Like Tree5Likes
Old 12-17-2012, 06:25 PM   #9076
The Captain's Avatar
Pics. I had removed 2 of the chassis standoffs during practice to see if I got any more flex, but didn't really notice much of a difference.
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 12-18-2012, 01:09 AM   #9077
Yeah sorry everyone, got confused with all my other R/C race cars. You are all right, you cannot adjust the rear camber.
Most fun you can have standing up!
-Adz- is offline   Reply With Quote
Old 12-18-2012, 02:56 PM   #9078
5VoltDetonator's Avatar
I'm new the F104 pro also. I was having alot of problems with spinning out get on power coming out of corners.
First thing that helped was getting the diff set correctly like this- ( Texastx explained it like this ) - make sure that the diff action is smooth, spin one tire while holding the spur still should spin the other tire the opposite direction. And if you hold both tires have the diff just tight enough to where you cannot move the spur with your thumb. There is a fine line between too loose and too tight. I like to tighten all the way, and then loosen it a quarter turn at a time, until I can barely move the spur, and then tighten it back about 1/8-1/4 a turn. You don't want it to slip, but it has to be loose enough to where its not binding.
The other thing I did was to set the front wheels with about 2-3 deg toe out. I read it somewhere, cant rememberr where ? Maybe an Australian F1 site. This helped my spinning out problems the most I think.
Also try to make sure the pod is built perfect.
I also removed the middle screw on the t-plate it gave me more rear movement.
5VoltDetonator is offline   Reply With Quote
Old 12-20-2012, 05:30 AM   #9079
jsr555's Avatar
Trader Rating: 17 (100%+)
Default 3Racing rear wing
I am new to F1 and was just wondering if somebody could confirm for me if the 3Racing F1 rear wing set, this one
http://www.rcmart.com/3racing-lexan-...h=595_744_1390
Will fit the F104 Pro..? I was just concerned over the width of it.
thanks.
Xray T4 & HPI/HB Pro 5 - Powered by Hobbywing
SQ: HPI RS Pro -HPI RS Pro 2 - HPI Pro 3 - HPI Pro ?? - HPI Pro 5
jsr555 is offline   Reply With Quote
Old 12-20-2012, 02:20 PM   #9080
edhchoe's Avatar
Trader Rating: 41 (100%+)
Plz PM If ne1 got f104x1 for sale. Thx.
edhchoe is offline   Reply With Quote
Old 12-20-2012, 05:29 PM   #9081
thanks.
It's a repackaged Cross/TRG wing so it is pretty huge. My TRG version which clears the tyres easily on an F103 was tried on an F104 and rubbed against the inside of the tyres so the wheels might need a little bit of spacing apart or the sides of the wing trimmed to clear the tyres.
terry.sc is offline   Reply With Quote
Old 12-21-2012, 12:15 AM   #9082
kneedeeppow's Avatar
if your using kit foam tires,they are a softer compound and the fronts can generate alot of grip to the point of out turning the rear. alot depends on running surface and tire selection to get the most of car stuck. diff is definatly an important factor but tire choice is very big
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 12-21-2012, 07:07 PM   #9083
edhchoe's Avatar
Does this look right for 60mm diameter tire?
Old 12-30-2012, 02:01 PM   #9084
As you can see, I cannot run my battery all the way back, as the bullet connectors would be covered up by the upper deck. What I want to do is trim the upper deck just after the front standoff (in line with the "d" in reedy), so the bullets are not covered. Will this e ffect the handling in a negative way? I'm thinking it will cause more flex, which might be a good thing.
I dont want to buy a shorty lipo until I know the class will take off locally.
-Derrick-
Old 12-30-2012, 03:05 PM   #9085
Pro10noob's Avatar
Yes you can.
Use the short upper deck and shorties or the full size lipo the other way around.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-30-2012, 03:09 PM   #9086
Originally Posted by Pro10noob View Post
Yes you can.
regards Roy
Ill be getting a shorty lipo if the class becomes consistent. So far no one has shown up to race them at my local track So in the meantime ill just cut off the front part of the top deck so my bullets are accessible and run it like that.
For future reference, what shorty lipos fit the f104pro well in stock form? I'd like to be able to run my esc (Novak edge) and rx (futaba) down the center of the chassis.
-Derrick-
Old 12-30-2012, 03:14 PM   #9087
Pro10noob's Avatar
I run my F104Pro wide with the silverback 4200MAH shorties they use on the ETS races.
This with the short topdeck and a little foam cushion between the lipo and battery holder at the rear.
I block the shorty by using some wheel balance lead or the ESC/reciever.
Works like a charm.
Regards Roy
l===/o\===l
Old 01-02-2013, 02:03 PM   #9088
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Looking for some help I bought the Aluminum spacer set for my F1R and I am trying to get it set to 5mm ride height in the front. Does anyone have the combination? Total F1 noob here.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 01-02-2013, 04:41 PM   #9089
Thats my semi Sybrand-F104X1 with 0571/0575 Shimizus for the cold winter weather. Pro10noob i see you use only the rear tire warmers, i have seen this with proten pancars with foams, does it give good results also with rubbers?
[IMG][/IMG]
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 01-07-2013, 09:28 AM   #9090
rimracker's Avatar
Trader Rating: 14 (100%+)
Can anybody post up a pic or two of the X1 body, I would like to see how you cut the body for the side damper. I would just like an idea before I take my dremel to it. It looks like I need to do both sides?
rimracker is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
IMPORTANT: New Product Arrival Alert! (June 2009) rcmart rcMart.com Mega Online R/C Marketplace 18 06-21-2009 10:11 PM
