Like Tree5Likes
Old 06-16-2012, 10:44 PM   #8446
skengines's Avatar
Trader Rating: 226 (100%+)
Originally Posted by J-PaP View Post
tamiya 54125 is the spur gear spacer you need.
Using kawada spurs with 3mm diff balls and no issues. i prefer using the tamiya ceramic diff balls.
No need to replace your diff plate just sanding them with 600 grit sand paper soaked in water.
kawada spur uses 8 balls.
Thanks!
Do you know if the 3racing spur gear uses 3mm balls? tq doesnt stock kawada.
Also what size spurs do most of you guys keep handy? Gonna place my order through tq tomorrow.
skengines is offline   Reply With Quote
Old 06-16-2012, 10:49 PM   #8447
Vyger's Avatar
Originally Posted by RedBullFiXX View Post
The VII pic is a friends car that will likely never see an actual track
Thanks man...
Don't you know, words cut deeper than knives...
Tamiya Road Wizard, F101s, F102s, F103s, F103RSs, F103LM, F103RXs, F103RMs, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 06-16-2012, 11:00 PM   #8448
Originally Posted by skengines View Post
Thanks!
Should be fine with 3mm having a look at the spurs. 3mm vs 1/8 is only 0.1mm difference.
Just use 93t normally but have 90t as well if i need to really drop the ratio down.
J-PaP is offline   Reply With Quote
Old 06-16-2012, 11:08 PM   #8449
blade072's Avatar
Trader Rating: 98 (100%+)
i think i just realised i was using 2mm balls at the time when it melted......not 3mm..... just found some spares....no wonder it died
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 06-16-2012, 11:09 PM   #8450
skengines's Avatar
Do you run at TQ?
As for pinions 30-35? Thanks for your help
Old 06-16-2012, 11:14 PM   #8451
Yeah that would do it. At 2mm your diff balls wouldn't have actually been touching the diff plates.
Do you run at TQ?
Nah I'm not even in the US. If it is 21.5 blinky then 30-35 should be about right. If silver can then 25-30.
Old 06-16-2012, 11:19 PM   #8452
blade072's Avatar
am running 21.5 blinky and i have 72 spur 24 pinion (48p) which is a fdr or 3.0 and the thing flies.....
our track is quite big and flowing though as for diff balls.... also my diff seams to loosen itself after a slight accident.....will sand my diffs for the next meet....also might try 3mm balls
David Randall
Old 06-16-2012, 11:38 PM   #8453
blade072's Avatar
correction i was using 3mm ceramic balls when it melted......just looked at my order history at the time it happened...i knew i wouldnt be that stupid
David Randall
Old 06-16-2012, 11:42 PM   #8454
The diff will slowly loosen itself over time. Think I need to re-adjust mine every 3-4 meets.
What motor and esc are you using? I'm down to a 2.4 ratio so far on my blinky car. I think I may push it further as it still spins the wheels quite easily.
Old 06-16-2012, 11:49 PM   #8455
blade072's Avatar
using a viper vtx-10 with a lrp x12 with max timing.......no wonder your getting wheel spin......its too low ever thought of going higher??...i dont have that issue....an using an f104X1 with ride supersofts all round
David Randall
Old 06-17-2012, 12:30 AM   #8456
Think you may have it the wrong way around. The lower the ratio the less likely you will spin the tyres.
Old 06-17-2012, 12:54 AM   #8457
blade072's Avatar
think you have.....if thats the case then a 13.5 motor would be slower than a 17.5 motor....
the bigger the spur/pinion the less rip you get out of the corners and would be easier to drive (smoother)....
thats why you are getting wheelspin because you have gone too low and out of curiosity how many years have you been racing and what classes???
in most cases with gear ratios and motor winds.....the lower the number the faster it is usually
David Randall
Old 06-17-2012, 01:32 AM   #8458
You are confusing yourself going into motor winds. That is different to gear ratios.
When keeping the motor and everything else identical, as you lower the gear ratio the car will have a higher top speed and lower acceleration. Lowering your gear ratio does not increase acceleration and top speed.
What does the number of years I have been racing have to do with anything?
Old 06-17-2012, 01:46 AM   #8459
blade072's Avatar
i am not confusing myself mate.....you will see that if you set your car to higher ratio number like 3.0 you will find you wont get as much wheelspin....the closer you go to 1:1 the faster acceleration you will have out of the corners.....
with extra speed comes extra acceleration.......
try it for yourself and see how it goes.....
as for years racing.....let me reword that, what other cars or classes have you run??
also what ratio are you thinking of running???
David Randall
Old 06-17-2012, 01:51 AM   #8460
If your diff is locked (and it should be) it will go straight on power, unless there is something off in the front end
Try using proper silicon diff grease
A bad rear bearing or a left side hub set too tight against the bearing will also cause the car to pull to one side
3Racing spur gear uses 1/8th diff balls stock.
On the gear ratio Jpap is right...the higher the ratio is numerically the more wheel spin you will get. The closer to 1:1 you get the less wheel spin you get.
almost 20 years racing...over 10 years as a race director...3 years as a contributing author. Other classes (brushed): Stock 27t 1/10th pan car (road course), stock 27t 1/12th pan car, stock touring car, mod 1/10th pan car, mod touring car, Tamiya black can F1, 1/10th stock 2wdbuggy, 1/10th stock stadium truck, mod 1/10th monster truck, mod 1/10th 4wd buggy, oval mod 1/10th pan car. Other classes (nitro): 1/10th 2wd .15 nitro, 1/8th 4wd .21 nitro (on-road), 1/8th 4wd buggy .21 nitro. Other classes (brushless): 17.5 boost 1/12th scale, 13.5 boost 1/12th scale, 10.5 1/12th scale, 17.5 blinky 1/12th scale, 13.5 blinky 1/12th scale, 17.5 boost touring car, 21.5 blinky F1...I think that is it...I might be missing one or 2...it's been a long run and I don't remember them all
This is theoretically true to an extent but not in terms of gear ratio...if you use say a 100 spur and 50 pinion vs say a 50 spur and 25 pinion...the gear ratios themselves are the same but the 100/50 has more rotating mass than the 50/25 so you will lose some punch. However in practical terms the gear ratios being the same the difference in mass has such a small difference in acceleration that the average driver isn't going to be able to tell the difference. Now if you compare the 100/25 to say a 50/25...you now have a 4:1 gear ratio vs a 2:1 gear ratio. Even though the 100/25 are bigger gears they are going to have more acceleration and therefore more wheel spin than the 50/25.
This is true...however more top end does not mean more wheel spin...more acceleration = more wheel spin. Top speed and acceleration have an inverse relationship. Meaning the more top speed you have the less acceleration you will get...the more acceleration you have the less top speed you will have.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
