinions on whether 0.4 mod and 64p are compatible are split 50/50.
Stab it and steer.
Old 10-24-2014, 08:59 AM   #9281
Hua
Hi all, i thinking of getting F104 with a 1s Lipo set-up. I need some advice from u guys to clear some some of my doubt.
Here are the electronic i plan to use on:
1s ESC, 1s Lipo
17.5/21.5T motor
All rubber tyres
Standard Servo eg: Futaba 3003
1) With rubber tyres, will the ESC/Lipo take excessive load since its 3.7V?
2) What gear ratio should i go for if i'm running 17.5/21.5T? will 3 be good enough?
Hua is offline   Reply With Quote
Old 10-24-2014, 09:59 AM   #9282
Do you have to use a 1s battery, or is this a choice? Given the choice, I'd go 2s. ProTek make a very nice 2s pack that's small enough for a pan car, or 2s shorty packs from Turnigy are a pretty good deal.
I don't think the ESC would face excessive stress, as long as the car is set up the right way, with proper gearing. You may want to look at what sort of gearing is being run in 1/10 pan car classes like WGT, where 1s is fairly common.
Stab it and steer.
Old 01-05-2015, 07:08 PM   #9283
I realize this is an old thread but I will give it a shot...I have a 3 racing out tuned ball diff. I built it exactly to the instructions. Even if I tighten the diff as tight as possible, by lap two the diff has loosened to the point that the motor no longer is able to spin the wheels. What the heck am I doing wrong?
mhopper is offline   Reply With Quote
Old 01-06-2015, 02:00 PM   #9284
robk's Avatar
Trader Rating: 22 (100%+)
I had one of those diffs and sadly the idea is better than the execution. Maybe try threadlock on the threads for the external adjuster.
Old 01-06-2015, 02:43 PM   #9285
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
mount them in front or you can try using shorter ballstuds. or, as suggested, use a low profile servo so you can lay it down and run yhe saver horizontally (less bump steer)
I use 64p pinions with 04 mod spurs with no problems. 48p or 06 mod will be noisier. would suggest switching to a spur gear that can hold 12 or more balls (eg xenon)... diff runs smoother for longer
did the topdeck mod too but have swaped it out for hopup deck that uses as roll damper instead of the friction plate damper... more consistent and easier to tune.
hths
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
