Old 12-17-2012, 05:26 AM   #9061
Can't run camber on the back of a F104 Black Edition.
Old 12-17-2012, 08:21 AM   #9062
The Captain's Avatar
Alright guys, got my F104 Pro out to the track yesterday now I need some setup advice
Track is roughly 70x30', high bite carpet
The car has a push, but also has a TON of steering. It is VERY easy to over steer and spin it out in the turns. I was doping the entire rear tires (TCS Rubber) and the inside 1/2 of the fronts. Everything is box stock, less the spur gear and tires.
(setup off the top of my head)
Rear ride height is in the lowest position.
45wt oil in the shock
30k wt diff oil on the rear damper plates, spring compressed with ~7mm thread showing (manual says start with 4mm)
0 camber
Reedy 5000mAh LiPo placed as far forward as possible with foam blocks in the back to keep it forward
This was just my initial setup from the build. I took it out on the track just to get a feel for it and see where I needed to make adjustments. I spent the majority of my time adjusting the diff and breaking in the tires though.
What I planned on doing was placing the battery all the way back for starters, and see where that got me. I also have a high traction T plate on order, so I'll put that in as well. From there, adjusting the rear shock spring/oil, rear damper oil, removing the middle screw from the T plate, and removing chassis standoffs to achieve more flex. I've got the front screw set coming in with the T plate as well.
Am I heading in the right direction?
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 12-17-2012, 09:09 AM   #9063
er6f's Avatar
Originally Posted by Andysan View Post
Hey man,
You can try a few things - generally, if your tyres are shot at both ends of the car then you should replace them all around, but I digress. Perhaps try any of the followign one at a time;
* Add more weight to the rear, as low down and close to the axle as possible.
* Adjust the T-bar.
* Stiffer spring in the rear shock - this should stop the weight transferring to the front on corner-in, and ensure that you have a bit more shock rebound and hence weight transfer over the rear on corner-out.
* Add a bit of toe-out on the front.
Thank you very much sir for the tips, should i lower the ride height too?
Kyosho Pureten GP Spyder Mk II - Traxxas Summit 1/8th - Traxxas Slash 4x2, Traxxas Erevo Vxl - Hpi Savage X4.6 - Mugen MBX6 Eco MMM - Tamiya TT01ER Front Motor -Tamiya TT01E - Tamiya TA05 ver.2 - Tamiya FJ40 CR01 - Tamiya Bronco CC01 Tamiya Tundra Highlift w/MFC02 - Tamiya F104 Pro Black Special Tamiya MAN TGX 26.540 6x4 XLX w/MFC01 and Flatbed Trailer
er6f is offline   Reply With Quote
Old 12-17-2012, 09:12 AM   #9064
er6f's Avatar
Originally Posted by -Adz- View Post
Just to add to Andysan's informative post; I would run some camber too, especially on the back. You say your running 0 degrees, if that's on the back, then that's half ya problem. Otherwise, welcome to the great class of F1.
Yes sir, i have 0 camber but my adjustable camber is only applicable at my front wheels, my kit doesn't have adjustments at the back wheels
Old 12-17-2012, 10:02 AM   #9065
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
anybody try fitting a rm01 pitch damper on a x1 or wgp? thanks!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-17-2012, 11:41 AM   #9066
You really can't adjust camber on a solid axle in the rear. Maybe if it had a couple U-joints ........
AreCee is offline   Reply With Quote
Old 12-17-2012, 11:46 AM   #9067
I can't remember what I used to do to set up my old F103 but I think I replaced the friction plates with a TRF F1 shock but then that was an older wide arm chassis.
My v2 was almost dead on at teh Track in Winthrop Harbor, it was only the driver that was the main deficiency. Since its initial voyage I made a few changes but most are for the link chassis.
Old 12-17-2012, 11:51 AM   #9068
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
0 camber
Shimizu TCS tires, or Tamiya tires
Shimizu TCS tires require no breakin, only cleaning first time to get around
If you don't have grip on Shimizu on carpet something is wrong with car build
Doesn't sound like a setup issue
Can you post pics of you car in current form
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-17-2012, 11:55 AM   #9069
Yeah they sell a conversion for the friction plates, Tamiya #54331. Problem is its more than $50, so I'm going to try to make the plates work for now.
-Derrick-
Old 12-17-2012, 01:08 PM   #9070
He did say he's using those tires.
Those tires have good traction and depending on the track may even cause traction rolls.
Old 12-17-2012, 01:11 PM   #9071
Tamiya 1031 and 1032 tires. I'll post up pics when I get home tonight.
-Derrick-
Old 12-17-2012, 01:19 PM   #9072
A little confused on this
"The car has a push, but also has a TON of steering."
So is that off-throttle push
and
On throttle loose ?
What are you putting on the tires ?
Old 12-17-2012, 01:56 PM   #9073
and
On throttle loose ?
Yup. Off throttle the car has a push, on throttle the rear end likes to whip around fairly easily, but turns on a dime. What I noticed was I had to stay in the throttle going through the turns, and there was a VERY fine margin between just enough throttle to get through the turn, and too much throttle and making it spin out. I also thought this just might be the way these things drive, too.
We can only use SXT traction compound.
Keep in mind this is my first 2WD onroad car, first pan car, so there is quite a learning curve for me.
-Derrick-
Old 12-17-2012, 02:22 PM   #9074
That car, on those tires should be fairly easy to drive on carpet, not loose, yes a bit pushy of throttle
The later model F-104 X1, and VII are even easier to drive, with many more options for setup, but 104Pro isn't that far off from the ultimate fast lap, if at all
Old 12-17-2012, 04:38 PM   #9075
Andysan's Avatar
What is it currently set to now - ensure that the rear ride height is the same as the front, or about 0.5mm higher at the rear. If you'r running smooth carpet, somewhere around 5mm is a good starting point. Also, if you can get hold of any tyre additive then this will make a huge difference.
Hey Man,
Just out of interest, as I don't actually own an F104 (I run F102/3), how do you add camber to the rear???
Andysan is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
