Like Tree1Likes
Old 10-04-2012, 09:09 AM   #8956
Originally Posted by terry.sc View Post
You are never going to see a modern fluid filled gear diff in a direct drive F1, purely because you would be adding so much more weight to the rear axle on the diff side you would have to balance it out by adding even more on the other end of the axle, all increasing the rotational inertia of the axle.
FTFY
The FGX has a fluid filled diff but runs a gearbox.
You can find me at the folllowing sites:
twowheel at rcracing.com
FuriousFlip at ultimaterc.com
K.O.M. at rccrawler.com
TW@ at vwvortex.com
TwoWheel is offline   Reply With Quote
Old 10-08-2012, 06:30 PM   #8957
BadSign's Avatar
Trader Rating: 15 (100%+)
Last friday I ran my F104 Pro for the first time ever. My only F1 experience prior has been a 103 on foams.
Anyway, my outer front tires were chattering like crazy, especially in tight 180's.
What can I do to fix this? Here's my set-up:
New TCS (shimizu) fronts and rear
Trinity Rubber Death Grip, full sauce on all tires
I tried both black and silver front springs- same result
Tried both 1 and 2* camber- same result
I have the servo setup horizontally/ laydown instead of stock, with the tierods set even/straight across. tierods were horizontal.
Tierods mounted on the front holes of steering blocks
So my question is, is this a matter of excessive caster, or a lack of ackerman?
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 10-08-2012, 07:03 PM   #8958
robk's Avatar
Trader Rating: 22 (100%+)
Do you have any type of grease or fluid to dampen the front end? Something like 30 or 60K diff fluid will help.
robk is online now   Reply With Quote
Old 10-08-2012, 08:53 PM   #8959
BadSign's Avatar
Thanks, I'll try that in testing this week.
Old 10-09-2012, 02:39 AM   #8960
Alfonso_R's Avatar
Send a message via Yahoo to Alfonso_R
Hi guys ! What would be the best foam combo on a asphalt track medium - high traction? Thanks!
Alfonso_R is offline   Reply With Quote
Old 10-09-2012, 06:18 PM   #8961
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Originally Posted by TwoWheel View Post
FTFY
Exactly, the FGX it's not a direct drive chassis. Two Wheels is talking about direct drive.
I wold get the "B" options. PM me I think I still have a NIB set.
Cheers,
Marcos
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 10-14-2012, 06:20 PM   #8962
I)arkness's Avatar
Ran a set of the Ride R1 premounts yesterday and they worked really well, but had trouble with getting the front ride height down, due to the know issue of the king pin rubbing on the rim, the lowest i got was 6.5mm on the front
has anyone else been able to get it lower then this by fiddling with the spacers, im running with the option alloy knuckles.
and to get the rear end to stop hopping or bouncing when i go over bumps, would it be more droop?
thanks in advance
B.Portelli
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 10-14-2012, 07:47 PM   #8963
Trader Rating: 194 (99%+)
If you are running a shorty battery pack then move the pack forward about an inch if you are all the way back. More weight up front will really help this out.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 10-17-2012, 03:37 PM   #8964
JayL's Avatar
Really like Robk's idea for front droop:
http://rcf1blog.blogspot.com/2012/10...ws-or-how.html
What do you guys think about using a droop screw with a flat head but can still adjust with a hex on the screw end?
Like this:
http://www.amainhobbies.com/product_...p-Screw-Set-10
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 10-17-2012, 04:23 PM   #8965
robk's Avatar
Those screws sound pretty cool. Normal grub screws work great if you can't find the Durango ones though.
Old 10-18-2012, 04:07 PM   #8966
GryphunRacing's Avatar
Thanks for the links. First time I have heard of this idea and RC FiA. Bummer since the last race was October 13th.
In the Stable: VBC Flash-04, Tamiya F104X1, Tamiya F104v2
GryphunRacing is offline   Reply With Quote
Old 10-18-2012, 04:27 PM   #8967
JayL's Avatar
Norcal hobbies in union city
and
Speedworld raceway in roseville
both race F1 at least twice a month and have good helpful people
Kinda funny about front droop, I have one person saying run .5-1mm and another saying pull the front droop screws completely, and both are knowledgeable and fast
I need to try both back to back once I get those droop screws
Old 10-27-2012, 09:31 PM   #8968
Heri W.'s Avatar
thanks in advance
Hi I)arkness
i try also this tire - is a very good tire
you have two options
1) 2 mm spacer ander the front suspension - i drive this so....
2) cut the front spring a little bit
i drive my car with 3mm front ride high
but the best right high for me is 4,5 in the front
greet herbert
i drive this t
Heri W. is offline   Reply With Quote
Old 10-29-2012, 10:51 PM   #8969
kneedeeppow's Avatar
i am on the hunt for the little wee screws and nuts that the 104 bodies use to attach the sidepods. can anyone point me in the right direction? cheers
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 10-29-2012, 11:27 PM   #8970
Trader Rating: 21 (100%+)
http://www.tqrcracing.com/shop/produ....asp?p_id=3415
silencery is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
