Like Tree1Likes
Old 06-22-2012, 08:58 PM   #8551
GryphunRacing's Avatar
Originally Posted by JayL View Post
Norcal THE TRACK, has some very good dedicated F1 racers, I can't speak for the hobby shop........
buy one online and go out to the track, you will get lot's of help and get to watch some fast guys
I know this for a fact. My first time at the track with my F1 (F104x1) a gentlemen walked up to me and said, "all right...another F1" with enthusiasm and proceeded to show me a couple tricks of the trade and great advice without me asking.
I will definitely return there (more now since my grad school is finished) and will be bringing along my x1 and soon to acquire version 2 (waiting for my order from speedtech which by the way the shipment of Version 2's landed yesterday meaning the hobby shops should be in receipt by next week)
In the Stable: VBC Flash-04, Tamiya F104X1, Tamiya F104v2
GryphunRacing is offline   Reply With Quote
Old 06-23-2012, 06:00 PM   #8552
RonF's Avatar
For parking lot racing, would it be better to upgrade my Pro with the x1 dampner and short upper deck, 54331 RC Upper Deck/Roll Damper Set - F104X1 or just the short deck 54278 RC F104 Separated Upper Deck?
I would think the x1 setup with rubber tires. I couldnt get the right search words to find a suggestion.
VBR,
Ron
F104pro, Turnigy Turbo 80amp, 21.5 trackstar, LRP esc and Rs 540
RC10 original, RC10 graphite, RC10 4wd MIP SP1 version, RC10T
RonF is offline   Reply With Quote
Old 06-23-2012, 08:18 PM   #8553
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
It's like two steps in advancement
Both will improve the grip, and make the car more stable
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-23-2012, 08:50 PM   #8554
Originally Posted by J-PaP View Post
Think he meant that the wheels/tyres are the same on a F104 V2. compared to a normal f104. Not the same front vs rear.
Thanks for the info, but that's not what I'm asking for...sorry for my english
My question is f103 rear tire can it be use in f104? Because with wider tire f103 rubber will give more traction on carpet instead of f104 rear rubber tire because of the wider size..
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 06-23-2012, 09:05 PM   #8555
Yes
With the "correct" tires, 200mm F-104 will for sure be faster in corners than 180mm, not more traction, just more stable
Here is F-103 tires and front end on F-104 WGP
Old 06-24-2012, 12:31 AM   #8556
Originally Posted by RedBullFiXX View Post
Yes
So that's mean I have to change the front end to f103 as well?
Old 06-24-2012, 01:53 AM   #8557
Originally Posted by freakyfreakyflo View Post
i find my 104 is going left very badly. i have been setting and reset the diff as it must be to to tight and this does not give me any help. i read this and it finds me to make sense. but i have a question to ask. when putting the left wheel side on how is it positioned on the axle? should i leave a amsll gap between the bearing and the hub(wouldnt this move left and right and cause problem?) or put a spacer between the hub and the bearing?
i check my bearing as we run on a low grip carpark and the bearings find alot of dust.they are replaced often.
thanks
Originally Posted by InspGadgt View Post
There should be a very small gap...rule of thumb is to insert a piece of paper between the hub and the bearing when you tighten down. I find personally that I push too hard on the hub and don't get a big enough gap so I fold the paper and use the double thickness.
would putting some sort of shim between the hub and bearing be a help
freakyfreakyflo is offline   Reply With Quote
Old 06-24-2012, 06:03 AM   #8558
theDover's Avatar
Remember though, if you are sliding any shims over the rear axle between hubs and bearings, you are also widening the rear wheelbase by doing so and you would want to place the shims on both sides to even out the wheelbase.
Standard rear axle is 6mm x 110mm. Any 6mm shim will work.
Here is another product to consider a try.
http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
TEAM ULTRALINE / RickyRacerLidz
www.ultralinehobbies.com
Ultraline Hobbies RC Raceway @ facebook
theDover is offline   Reply With Quote
Old 06-24-2012, 06:11 AM   #8559
If you are going to run 103 rear wheels, you should have the 103 front end, otherwise you will have 200mm rear track, with 180mm front track, also the 103 wheels are smaller dia than 104 wheels
I don't see how a shim will help with setting up a small gap on the axle
Can you post a pic of your car, top view, so we can have a look at what you have ?
Someone may be able to spot what is causing the issue you have
As Dover said
That C/W is also a good idea to balance the back of the car
Old 06-24-2012, 06:38 AM   #8560
Been running my car with 180/200mm front/rear track (using r-sector widening kit on the rear but not the front). Works quite well for me.
J-PaP is offline   Reply With Quote
Old 06-24-2012, 11:05 PM   #8561
Trader Rating: 43 (100%+)
searched everywhere but can not find the tamiya black diff case upgrade
Tamiya 84114
i don't care if i have to buy out of country, if anyone knows please let me know.
aceinthesky is offline   Reply With Quote
Old 06-25-2012, 05:38 AM   #8562
blade072's Avatar
Trader Rating: 98 (100%+)
Tamiya 84114
i ended up buying a black special off here for spares so i have it now....but i did originally buy the tech racing one off ebay which is also good but twice the price...
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 06-25-2012, 09:14 AM   #8563
For anyone who has the aluminum roll damper upgrade for the x1 do you build with no rebound and what wt oil is good for rubber tires on asphalt thanks.
MDRTales is offline   Reply With Quote
Old 06-25-2012, 11:32 AM   #8564
Read the instructions
Drill the 1mm hole
900wt
Old 06-25-2012, 12:56 PM   #8565
dfx
dfx's Avatar
Drill the 1mm hole
Sorry for the stupid question but does it mean drill the 1mm hole through the whole plastic part (damper cap)? Don't own V2 yet but it should help in the future...
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
