Old 10-30-2012, 12:28 AM   #8971
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by kneedeeppow View Post
i am on the hunt for the little wee screws and nuts that the 104 bodies use to attach the sidepods. can anyone point me in the right direction? cheers
How many do you need ? I have way more than I will ever use.PM me and I can figure out how to get them to you
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 10-30-2012, 11:16 AM   #8972
spring71's Avatar
Smile
Originally Posted by silencery View Post
Also, you can try these...
http://www.tqrcracing.com/shop/produ....asp?p_id=2847
http://www.tqrcracing.com/shop/produ....asp?p_id=2954
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 10-30-2012, 11:38 AM   #8973
JayL's Avatar
I use shoo-goo and no screws for side pods
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 11-13-2012, 07:12 PM   #8974
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
any one looking for a F104 X1 and reedy 21.5 let me know
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 11-17-2012, 07:37 AM   #8975
BadSign's Avatar
Trader Rating: 15 (100%+)
Can anyone tell me how many camber settings there are on the aluminum upper suspernrion mount? I only see 1* and 1.5* in the photos.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 11-17-2012, 10:05 AM   #8976
dfx
dfx's Avatar
1, 1,5, 2 and 2,5 (4 different settings possible).
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 11-17-2012, 10:20 AM   #8977
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
There is another brand on tqracing that have them as well with 0.5, 1,1.5, 2. Degrees.
I drove my car yesterday and what a blast it is.later on we got some light rain and i still drove it through the light rain and that was funny as hell with a 17.5
Have some small issues and looking g for some input. The car pushes on power, the pitch damper has 30 oil and 20 on the side one 4000 lipo towards the rear position. Im getti g ready to order some more goodies and wondering if the small spacer to run the spur is all i need to run 64 or 48 pitch?
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 11-17-2012, 02:17 PM   #8978
kneedeeppow's Avatar
yip the 'pom' ring is all you need to switch to 48 pitch. 3racing do one as well as tamiya. as for the push maybe try different front springs and 'motorboat' your ride height(high front low rear). and softer front tires
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 11-17-2012, 02:39 PM   #8979
Mr.juarez's Avatar
Cool ill switch to 64 or 48 so i can use my spare gears. Everything is stock, but now that you mention it the front is low enough not to drag, but the back is way high after i installed the aluminum motor mount.
Im running it on a low to medium bumpy asphalt big track will placing the lipo towards the front be a wise idea and put the esc right under to damper mount? Sort of trying to figure out how to clean up the wiring.
Old 11-17-2012, 11:04 PM   #8980
BadSign's Avatar
So you just flip it over?
Old 11-17-2012, 11:05 PM   #8981
i personally have never played around with battery position so cant really comment on that but the ride height thing is quite critical(imho) i run on rubber tires so just have the ride height permanently set as low as it can go in the rear with the kit axle holders. and in the front i aim for 4mm minimum. foam tires are gonna need constant monitoring as the foams wear. like you i run a bumpy outdoor track so the minimum ride height can be a pain tho now i have changed my line to keep away from the rough spots(well i like to try and change my line lol) the heavy pivot post is a good option for getting weight in the right spot in the car without sticking clumps of lead all over the place. and clean wiring is also super important as the rear pod can get comprimised easly and cause handling issues. try running the car in a area where you can see the car clearly with out the body on and watch if the wires move when turning left or right.then put the body on and see if it changes?
hope this helps
Old 11-18-2012, 11:54 AM   #8982
I'm considering to sell all the original titanium plated aluminium parts of my F104X1.
If anybody is interested in the F104 X1 Alu parts just let me know with a Private Message, maybe when can work something out.
I live in europe, just keep that in mind.
Kind regards
addicted2blue is offline   Reply With Quote
Old 11-18-2012, 02:58 PM   #8983
dfx
dfx's Avatar
Yes (speaking of Tamiya part, have no experience with other brands)
Tamiya TRF 416 WE
Old 11-22-2012, 06:42 PM   #8984
durtbag's Avatar
Default C Clips
Does anybody know of a source for #19805478 2mm king pin c-clips? I'm thinking that I should find some.
Thanks, Terence
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 11-22-2012, 09:04 PM   #8985
hanzo3's Avatar
Trader Rating: 55 (100%+)
I have a brand new 54163 Tamiya F104 Carbon Chassis Lower Deck for sale. $25 shipped.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
