Old 06-16-2012, 12:05 PM   #8431
Originally Posted by skengines View Post
So this is what I have so far.
Futaba 9551
Tekin 21.5
Tekin RS Pro
Shorty LiPo
Futaba Receiver
Will still need to get 30-35T pinions, but I think I have everything covered? This will be my first time with on road, so just want to make sure I get all my ducks in a row.
Also got the parts below.
F104 F Parts - Suspension Arm/Front
F104 J PARTS (Front Wing
F104 Mesh Wheels - For Rubber Tires (F/R)
F104 Rubber Tires Front
F104 Rubber Tires Rear
F103 / F104 1 Piece Ball Thrust Bearing
5mm Alum Ball Nut - Fluorine Coated 10pcs
F104 Titanium Coated King Pin - 2pcs
F104 Rubber Tires - Rear/Soft
Tamiya Rear Steel Shaft 6x110mm F104
F104 Font F3-Soft (1 pair)
If you are running the old F104 you will probably want a softer rear t-plate. If you are running the V2 you won't need it.
Old 06-16-2012, 12:27 PM   #8432
skengines's Avatar
Trader Rating: 226 (100%+)
Yep, I'm running the older F104 Pro. Was thinking of the V2 but figured I would start off with this before getting a better model.
Link to the t-plate? Where do you guys usually get your parts? Amain doesn't sell Tamiya parts
skengines is offline   Reply With Quote
Old 06-16-2012, 12:32 PM   #8433
skengines's Avatar
Originally Posted by Dan View Post
64P pitch pinions are okay to use with the stock Tamiya spur? Are you positive? Just don't want to strip any spurs....
Can anyone confirm this? gonna order 30-35T 64P pinions today.
Old 06-16-2012, 12:44 PM   #8434
I know at least 1-2 guys who have used 64p with a tamiya spur without a problem. Why not just spend a few dollars and get a spur gear spacer and a 64p spur and you will be 100% safe.
J-PaP is offline   Reply With Quote
Old 06-16-2012, 12:57 PM   #8435
skengines's Avatar
So with the F104, any recommendation on what spur gears I need then?
Old 06-16-2012, 01:01 PM   #8436
hanzo3's Avatar
Trader Rating: 55 (100%+)
Do we have to turn down throttle expo for f1s? When I gun it on a straight it either goes left or right. My trim looks fine when it is slow. Diff is nice and smooth. Ceramic bearings and ae black grease. Do I need to change my thrust bearing assembly?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 06-16-2012, 01:04 PM   #8437
link to spacer?
i used the 3Racing spur gear adapter from theF109 and it works well
as for spur gears i use the Corally Delrin white spurs and they are great even outdoors
http://www.stellamodels.com.hk/54215...04-p-4594.html
sidecarphil1 is offline   Reply With Quote
Old 06-16-2012, 01:08 PM   #8438
http://www.tamiyausa.com/product/ite...oduct-id=54222
http://www.tqrcracing.com/shop/produ...w.asp?p_id=882
Xenon spur gears are awesome if you can find them. Lots of holes for diff balls makes for a smoother diff.
Old 06-16-2012, 02:51 PM   #8439
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
If your diff is locked (and it should be) it will go straight on power, unless there is something off in the front end
Try using proper silicon diff grease
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-16-2012, 08:49 PM   #8440
skengines's Avatar
When running the 64 pitch spurs, do I need to use different diff balls? In the manual the Tamiya spur only uses 6 diff balls but i noticed with the 3Racing Spur it was 8 holes plus additional holes on the outside.
Old 06-16-2012, 08:53 PM   #8441
blade072's Avatar
Trader Rating: 98 (100%+)
get some 1/8 diff balls...although some say the 3mm ones will work...but i melted one of my spurs hence the change to 1/8 balls and have not had an issue since but i am using kawada and kimbrough spurs
David Randall
AWESOMATIX A800 ★ MUCHMORE ★ R1 WURKS ★
TEAM XRAY X116 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 06-16-2012, 09:03 PM   #8442
skengines's Avatar
Originally Posted by blade072 View Post
get some 1/8 diff balls...although some say the 2mm ones will work...but i melted one of my spurs hence the change to 1/8 balls and have not had an issue since but i am using kawada and kimbrough spurs
How many balls do I need to run in the 3racing spur gear and do I need new diff rings?
If possible can someone provide me with links to what I will need? Appreciate all the help! It's a lot different from off road.
Old 06-16-2012, 10:21 PM   #8443
blade072's Avatar
yes you will need to use 8 balls for the holes that line up with the rings...
the standard diff rings are fine.....you might need to get a spur gear adapter though
and 1/8 balls
http://www.tqrcracing.com/forum/view...no=43&bbs_no=9
above is a link to the 3racing f109 manual and below is a link to the adapter needed
http://www.tqrcracing.com/shop/produ...r+gear&pg_no=3
David Randall
Old 06-16-2012, 10:30 PM   #8444
tamiya 54125 is the spur gear spacer you need.
Using kawada spurs with 3mm diff balls and no issues. i prefer using the tamiya ceramic diff balls.
No need to replace your diff plate just sanding them with 600 grit sand paper soaked in water.
kawada spur uses 8 balls.
Old 06-16-2012, 10:41 PM   #8445
blade072's Avatar
i melted my kawada using 3mm.....but glad to see you got yours to work without an issue.....
David Randall
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
