Old 05-24-2012, 07:38 PM   #8311
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Should be 3mm diff balls right.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 05-24-2012, 07:41 PM   #8312
dfiantii's Avatar
robk,
I am going to try to put a few drops of ca on it. It that does not work I may end up going to the Tamiya gear with 8 diff balls instead. Just not liking the wobble action thats going on.
Old 05-24-2012, 09:30 PM   #8313
I run Kawada gears and the tamiya spur adapter and never once had an issue with the spacer coming out. There is bugger all wobble from side to side either. Perhaps the Kawada gears are a better fit?
FST4RD is offline   Reply With Quote
Old 05-24-2012, 09:37 PM   #8314
Trader Rating: 77 (100%+)
I have three top shelf f1 cars for sale.. Check my listing..thanks
artoftatt2 is offline   Reply With Quote
Old 05-25-2012, 06:05 AM   #8315
Originally Posted by MikeR View Post
hello
i would like to know if the nose piece has been made available for market? i think it is a good idea
and,is the x1 upgrade for a 104pro a good part to try?
once again many thanks
freakyfreakyflo is offline   Reply With Quote
Old 05-25-2012, 07:58 AM   #8316
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by fastvee View Post
Wobble left to right is normal(if looked from back of the car) ,but the adapter slipped out from spur and the spur started to wobble front/back. So that needs sorting,maybe gluing the adapter in the spur.
When using a standard spur gear with adapter, only use 1/8" diff balls
3mm diff balls are for the metric Tamiya type spur gear
If the Spur gear adapter does not fit snug, there will be run out, which will make proper gear mesh impossible
Try to find a Spur gear that fits the adapter better, some gears have too large an I.D. to work with the adapter, even though this should be a standard size
You can also use 64p pinion gears with the Tamiya Spur gear, in the larger sizes 30+ the mesh is close enough to work without any issues
There will always be some side to side play in the spur gear, this is normal & should never cause any problems
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-26-2012, 03:31 PM   #8317
Default Setup TQRC TCS Race #173
Here is the setup from the race
Thanks to Arn0 for the editable setup sheet
http://www.petitrc.com/reglages/tami...amiyaF104.html
Old 05-26-2012, 07:52 PM   #8318
blade072's Avatar
Trader Rating: 98 (100%+)
kawada use 1/8 balls......in regards to your adapter moving.....are you sure you are using the bearing on the inside of the outside diff hub???? that seems to hold it in place on mine.....also you didnt make the hole bigger on your spur gear did you????
just a thought
David Randall
AWESOMATIX A800 ★ MUCHMORE ★ R1 WURKS ★
TEAM XRAY X116 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 05-26-2012, 08:31 PM   #8319
just a thought
Didn't realise this.
I've been using 3mm diff balls in my kawada gears. Haven't noticed an issue yet though.
J-PaP is offline   Reply With Quote
Old 05-26-2012, 08:48 PM   #8320
blade072's Avatar
my diff only lasted a run with the 3mm balls (which were ceramic) as it melted the holes on the spur gear....i changed to the 1/8 balls after a fellow racer told me to...still going strong
David Randall
Old 05-27-2012, 12:56 AM   #8321
by 1/8 diff ball do you mean this one?
http://www.tqrcracing.com/shop/produ...yword=&pg_no=1
Old 05-27-2012, 01:10 AM   #8322
blade072's Avatar
correct.......
David Randall
Old 05-27-2012, 05:53 PM   #8323
Originally Posted by freakyfreakyflo View Post
hello
hi, where can i buy this parts please
nobull22 is offline   Reply With Quote
Old 05-27-2012, 06:24 PM   #8324
MikeR's Avatar
Trader Rating: 14 (100%+)
Hi All,
The F60 wing braces are ready now.
http://www.exotekracing.com/f1-wing-...60-front-wing/
Thanks!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-27-2012, 10:05 PM   #8325
idbdoug's Avatar
Trader Rating: 33 (100%+)
I have a F104ProX1 and i'm racing on carpet. I remember reading in the past where people removed the center screw from T-bar and gluing a piece of shock foam over this hole but i can't seem to find this post again. Can somebody either explain this to me or link me to this post!!!
My search Kung Fu in weak
idbdoug
idbdoug is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
