Like Tree1Likes
Old 08-13-2013, 06:38 PM   #9196
Is it possible to put a wide front on the v2?
Tamiya F104 V2, TT-01E CS Drifter
XRAY T4 '13
Yokomo R12C3
d.k.vmatt is offline   Reply With Quote
Old 08-13-2013, 06:43 PM   #9197
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Yes, Tamiya F103 front end will bolt right on.
Dan is offline   Reply With Quote
Old 08-18-2013, 08:41 AM   #9198
madjack's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to madjack
Any Tamiyafile's out their test the new TRF 101 front end on the F104 X1 or t-plate chassis?
madjack is offline   Reply With Quote
Old 08-18-2013, 02:15 PM   #9199
SAMU's Avatar
good afternoon
The advice on what to wear to the zero control.
It is important that the cruise control is a fast zero mode.
Tamiya Formula 1 F104Pro RCcar speed passion 21.5 motor must V3.
Momentum and winding short courses running in the car.
It should be zero for zero esc controller is better than the other mod esc.
Thanks for your help!
SAMU is offline   Reply With Quote
Old 08-19-2013, 01:52 PM   #9200
SAMU's Avatar
Hi
I have problems to place a short battery I put forward or backward?
Thank you!
Tamiya F104Pro V2. ?????? SP 21.5T
Tamiya TB-03 Carson 16T
HB Cyclone TC SP GT 2.1 SP 17.5T
Yokomo BD5 LRP SPX Zero SP 13.5T
Old 08-19-2013, 02:29 PM   #9201
edhchoe's Avatar
Trader Rating: 41 (100%+)
Try forward. It makes wiring neater.
edhchoe is offline   Reply With Quote
Old 08-20-2013, 06:57 AM   #9202
Trader Rating: 69 (100%+)
How about any Tamiya F1 Junkies that may have already put together a TRF 101 Front End Parts list???
For those of us that are much lazier and not as sharp?
Thanks.
Markus is offline   Reply With Quote
Old 08-20-2013, 12:14 PM   #9203
edhchoe's Avatar
I don't think the front upper carbon piece is available yet. Or is it?
Old 08-20-2013, 03:00 PM   #9204
The Tamiya parts aren't available yet, if anyone wants to find out what parts to buy you can find all the parts, and all the part numbers, in the manual that can be downloaded from Tamiya.
The parts are kind of available in Japan, Tech Racing already make their own version. Unfortunately no one that posts outside Japan stocks them right now, although I would guess Banzai Hobby would order them for anyone who wants one.
terry.sc is offline   Reply With Quote
Old 09-16-2013, 03:36 PM   #9205
Trader Rating: 22 (100%+)
Default f103 motor mount on a f140x1
Can I use the F103 motor mount on the F104X1. Will this lower the rear of the car more then what I can with the standard rear ride height blocks. Anyone know?
RS_ZACH is offline   Reply With Quote
Old 09-16-2013, 04:33 PM   #9206
yourstruly22's Avatar
If you want to get lower you can always shim the motor mounts . Raising the axle lowers the right height. I have never needed to go lower the #2 on top even on carpet. Besides if you use the F103 motor mounts you won't be able to use the x1 roll damper without customizing. If you're okay with that you have this option. http://www.tqrcracing.com/shop/produ....asp?p_id=2337. Also 3 racing makes axle bearing holders in half increments. I don't own these so I'm not sure if they make a 2.5 maybe someone else can chime in on this.
Pass me clean or don't pass at all
yourstruly22 is offline   Reply With Quote
Old 09-17-2013, 01:41 AM   #9207
With the F103 Motor mount you will get more ride height,
just use the F104 Motor mount.The Yeah Racing Motor mount
has about the same Ride height as the F104 one.
VicViper is offline   Reply With Quote
Old 09-17-2013, 10:21 AM   #9208
Check the link in green Yeah motor mount gives you more ride height adjustment with the spacers on top or bottom http://www.tqrcracing.com/shop/produ....asp?p_id=2337 But like you said go with the f104 motor mount.
Old 09-18-2013, 12:15 PM   #9209
if you put the 2mm spacers on the bottom youll get the same ride height as the F104 pod. if you put them on the top its like the F103 one.
So it does not lower the ride height.
Old 09-20-2013, 09:00 PM   #9210
Tracy B's Avatar
I am looking to find this product: Rsector SR-F104-001 High Capacity LiPo Conversion for the F104/W/PRO/X1 cars (http://www.tqrcracing.com/shop/produ....asp?p_id=2680). TQ RC had it in stock before I bought my F104X1, they say it is now discontinued. It would work perfect for me since I use a Reedy 5500 2S LiPo for my X1 and am looking for a way to do quicker battery changes.
Is it truly discontinued?? If not, where can I find one??
If it is truly discontinued, is there anything on the market similar to it that might work just as well??
TRex chassis with McAllister Xfinity Ford Mustang
Member of WRCRC
Authorized HobbyWing, Gens Ace batteries, McAllister Racing Bodies, and Precision Racing Systems dealer: BroeckerRacing@Gmail.com
www.facebook.com/BroeckerRacing
Tracy B is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
