Old 06-20-2012, 05:01 PM   #8521
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Originally Posted by MantisWorx View Post
We had our first UF1 houston trial run this past saturday!
Hey congratulations, the track looks fantastic!
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 06-20-2012, 07:20 PM   #8522
theDover's Avatar
Originally Posted by skengines View Post
I was reading the article by...
Are those good to start with?
The 3Racing spur uses 1/8 balls? It looks like they only sell 3mm balls though? Not sure why they would sell balls that don't fit their own spur.
Does your local club racing allow aftermarket on your F1?
If so.. Start looking in to 3Racing. Cheaper on price.. not on quality.
I run a complete 3Racing / F104pro. I've converted to 48p gearing and run a Kimbrough Spur with ACER 1/8th ceramic bearings, Associated diff grease, and stock Tamiya diff. rings. Most unbelievable smooth diff.
Not because of the brand of bearings I use, just simply the Tamiya or 3Racing simple direct-drive diff assembly is a great diff. all around. Easy to build and maintain.
BTW.. Fact: 90% of the bearings on our markets are purchased in bulk from a specific manufacturer. Then independent companies make their own labels and packages then sell them to you threw distributors. I know, my friend owns a VERY popular R/C bearing company that most all of you on here know, for 20+years. .
(annonymous) Not ACER either.
Moral of the story, is buy any good set of ceramic bearings from your local Hobby Shop or Online Dealer and your F1 will have a lot better diff. performance.
Promise.
P.S.. Don't be surprised if you see a compatible aftermarket Gear Diff. released soon for the Tamiya F1!
TEAM ULTRALINE / RickyRacerLidz
www.ultralinehobbies.com
Ultraline Hobbies RC Raceway @ facebook
theDover is offline   Reply With Quote
Old 06-20-2012, 09:11 PM   #8523
WratchetHead's Avatar
Hey All; Just wanted to say thanks for all the info and tips. I have finally got a place to run my Pro. Here are a few pics of it. Thanks Again.
AnyThing Worth Doing Is Worth Doing RIGHT
OffRoad:AE SC10 FT / AE RC10T4.1 FT/AE SCB-10FT
OnRoad:Tamiya F-103 RX/Tamiya F-104Pro/Tamiya Mini M03L/HPI Pro4 VTA
Tekin/Savox/Spectrum/JConcepts/Paradise Hobbies/Jeff's RC Studio
TEAM TERRIBLES RACING/WrenchHead Racing/ SuperBikes&Ski/Team Holy Rollers
WratchetHead is offline   Reply With Quote
Old 06-21-2012, 01:25 AM   #8524
skengines's Avatar
Trader Rating: 226 (100%+)
Originally Posted by Alfie View Post
I swapped that piece of bearing for the 1-piece thrust bearing.
After that, the orientation is: 1-piece thrust bearing + > + < + spacer + nut.
Hope it helps!
Alfie
I have the thrust bearing, but do I need to replace my bearing with the thrust bearing?
Advantages?
btw: I am running a Kimbrough 64pitch spur with the tamiya spacer replacing the bearing.
skengines is offline   Reply With Quote
Old 06-21-2012, 01:36 AM   #8525
Pro10noob's Avatar
What has been said before.
Loose the original ballbearing and replace it with a one piece trustbearing en then the springwashers like this )( then the alloy ring, after that the nut.
This is also when you use other spur gears.
Almost no rebuilds needed when running on clean tracks and smooth as a baby bottum
regards Roy
I have the thrust bearing, but the mini illustration guide shows to place the thrust bearing in between the thrust washers? Which is the correct way and do I need this?
Advantages?
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-21-2012, 01:47 AM   #8526
skengines's Avatar
Also with the thrust washers, I read it goes )( and NOT (). Is that correct?
Old 06-21-2012, 01:51 AM   #8527
Pro10noob's Avatar
Lol
See above post
regards Roy
l===/o\===l
Old 06-21-2012, 01:54 AM   #8528
Default which tyre for f104 v2
Hi guys...
I'm getting f104 v2 and i have a stupid question...
which rubber tire i should buy....are they the same as f104 or have to use bigger tire on rear...
thanks
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 06-21-2012, 04:33 AM   #8529
malcnz's Avatar
Originally Posted by k4mp4q View Post
Hi guys...
thanks
they are the same
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 06-21-2012, 05:25 AM   #8530
Originally Posted by malcnz View Post
they are the same
They are not the same, F104 rear tires are a little wider than fronts tyres.
Front rims 30 mm
Rear rims 35 mm
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 06-21-2012, 05:55 AM   #8531
Front rims 30 mm
Rear rims 35 mm
Think he meant that the wheels/tyres are the same on a F104 V2. compared to a normal f104. Not the same front vs rear.
J-PaP is offline   Reply With Quote
Old 06-21-2012, 07:38 AM   #8532
skengines's Avatar
Thanks good sir!
Old 06-21-2012, 09:38 AM   #8533
Nice car wratchethead
TEN-SCTE-RX8-Pro4 4600-Hitec 7955-TLR Chassis + everything else!
TEN-SCTE-MMP-Tenshock 5200-Spektrum 6040
Mini 8ight-all carbon and aluminum upgrades-Hitec servo (fastest car I have!)
TLR 22-Tekin RS-Tekin 8.5-Savox- +++
Kyosho ZX5 FS2-Tekin RS Pro-Tekin 6.5-Futaba S9452 + slam loaded!
johnnytwothumbs is offline   Reply With Quote
Old 06-21-2012, 11:26 AM   #8534
hanzo3's Avatar
Trader Rating: 55 (100%+)
My carbon shaft has bearings that are hard to remove. With the steel shaft bearings slip out so easily. Does that happen to anyone? Or was my carbon shaft warped?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 06-21-2012, 11:31 AM   #8535
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
The set screw securing the left hub will warp the end on the carbon shaft
This can be sanded to fix the issue
Not an issue with a steel axle
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
