Old 11-23-2012, 09:11 AM   #8986
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by durtbag View Post
Does anybody know of a source for #19805478 2mm king pin c-clips? I'm thinking that I should find some.
Thanks, Terence
Try here
http://www.tqrcracing.com/shop/produ..._keyword=50588
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-23-2012, 09:25 AM   #8987
Originally Posted by RedBullFiXX View Post
They are not the same as mentioned, the ones he need is a C-clips and those you have in the picture are E-clips
The ones he need are the ones from the following picture
addicted2blue is offline   Reply With Quote
Old 11-23-2012, 09:28 AM   #8988
As far as I know there are only 2 clips for the Kingpins
This is the other one
Sean will re-stock if requested
http://www.tqrcracing.com/shop/produ..._keyword=84171
Old 11-23-2012, 09:39 AM   #8989
Both will work but the C-clips is much easier for changing set-ups
Old 11-23-2012, 10:33 AM   #8990
durtbag's Avatar
thanks guys! now that I have a proper Tamiya # I found them.
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 11-27-2012, 09:14 AM   #8991
The Captain's Avatar
Hey guys, I'm picking up one of these NIB from a friend and will start building it this weekend. What upgrades are pretty much necessary right out of the box? After doing a search, all I came up with was the aluminum motor mount and a 64p spur adapter. Does anyone have a part number for the adapter? Anyone got any advice for gearing options running 2S LiPo with a 21.5T? Track is indoor carpet
http://www.rctech.net/forum/attachme...918_181715.jpg
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is online now   Reply With Quote
Old 11-27-2012, 09:37 AM   #8992
It's Tamiya 54215 or Tower LXZEU7.
I'm building up my 104v2 and should have it running for this weekend at Hotslots. Looks like I will be there the 8th if I can't make it on the 1st.
I got the TCS tires which go on the foam wheels (included in the kit). Tamiya 1031 and 1032 for the tires (they are rebranded Pit Shimizu).
I have no idea of what FDR will work so I have a 96/27 on it now for a FDR of 3.55.
AreCee is offline   Reply With Quote
Old 11-27-2012, 10:00 AM   #8993
At TQRC 90x45 carpet track
93x30 is close (3.10) with a Reedy 21.5 @40deg
The stock spur works fine with 64p pinions, it's all I ever use, and I'm still on the original spur after a full UF1 outdoor season, and many club races
Old 11-27-2012, 10:32 AM   #8994
The track that Captain and I are at is about 70x35 and has very high traction (I was told they sprayed traction compound on the carpet). I am just guessing at the FDR but I felt that the mid 3s would be a good place to start.
I would use the stock spur but I have quite a few 64p gears and pinions not to mention balls (1/8") that it only made sense to spend $2.50 for the adapter.
I used to race the F103 years ago and it was a lot of fun then so I got bit by the F1 bug again due to an increased interest of getting this class together.
Old 11-27-2012, 08:29 PM   #8995
Thanks, what are some parts to go ahead and order for spares (most commonly broken items)?
-Derrick-
Old 11-27-2012, 08:37 PM   #8996
I'm not sure either. I sort of remember that I only broke the steering uprights, motor mounts and front wing on my 103.
Old 11-28-2012, 03:06 AM   #8997
dfx
dfx's Avatar
...what are some parts to go ahead and order for spares (most commonly broken items)?
Upper arms are bending sometimes, spare spur gear and if You use high-traction t-bar it could be demaged even though it looks OK but the car reacts strangely.
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 11-28-2012, 07:25 AM   #8998
Got a part number for the high traction T bar?
One thing I have noticed about the F104 is it difficult to find the parts because the part numbers are all weird. Sometimes they match up, sometimes they dont.
-Derrick-
Old 11-28-2012, 07:50 AM   #8999
part nr for the high traction T-bar is 54222
Old 11-28-2012, 07:53 AM   #9000
dfx
dfx's Avatar
#54222 F104 High Traction T-Bar: http://www.tamiyausa.com/product/ite...oduct-id=54222
#51381 F104 F Parts - Suspension Arm/Front: http://www.tamiyausa.com/product/ite...oduct-id=51381
Here You can find a lot of F104 part numbers: http://www.tamiyausa.com/search.php?....x=7&image.y=7
Tamiya TRF 416 WE
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
