Old 05-28-2012, 05:44 AM   #8326
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by MikeR View Post
Hi All,
The F60 wing braces are ready now.
http://www.exotekracing.com/f1-wing-...60-front-wing/
Thanks!
hey Mike - will this brace work on any other front wing, or just the F60's wing?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-28-2012, 08:49 AM   #8327
Giorgio's Avatar
Speaking on rubber tires...
Yesterday was one of those day in which nothing works properly... Same car able to take 1st position on the previous sunday was undriveable... no matter what
At the end of the tunnel... I've tested on an F104-X1 a set of Ride (ETS version, H1 all around), on asphalt.
Waaay better... car was "round" to drive, easy.
As we normally use Tamiya foam... but we could use Tamiya Rubber as well... how can I comapre Tamiya rubber whit Ride rubber?
Thanks!!!!
www.fenix-racing.com
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Old 05-29-2012, 12:35 AM   #8328
I have f104w gp and am confused with tire selection.
first of all I want to try wide tire for 103 on my car. Can I use them? Do I need any mod to do that? Also DO i need any extra parts?
aackjw is offline   Reply With Quote
Old 05-29-2012, 12:45 AM   #8329
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Same tires and wheels as F-103
You can also bolt on the F-104 front end, and use 104 tires and wheels, rubber or foam
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-29-2012, 03:55 AM   #8330
I am ready for E.T.S this weekend
F104pro with X1 conversion Ride H1 Rubbers
GO GO GO !!!!!!!
sidecarphil1 is offline   Reply With Quote
Old 05-30-2012, 12:59 AM   #8331
Matthijs's Avatar
I'm also ready for the ETS this weekend, should be fun!
F104x1 with ETS rules (Cirtix stock and 21.5 speedpassion sportsman, Ride tires and shorty lipo)
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 05-30-2012, 03:34 AM   #8332
blade072's Avatar
Trader Rating: 98 (100%+)
very nice.....i will be trying my X1 on sunday at our track...have installed the r sector high capacity lipo conversion, also using shorty packs and ride tires ....
also i am using the f104pro body....am thinking of getting the f60 body...would it be different handling wise??
David Randall
AWESOMATIX A800 ★ MUCHMORE ★ R1 WURKS ★
TEAM XRAY X116 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 05-31-2012, 12:29 PM   #8333
240Z's Avatar
Thanks!!!!
UF1 site has a good tire review. The new Shimizu compounds are in the review and are much better than any Ride tire currently offered.
240Z is offline   Reply With Quote
Old 05-31-2012, 02:47 PM   #8334
Giorgio's Avatar
Thanks for the info. But for the Tamiya series we must use Tamiya stuff...
Old 05-31-2012, 03:14 PM   #8335
When did they change the compounds? Do they still have that lip that goes over the side of the rim? I'm planning on trying other brands just because of how ripped up the Shimizu tires get because of the way they mount on the rim.
Old 05-31-2012, 04:14 PM   #8336
Yes, still the same shape/design
Don't hit so much stuff and they don't get so ripped up
Old 05-31-2012, 06:06 PM   #8337
Old 05-31-2012, 07:37 PM   #8338
F N CUDA's Avatar
The Pit Shimizu 571/572 combo is much tougher as far as sidewalls go and the grip is the best my car has ever seen.
(been recently noted that Rick Hohwart dialed his car in and handily kicked our asses with 577's up front in order to calm down the steering on his ride.)
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 05-31-2012, 10:18 PM   #8339
I'm running the 571/572 combo and they are tearing up quite quickly...even after I rounded the edges of the rims on this last set. Also the rears don't have enough grip when getting on the throttle...once it is moving it has a huge amount of push. I'm thinking a medium all around will work better on our track. There's an HPI F10 running HPI soft tires all around and it seems to work well on his car so I'm considering trying that as well...but that's all later on down the line as I am currently using my FGX.
Old 06-01-2012, 12:18 AM   #8340
kneedeeppow's Avatar
i concur i would use shimizu rubber hands down over the ride and tamiya and foam. best grip by far front and rear buuuuuuuuut,that rear mounting/ripping system sees them only lasting a minimum amount of time. that side to side movement chomps the rear sidewall out hard. maybe a bigger and or firmer inner....i dunno. so now i run tamiya soft front and rear as its best value by far. sure a bit of performance sacrificed but its pretty minimal to my wheeling
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
