Like Tree1Likes
Old 06-17-2012, 08:28 PM   #8491
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by F N CUDA View Post
If you saw RedBullFiXX's final diff (and racing) results you'd be extremely jealous.
Butter smooth yet 0 slip.
Feels as though you were turning the front wheels in opposite directions, yep, that free.
12th scale guys are particular like that.
Ceramic diff balls have been spotted going into his spurs.
Originally Posted by robk View Post
Great description....RBF knows his stuff!!!
Thanks guys
My logic is of course based on pan cars, so I can see the confusion from the Sedan racers on terminology
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-17-2012, 08:52 PM   #8492
hanzo3's Avatar
Trader Rating: 55 (100%+)
RBF: what do you put on the diff balls? You told me no on the AE black grease?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 06-17-2012, 09:38 PM   #8493
skengines's Avatar
Trader Rating: 226 (100%+)
I use AE Diff lube. Seems to work best on all my diffs.
skengines is offline   Reply With Quote
Old 06-17-2012, 09:50 PM   #8494
CR0SS's Avatar
Originally Posted by RedBullFiXX View Post
This, but I call it locked, as opposed to a slipping diff, where you pull the throttle and the diff slips, but the wheels don't turn for a bit
With 2WD pan cars we like a lot of diff action, unlike 4WD sedan where the front can pull the car around
A diff that is slipping is not working and needs fixed. With ball diffs we get the advantage of easily adjusting how active the diff is by loosening or tightening it. A ball diff should never slip when built and adjusted correctly(if a gear diff slips you have bigger problems). If it slips I would say it is malfunctioning and you need to readjust it, not lock it. Hearing or noticing a ball diff slip even once on the track is reason to do a full diff rebuild and hope the diff rings and balls do not need replaced.
What do you call a locked diff? A spool is a locked non-adjustable diff. Calling a diff locked like you do is confusing since a majority of people when discussing diffs consider a locked diff to be a diff that does not allow the wheels to spin at different speeds.
For diff balls I have always used Associated Stealth diff lube. Getting a very smooth acting diff is not hard you just need to pay close attention to what you are doing and when adjusting even 1/8th of a turn on the screw can be a big adjustment. It is maintaining a smooth loose diff that can become tedious. The F104 to me has the easiest diff to adjust out of any car I have ever run.
You know the guy that beat you at the last race? It was not because of his car, or motor, or battery, it is because he was a better driver. Now go practice so you can beat him.
Visit my Youtube channel for HD R/C videos. http://www.youtube.com/user/DHCross1
CR0SS is offline   Reply With Quote
Old 06-18-2012, 01:25 AM   #8495
Originally Posted by InspGadgt View Post
A bad rear bearing or a left side hub set too tight against the bearing will also cause the car to pull to one side
i find my 104 is going left very badly. i have been setting and reset the diff as it must be to to tight and this does not give me any help. i read this and it finds me to make sense. but i have a question to ask. when putting the left wheel side on how is it positioned on the axle? should i leave a amsll gap between the bearing and the hub(wouldnt this move left and right and cause problem?) or put a spacer between the hub and the bearing?
i check my bearing as we run on a low grip carpark and the bearings find alot of dust.they are replaced often.
thanks
freakyfreakyflo is offline   Reply With Quote
Old 06-18-2012, 01:46 AM   #8496
There should be a very small gap...rule of thumb is to insert a piece of paper between the hub and the bearing when you tighten down. I find personally that I push too hard on the hub and don't get a big enough gap so I fold the paper and use the double thickness.
Old 06-18-2012, 05:10 AM   #8497
Trader Rating: 24 (100%+)
RBF, now that we're on common ground ( in other words "I ain't as ignorant as I once was" ) Maybe you could post how you build a 104 diff and what materials, lubes, equipment,etc. you might use ?? As mentioned, us touring car converts could stand to learn a few things. I'm sure finding that out !
Evoracer is offline   Reply With Quote
Old 06-18-2012, 07:14 AM   #8498
If you follow the link in my sig to 12th info center there is a TON of info about pan car setup
This one in particular is a very good article on Diff Building
The most common issue I've seen are racers using something other than "Silicon Diff Lube"
With the wrong lube, you end up cranking the preload nut down too tight to keep it from slipping, and it kills the diff action
Old 06-18-2012, 09:25 AM   #8499
Oortael's Avatar
Originally Posted by Oortael View Post
Hi,
I bought 4 sets of scales to measure the weight of my F104Pro on each axle/tire. I messured following values:
rear left: 331g
rear rigth: 287g
front left: 226g
front rigth: 248g
IMHO it would be best to have the left and the rigth hand side of the car balanced at the same weight.
Could that result that out of where I put my electronics, or could the car be tweaked somewhere? I put some weight on each electronic post to balance my Spectrum receiver with the Tamiya TEU-302BK ESC.
What are the best ways to balance the weight of the car? What relation (front to rear, left to right) is common?
regards
Oortael
Has no one any idea on that?
Oortael is offline   Reply With Quote
Old 06-18-2012, 11:47 AM   #8500
Some great info there. Been to the IRS site many times but can't remember ever reading that diff build info. Amazing how long I've been building diffs and, apparently, building them wrong !! I usually use 1000 grit and try to get a nice "polished" surface. Never thought about a rougher finish being better. Also not used to very minimal application of lube. Always brushed on a coat of silicone or teflon grease to the rings and the diff balls. Amazed how much I thought I knew and how little I actually know.
Old 06-18-2012, 12:23 PM   #8501
Trader Rating: 45 (100%+)
In the past, I've always thought about putting my rc cars on 4 scales like you've done, but I knew it would just be an endless battle.
For a Tamiya F1(04x1), there is no tweak adjustment so it's best to mount your electronics so when you lift up the front end (at the centerline) that both wheels come off the ground at the same time. Best way to achieve balance is to mount your electronics down the center of the chassis. With shorty packs it's possible to do this now. I also use a tweak board (similar to this one http://www.integy.com/st_prod.html?p...53&p_catid=163) to make sure the chassis is balanced. It's amazing how wires going to the motor can tweak the chassis, the rear pod isn't square, the top plate was not torqued down in sequence, a front spring is over collapsed can all cause tweak.
For fore/aft balance you can move the shorty pack forward/backward for the steering characteristics you're looking to achieve for the track/layout. If you move the battery to the back more grip is achieved, but the car has tons of initial steering. If you move it fwd, it has less initial steering and more mid/exit steering.
Apex is offline   Reply With Quote
Old 06-18-2012, 07:15 PM   #8502
skengines's Avatar
How do you guys mount tires to the rim? Manual says to use tape but I don't think that will hold.
Will AKA Tire glue work fine?
Also do you guys use the foam inserts? I read some people don't use inserts.
Old 06-18-2012, 07:53 PM   #8503
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
I've never had a problem with the tape, but I've been always wanting to give this a go:
http://www.youtube.com/watch?v=jKFfyyHD1bU
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 06-18-2012, 08:01 PM   #8504
hanzo3's Avatar
There are instructions on tq s site.
Chris TRF419 TA05V2
Old 06-18-2012, 08:08 PM   #8505
Tape is for foam tires...for rubber tires use CA glue
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
